ESP8266 w/ Alexa Help
I am doing a Home Automation Senior Project and my Amazon Alexa App is not finding the ESP8266 when I run the code I get this in the Serial Monitor. Can anyone please help me
Responding search req...
����������������������������������������������������������������ot-Found HTTP call:
URI: /api/2WLEDHardQrI3WHYTHoMcXHgEspsM8ZZRpSKtBQr/lights/1988806784
Body:
AlexaApiCall
ok
l1988806784
1988806784
Got UDP!
M-SEARCH * HTTP/1.1
Host: 239.255.255.250:1900
ST: urn:schemas-upnp-org:device:InternetGatewayDevice:1
Man: "ssdp:discover"
MX: 3
#ifdef ARDUINO_ARCH_ESP32
#include <ESPmDNS.h>
#include <WiFi.h>
#else
#include <ESP8266mDNS.h>
#include <ESP8266WiFi.h>
#endif
#define ESPALEXA_DEBUG
#include <Espalexa.h>
#define RelayPin1 5
boolean connectWifi();
void firstLightChanged(uint8_t brightness);
const char* ssid = "BCUStudents";
const char* password = "";
String Device_1_Name = "Yellow LED";
boolean wifiConnected = false;
Espalexa espalexa;
  pinMode(RelayPin1, OUTPUT);
  wifiConnected = connectWifi();
  if (wifiConnected)
    espalexa.addDevice(Device_1_Name, firstLightChanged);
    espalexa.begin();
    while (1) {
      Serial.println("Can't Connect to WiFi. Please Try Again");
      delay(2500);
  espalexa.loop();
  delay(1);
void firstLightChanged(uint8_t brightness) {
  if (brightness == 255) {
    digitalWrite(RelayPin1, LOW);
    Serial.println("Device1 OFF");
    digitalWrite(RelayPin1, HIGH);
    Serial.println("Device1 ON");
boolean connectWifi() {
  boolean state = true;
  int i = 0;
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  Serial.println("");
  Serial.println("Connecting to WiFi");
  // Wait for connection
  Serial.print("Connecting...");
    Serial.print(".");
    if (i > 20) {
      state = false;
    i++;
  Serial.println("");
  if (state) {
    Serial.print("Connected to ");
    Serial.println(ssid);
    Serial.print("IP address: ");
    Serial.println("Connection failed.");
  return state;
I think the letter N got clobbered in the initialization phase, just press the reset button should solve that, but the error is quite clear, you have the wrong URL.
Where do I find the right URL
Sorry, no idea.
I have downloaded your code and will try it. After changing creds it worked.
Here is the output
Your bad URL error is likely a glitch, just reset the board or re-upload. Here is proof of working
I have pressed the RST Button on the ESP multiple times and reuploaded the Code and I keep getting the error
