HI!
I can not find library ESP8266WebServer.h
I usually get zip file for library from GITHUB, but for ESP8266WebServer I can not find ZIP file.
can you help me?
HI!
can you help me?
The ESP8266WebServer library is part of the esp8266 Arduino boards platform:
So you only need to install that core via the Arduino IDE Boards Manager, following the instructions here:
https://github.com/esp8266/Arduino#installing-with-boards-manager
That will also install the "ESP8266WebServer" library. Note that library is written to run on the ESP8266 (not on a standard Arduino board communicating with an ESP8266 via serial) and is only available when you have one of the boards of the esp8266 platform selected in the Arduino IDE Tools > Board menu.
:o hmmm
With ethernet shield i have no problem...
Wifi shield is programmed differently?
Not directly on Arduino ?
I have this wifi shield
I want to do a web server for reading temperature from ds18b20 sensors. ( With ehternet shield work fine )
Thankyou fpr help
You need to understand there are two ways of using an ESP8266 with Arduino:
Therefore since you're likely using the ESP8266 in the latter manner the ESP8266WebServer library and the esp8266 core won't work for you. For that purpose I recommend the WiFiEsp library suggested by sterretje.
svedr:
That's because the Ethernet library is written for use with the Ethernet shield, the ESP8266WebServer is not written for use with your ESP8266 shield as you are using it.
svedr:
The shield comes preprogrammed with the AT firmware. Unless you want to update that firmware you won't be programming it at all. Instead you are programming the board that the shield is on top of.
Thank you for the explanation...
Do you have maybe an example code for web server for my WifiShield ?
Regards
The library that I linked comes with examples ![]()
Ok.. i see link...
I try "scan network" with arduino mega, change rx,tx to SoftwareSerial Serial1(10, 11); // RX, TX
But no luck...
In serial monitor :
TIMEOUT
WIFI SHIELD NOT PRESENT
Any idea what is wrong =
Wifi shield is connected on Arduino Mega ( like ethernet shield)
Regards
svedr:
Please explain what you mean by that. Unless you have connected it differently, your shield communicates with the ESP8266 via pins 0 and 1 (hardware serial's Serial).
The WebServer example included with that library assumes that if you're using an Arduino Mega you will have the ESP8266 connected to pins 18 and 19(hardware serial's Serial1). The sketch can be easily modified to other wiring configurations.
The code used pin 6 and 7 in softwareserial.
I read that Arduino Mega does not work on these pins so I changed to 10 and 11
code example
WiFiEsp example: ScanNetworks
This example prints the Wifi shield's MAC address, and
scans for available Wifi networks using the Wifi shield.
Every ten seconds, it scans again. It doesn't actually
connect to any network, so no encryption scheme is specified.
For more details see: http://yaab-arduino.blogspot.com/p/wifiesp.html
#include "WiFiEsp.h"
// Emulate Serial1 on pins 6/7 if not present
#ifndef HAVE_HWSERIAL1
#include "SoftwareSerial.h"
SoftwareSerial Serial1(6, 7); // RX, TX
#endif
// initialize serial for debugging
// initialize serial for ESP module
Serial1.begin(9600);
// initialize ESP module
WiFi.init(&Serial1);
// check for the presence of the shield
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue
while (true);
// Print WiFi MAC address
printMacAddress();
// scan for existing networks
Serial.println("Scanning available networks...");
listNetworks();
delay(10000);
void printMacAddress()
// get your MAC address
byte mac[6];
WiFi.macAddress(mac);
// print MAC address
char buf[20];
sprintf(buf, "%02X:%02X:%02X:%02X:%02X:%02X", mac[5], mac[4], mac[3], mac[2], mac[1], mac[0]);
Serial.print("MAC address: ");
Serial.println(buf);
void listNetworks()
// scan for nearby networks
int numSsid = WiFi.scanNetworks();
if (numSsid == -1) {
Serial.println("Couldn't get a wifi connection");
while (true);
// print the list of networks seen
Serial.print("Number of available networks:");
Serial.println(numSsid);
// print the network number and name for each network found
for (int thisNet = 0; thisNet < numSsid; thisNet++) {
Serial.print(thisNet);
Serial.print(") ");
Serial.print(WiFi.SSID(thisNet));
Serial.print("\tSignal: ");
Serial.print(WiFi.RSSI(thisNet));
Serial.print(" dBm");
Serial.print("\tEncryption: ");
printEncryptionType(WiFi.encryptionType(thisNet));
void printEncryptionType(int thisType) {
// read the encryption type and print out the name
switch (thisType) {
case ENC_TYPE_WEP:
Serial.print("WEP");
case ENC_TYPE_WPA_PSK:
Serial.print("WPA_PSK");
case ENC_TYPE_WPA2_PSK:
Serial.print("WPA2_PSK");
case ENC_TYPE_WPA_WPA2_PSK:
Serial.print("WPA_WPA2_PSK");
case ENC_TYPE_NONE:
Serial.print("None");
My wifi shield is mounted on arduino mega.
What should I change in code that will work ?
svedr:
That's correct but the problem is two things. First of all the way the sketch is written:
#endif
Means that since the Mega has multiple hardware serial ports, HAVE_HWSERIAL1 is defined, and thus the lines dealing with SoftwareSerial will never be run. Instead hardware serial Serial1 will be used.
Second, as I said, on the Mega hardware serial Serial1 is pins 18 and 19 but unless you have changed the wiring your shield is not connected to pins 18 and 19, it's connected to pins 0 and 1.
So ignore the SoftwareSerial stuff and change every reference to Serial1 in that sketch to Serial.
Next problem, your shield runs at 115200 baud by default but the sketch is written for 9600 baud so unless you 've changed the baud rate of your shield you need to change the sketch to communicate at 115200 baud.
So here's the updated sketch:
#endif
// Serial.begin(115200);
WiFi.init(&Serial);
// don't continue
while (true);
printMacAddress();
listNetworks();
delay(10000);
byte mac[6];
char buf[20];
void listNetworks()
while (true);
Serial.print(") ");
switch (thisType) {
case ENC_TYPE_WEP:
case ENC_TYPE_NONE:
Now my experience with this library is that all the debug output interferes with communication with the ESP8266 since they are also sent via Serial and thus make the library not work. This is unfortunate because without debug output you are basically working blind until you can actually get network communication going. So give the sketch I provided a try as is just to make sure I'm not wrong about that and if it doesn't work come back and I'll instruct you on how to disable the debug output.
I try with arduino uno, arduino mega....diferent pins, hw, serial....nothing work.
Time out..... in serial monitor....
Can write someone exactly how to connect and attach code, please?
I found manual for wifi shield.
My phone find this Wifi Shield ?? :o :o :o
But page for config is not available....
Any help ?
Manual :
That's a completely different shield. The instructions in that manual won't apply to your shield.
I haven't forgotten about you but I had a work deadline so I haven't been able to finish my response to your last post in this thread. I need to get a few hours sleep before I have to get up and go back to work but it's on my to do list still.
OK.... go to sleep then help me please....
Again.... here is photo of my shield:
ESP8266 ESP-12 ARDUINO WIFI SHIELD
I spent three days in forums and blogs....
Again my resoults.
l`rl-n't use rtc mem data
rl--rl--
Ai-Thinker Technology Co.,Ltd.
ready
AT command not work
I'm very grateful for help......
@pert is far more a specialist in this than I am (I don't have the shield, he seems to have / had one).
Dig a bit on the web and search for elecshop.ml; it seems some people have succeeded to use it on an Uno. This seems to be the latest.
Maybe it helps.
HI!
Finally, I have some success.
i have programmed wifi modul directly from the Arduino Sotware.
and work ! :o :o :o
Does this mean that they do not need arduino ???
Work independently ???
Can I connect sensor ds18b20 like on arduino and craate my home webserver with temperature ??
Why then has the base for Arduino ? Better cut it ? ![]()
Still not clear to me why not work mounted on arduino and
and why would I use Arduino if i do not need....
For begginer like me is this big shock.
First i finnaly create arduino+ethernet shield temperature webserver,
but when I want to do the same with arduino+wifishield is completely different story. >:(
svedr:
Glad to hear!
svedr:
Sure, you can program the ESP8266 directly using the esp8266 Arduino core (as I pointed out in reply #1) and not use the Mega at all. Obviously your shield is not intended for that purpose but there's no reason you can't use it that way. Typically you would use a board such as WeMos D1 Mini, NodeMCU, or Adafruit Huzzah, etc. for that usage of ESP8266.
svedr:
I don't see why not.
svedr:
Why then has the base for Arduino ? Better cut it ?Still not clear to me why not work mounted on arduino and
There are some significant benefits of using the ESP8266 alone. The processor runs at 5-10X faster than the Mega. It has 16X the flash memory. It has 10X the SRAM. Connecting an ESP8266 to an AVR is kind of like towing a sports car with a bicycle. However, there are some differences to the ESP8266 that may be a disadvantage also. The ESP8266 runs at 3.3V, which may make it a bit more difficult to interface with 5V devices. Some libraries and example sketches are written specifically for the AVR architecture of the standard Arduino boards and are not compatible with ESP8266. There are some differences in programming the ESP8266 and the documentation of the esp8266 core is not quite so good as the Arduino AVR Boards core (though it has gotten much better recently). The WiFi stack is running in the background on the ESP8266 so that needs to be continually serviced. In fact there is a watchdog timer that will cause the ESP8266 to reset if you write any blocking code (though you can safely use delay()) so there is something to be said for letting the ESP8266 just do WiFi and do everything else on a connected AVR. The Mega (or even the smaller boards such as Uno) have more I/O pins than the ESP8266. The ESP8266 GPIO has an absolute maximum of 12mA, on the AVR boards this is 40mA. So I'm not really sure which option is more beginner friendly. Programming the ESP8266 is significantly more difficult than AVR boards. However, for some reason some people seem to have a huge difficulty understanding how communication between the AVR and ESP8266 via serial works.
Pert, thankyou for your help.
I try change my code for arduino+ethernet server for esp8288. I thing i have enough pin.
For finish, this wifi shield is realy accidental version.
For upload code is needed dip switch 1 and 2 ON, for working 1 and 2 OFF.
For write firmware the third option, I forgot.
confusion is because I have two wifi shield and not having the same mounted dip switch, one is turned upside down
second up.
I hope ,that they are other models more user-friendly
Regards!!
