My respected gentlemen,
I have the following code where I am using WeMos D1 board + HX7111 Amp + Load Sensor + LCD
The following code runs fine (displaying everything on the screen, showing the WiFi Manager portal, connected and more)
But the issue i'm having is in the loop()
The moment the HX711 scale initiated and reading was attempted, ESP8266 (integrated) suddenly restarted.
I'm very new with Arduino and I dont understand what yield() / watchdog is doing to this code
I believe, if the wifi doesn't get restarted, everything will run super well (do note that the DB connection also working fine in my server DB)
Rui Santos
Complete project details at https://RandomNerdTutorials.com/esp32-esp8266-mysql-database-php/
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files.
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
#ifdef ESP32
#include <WiFi.h>
#include <HTTPClient.h>
#else
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
#endif
#include <WiFiClientSecureBearSSL.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 18, 2);
#include "HX711.h"
// HX711 circuit wiring
const int LOADCELL_DOUT_PIN = D4;
const int LOADCELL_SCK_PIN = D5;
HX711 scale;
// Replace with your network credentials
const char* ssid = "47B 2.4Ghz";
const char* password = "blt4397fuad";
// REPLACE with your Domain name and URL path or IP address with path
const char* serverName = "http://XXXXXXXXXX/writedata.php";
// Keep this API Key value to be compatible with the PHP code provided in the project page.
// If you change the apiKeyValue value, the PHP file /post-esp-data.php also needs to have the same key
String apiKeyValue = "XXXXXXXXXX";
int deviceID = 1;
float volume = 123.45;
WiFiManager wifiManager;
//wifiManager.resetSettings();
wifiManager.autoConnect("Suu Balm Smart Sensor");
Serial.println("Connected...");
lcd.begin();
lcd.backlight();
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Suu Balm");
lcd.setCursor(0, 1);
lcd.print("Smart Sensor");
yield();
delay(3000);
lcd.clear();
lcd.print("Initializing...");
lcd.print("Please wait");
//WiFi.begin(ssid, password);
Serial.println("Connecting");
while(WiFi.status() != WL_CONNECTED) {
Serial.print(".");
Serial.println("");
Serial.print("Connected to WiFi network with IP Address: ");
lcd.clear();
lcd.print("WiFi Connected!");
lcd.print(WiFi.SSID());
yield();
delay(2000);
lcd.clear();
lcd.print("Dispense Now!");
delay(1000); /// GIVE USER 1 minutes to apply product
lcd.print("30");
lcd.print("29");
lcd.print("28");
lcd.print("27");
lcd.print("26");
lcd.print("25");
lcd.print("24");
lcd.print("23");
lcd.print("22");
lcd.print("21");
lcd.print("20");
lcd.print("19");
lcd.print("18");
lcd.print("17");
lcd.print("16");
lcd.print("15");
lcd.print("14");
lcd.print("13");
lcd.print("12");
lcd.print("11");
lcd.print("10");
lcd.print("09");
lcd.print("08");
lcd.print("07");
lcd.print("06");
lcd.print("05");
lcd.print("04");
lcd.print("03");
lcd.print("02");
lcd.print("01");
yield();
delay(3000); /// GIVE USER 1 minutes to apply product
lcd.clear();
lcd.print("Scale initiating");
lcd.print("Place bottle Now");
yield();
delay(3000);
//My WEMOS D1 starts to restart from HERE when, please guide me
scale.set_scale(895.640);
scale.tare();
Serial.print("read: \t\t");
Serial.println(scale.read());
Serial.print("get value: \t\t");
Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight, set with tare()
float i = scale.get_units(5);
if (i < 1)
i = 0.00;
lcd.clear();
lcd.print("SB Smart Sensor");
lcd.print("Vol = ");
lcd.print(i,1);
lcd.print(" g");
//Check WiFi connection status
if(WiFi.status()== WL_CONNECTED){
WiFiClient client;
HTTPClient http;
// Your Domain name with URL path or IP address with path
http.begin(client, serverName);
// Specify content-type header
http.addHeader("Content-Type", "application/x-www-form-urlencoded");
// Prepare your HTTP POST request data
float i = 123.00; //i have to hardcode the parameter here to test the DB writing
String httpRequestData = "api_key=" + apiKeyValue + "&deviceid=" + deviceID + "&volume=" + i;
String httpRequestData = "api_key=" + apiKeyValue + "&sensor=" + sensorName
+ "&location=" + sensorLocation + "&value1=" + String(bme.readTemperature())
+ "&value2=" + String(bme.readHumidity()) + "&value3=" + String(bme.readPressure()/100.0F) + "";
Serial.print("httpRequestData: ");
Serial.println(httpRequestData);
// You can comment the httpRequestData variable above
// then, use the httpRequestData variable below (for testing purposes without the BME280 sensor)
//String httpRequestData = "api_key=tPmAT5Ab3j7F9&sensor=BME280&location=Office&value1=24.75&value2=49.54&value3=1005.14";
// Send HTTP POST request
int httpResponseCode = http.POST(httpRequestData);
// If you need an HTTP request with a content type: text/plain
//http.addHeader("Content-Type", "text/plain");
//int httpResponseCode = http.POST("Hello, World!");
// If you need an HTTP request with a content type: application/json, use the following:
//http.addHeader("Content-Type", "application/json");
//int httpResponseCode = http.POST("{\"value1\":\"19\",\"value2\":\"67\",\"value3\":\"78\"}");
if (httpResponseCode>0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
lcd.clear();
lcd.print("Data Upload:");
if (httpResponseCode = 200)
lcd.print("Completed! :)");
yield();
delay(10000);
lcd.clear();
lcd.print("Switching Off");
lcd.print("Good Bye!");
yield();
delay(2000);
lcd.clear();
lcd.print("Please Power Off");
lcd.print("& Well Done!");
else {
lcd.print(httpResponseCode);
else {
Serial.print("Error code: ");
// Free resources
http.end();
else {
Serial.println("WiFi Disconnected");
//Send an HTTP POST request every 5 minutes
yield();
delay(500000);
The error appeared in Serial screen was:
ets Jan 8 2013,rst cause:1, boot mode:(3,6)
load 0x4010f000, len 3424, room 16
tail 0
chksum 0x2e
load 0x3fff20b8, len 40, room 8
tail 0
chksum 0x2b
csum 0x2b
v0005a310
~ld
And i tried to install the decoder, but upon adding the .jar file into Arduino/tools folder and rebooting the IDE and compiled the code, the decoder doesn't appear in Tools menu
I'm using MacOS M1
