I have a problem with my project. My My smartphone doesn't recognize ESP8266 and I can't connect it for controlling my robot with the app. Can anyone help me?
You started a topic in the Uncategorised category of the forum when its description explicitly tells you not to
Your topic has been moved to a relevant category. Please be careful in future when deciding where to start new topics
This is my Arduino code:
/* include library */
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
WiFiClient client;
/* defining server prt */
ESP8266WebServer server(80);
/* Define WiFi Credentials */
const char* ssid = "hash";/* Your SSID */
const char* password = "12345678";/* Your Password*/
String data="";
#include "HCPCA9685.h"
/* I2C slave address for the device/module. For the HCMODU0097 the default I2C address
is 0x40 */
#define I2CAdd 0x40
int pos1=0;
int pos2=100;
int pos3=200;
int pos5=150;
const float pos4=80.0/pos5;
/* Create an instance of the library */
HCPCA9685 HCPCA9685(I2CAdd);
Serial.println("GPIO test!");
/*connecting to WiFi */
server.begin();
Serial.println("server started");
HCPCA9685.Init(SERVO_MODE);
/* Wake the device up */
HCPCA9685.Sleep(false);
unsigned int Pos;
/* Move Forward */
void move_forward() {
/* Initialise the library and set it to 'servo mode' */
unsigned int Pos;
HCPCA9685.Servo(2, pos1);
HCPCA9685.Servo(5, pos1);
/* Handling Request */
server.handleClient();
String data = server.arg("Key");
Serial.println(data);
if (data == "F") {
move_forward(); /* If data B moves forward */
void handleRequest() {
if (server.hasArg("Key")) {
Serial.println(server.arg("Key"));
if (server.hasArg("Speed")) {
Serial.println(server.arg("Speed"));
server.send(200,"text/html","");
delay(1);
void connectingToWiFi() {
delay(3000);
WiFi.disconnect();
Serial.println("Connecting to WiFi");
WiFi.begin(ssid, password);
while ((!(WiFi.status() == WL_CONNECTED))) {
Serial.print("...");
Serial.println("Connected");
Serial.println("Local IP is : ");
Serial.print((WiFi.localIP().toString()));
delay(5000);
You need to give more details of what you are trying to do
Please post the code that is running on the ESP8266, using code tags when you do. Which 'phone app are you using ?
thank you for your notice.I will be more careful next time
My smartphone model is Samsung A31
does the ESP8266 serial monitor output display connection to your network and display its IP address?
if so the smartphone should then be able to connect to the same WiFi network and a web client enter the IP address as the URL to view the web page
post your serial monitor output (as text not a screen image)
maybe easier for the ESP8266 to run an Access Point with web server - the smartphone then connects to the access point to view the web page
no serial monitor doesn't display connection
I used MIT App inventor to make android app
after compiling and uploading what does it display?
displays this message:
. Variables and constants in RAM (global, static), used 29016 / 80192 bytes (36%)
║ SEGMENT BYTES DESCRIPTION
╠══ DATA 1504 initialized variables
╠══ RODATA 976 constants
╚══ BSS 26536 zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 60491 / 65536 bytes (92%)
╠══ ICACHE 32768 reserved space for flash instruction cache
╚══ IRAM 27723 code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 270544 / 1048576 bytes (25%)
╚══ IROM 270544 code in flash
esptool.py v3.0
Serial port COM8
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 30:83:98:82:a7:38
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 304896 bytes to 221421...
Writing at 0x00000000... (7 %)
Writing at 0x00004000... (14 %)
Writing at 0x00008000... (21 %)
Writing at 0x0000c000... (28 %)
Writing at 0x00010000... (35 %)
Writing at 0x00014000... (42 %)
Writing at 0x00018000... (50 %)
Writing at 0x0001c000... (57 %)
Writing at 0x00020000... (64 %)
Writing at 0x00024000... (71 %)
Writing at 0x00028000... (78 %)
Writing at 0x0002c000... (85 %)
Writing at 0x00030000... (92 %)
Writing at 0x00034000... (100 %)
Wrote 304896 bytes (221421 compressed) at 0x00000000 in 19.8 seconds (effective 123.0 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
That is not the Serial monitor output
Nothing is displayed there
before starting the server you need to connect to the WiFi network, e.g.
delay(3000);
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
server.begin();
did you test the WiFi and server before adding the HCPCA9685 code
are you sure the HCPCA9685 works on the ESP8266?
did you test it in a separate program before attempting the control it via a web page
how have you connected and powered the HCPCA9685 and servo?
Yes. I tested HCPCA9685 with this code
is 0x40 */
#define I2CAdd 0x40
int pos1=0;
int pos2=100;
int pos3=200;
int pos5=150;
unsigned int Pos;
HCPCA9685.Servo(8, pos1);
HCPCA9685.Servo(11, pos1);
HCPCA9685.Servo(1, pos1);
HCPCA9685.Servo(4, pos1);
HCPCA9685.Servo(7, pos1);
HCPCA9685.Servo(10, pos1);
HCPCA9685.Servo(0, pos2);
HCPCA9685.Servo(3, pos2);
HCPCA9685.Servo(6, pos2);
HCPCA9685.Servo(9, pos2);
for(Pos = pos1; Pos< pos5; Pos++)
HCPCA9685.Servo(2, Pos);
HCPCA9685.Servo(5, Pos);
HCPCA9685.Servo(8, Pos);
HCPCA9685.Servo(11, Pos);
HCPCA9685.Servo(1, Pos*pos4);
HCPCA9685.Servo(4, Pos*pos4);
HCPCA9685.Servo(7, Pos*pos4);
HCPCA9685.Servo(10, Pos*pos4);
delay(2);
It works correctly
I tested your code but the result didn't changed.
The serial monitor should display at least:
GPIO test!
If it does not are you using the right speed on the serial monitor?
Press the reset button on the board.
you have a function connectingToWiFi() which you don't call - try
delay(3000);
connectingToWiFi();
server.begin();
if I then run your code the serial monitor displays
GPIO test!
Connecting to WiFi
.......................................Connected
Local IP is :
192.168.1.91server started
I reset the board but nothing changed
