ESP32-WROOM-32 has a compiler error, exit status 1
FQBN: esp32:esp32:esp32
Using board 'esp32' from platform in folder: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5
Using core 'esp32' from platform in folder: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5
cmd /c if exist "C:\\Users\\Zed\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\\sketch_oct13a\\partitions.csv" COPY /y "C:\\Users\\Zed\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\\sketch_oct13a\\partitions.csv" "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\partitions.csv"
cmd /c if not exist "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\partitions.csv" if exist "C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\variants\\esp32\\partitions.csv" "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\partitions.csv"
cmd /c if not exist "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\partitions.csv" COPY "C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\tools\\partitions\\default.csv" "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\Zed\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\\sketch_oct13a\\bootloader.bin" ( COPY /y "C:\\Users\\Zed\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\\sketch_oct13a\\bootloader.bin" "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\sketch_oct13a.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\variants\\esp32\\bootloader.bin" "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\sketch_oct13a.ino.bootloader.bin" ) ELSE ( "C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6\\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\sketch_oct13a.ino.bootloader.bin" "C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.6
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\Zed\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\\sketch_oct13a\\build_opt.h" COPY /y "C:\\Users\\Zed\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\\sketch_oct13a\\build_opt.h" "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\build_opt.h"
cmd /c if not exist "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\build_opt.h" type nul > "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\build_opt.h"
cmd /c type nul > "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F/file_opts"
Detecting libraries used...
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\sketch\sketch_oct13a.ino.cpp -o nul
Alternatives for WiFi.h: [WiFi@3.0.5]
ResolveLibrary(WiFi.h)
  -> candidates: [WiFi@3.0.5]
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\sketch\sketch_oct13a.ino.cpp -o nul
Alternatives for Network.h: [Networking@3.0.5]
ResolveLibrary(Network.h)
  -> candidates: [Networking@3.0.5]
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\sketch\sketch_oct13a.ino.cpp -o nul
Alternatives for ESPAsyncWebServer.h: [ESPAsyncWebServer@3.1.0]
ResolveLibrary(ESPAsyncWebServer.h)
  -> candidates: [ESPAsyncWebServer@3.1.0]
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\sketch\sketch_oct13a.ino.cpp -o nul
Alternatives for FS.h: [FS@3.0.5]
ResolveLibrary(FS.h)
  -> candidates: [FS@3.0.5]
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\FS\src @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\sketch\sketch_oct13a.ino.cpp -o nul
Alternatives for AsyncTCP.h: [AsyncTCP@1.1.4]
ResolveLibrary(AsyncTCP.h)
  -> candidates: [AsyncTCP@1.1.4]
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\FS\src -Ic:\Users\Zed\Documents\Arduino\libraries\AsyncTCP\src @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\sketch\sketch_oct13a.ino.cpp -o nul
Alternatives for ESP32Servo.h: [ESP32Servo@3.0.5]
ResolveLibrary(ESP32Servo.h)
  -> candidates: [ESP32Servo@3.0.5]
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\FS\src -Ic:\Users\Zed\Documents\Arduino\libraries\AsyncTCP\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESP32Servo\src @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\sketch\sketch_oct13a.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src\AP.cpp
Using cached library dependencies for file: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src\STA.cpp
Using cached library dependencies for file: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src\WiFi.cpp
Using cached library dependencies for file: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src\WiFiAP.cpp
Using cached library dependencies for file: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src\WiFiGeneric.cpp
Using cached library dependencies for file: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src\WiFiMulti.cpp
Using cached library dependencies for file: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src\WiFiSTA.cpp
Using cached library dependencies for file: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src\WiFiScan.cpp
Using cached library dependencies for file: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src\NetworkClient.cpp
Using cached library dependencies for file: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src\NetworkEvents.cpp
Using cached library dependencies for file: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src\NetworkInterface.cpp
Using cached library dependencies for file: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src\NetworkManager.cpp
Using cached library dependencies for file: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src\NetworkServer.cpp
Using cached library dependencies for file: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src\NetworkUdp.cpp
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\FS\src -Ic:\Users\Zed\Documents\Arduino\libraries\AsyncTCP\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESP32Servo\src @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts c:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src\AsyncEventSource.cpp -o nul
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\FS\src -Ic:\Users\Zed\Documents\Arduino\libraries\AsyncTCP\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESP32Servo\src @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts c:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src\AsyncWebSocket.cpp -o nul
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\FS\src -Ic:\Users\Zed\Documents\Arduino\libraries\AsyncTCP\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESP32Servo\src @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts c:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src\WebAuthentication.cpp -o nul
Using cached library dependencies for file: c:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src\WebHandlers.cpp
Using cached library dependencies for file: c:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src\WebRequest.cpp
Using cached library dependencies for file: c:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src\WebResponses.cpp
Using cached library dependencies for file: c:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src\WebServer.cpp
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\FS\src -Ic:\Users\Zed\Documents\Arduino\libraries\AsyncTCP\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESP32Servo\src @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\FS\src\FS.cpp -o nul
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\FS\src -Ic:\Users\Zed\Documents\Arduino\libraries\AsyncTCP\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESP32Servo\src @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\FS\src\vfs_api.cpp -o nul
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\FS\src -Ic:\Users\Zed\Documents\Arduino\libraries\AsyncTCP\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESP32Servo\src @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts c:\Users\Zed\Documents\Arduino\libraries\AsyncTCP\src\AsyncTCP.cpp -o nul
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\FS\src -Ic:\Users\Zed\Documents\Arduino\libraries\AsyncTCP\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESP32Servo\src @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts c:\Users\Zed\Documents\Arduino\libraries\ESP32Servo\src\ESP32PWM.cpp -o nul
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\FS\src -Ic:\Users\Zed\Documents\Arduino\libraries\AsyncTCP\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESP32Servo\src @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts c:\Users\Zed\Documents\Arduino\libraries\ESP32Servo\src\ESP32Servo.cpp -o nul
Generating function prototypes...
C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/defines -IC:\Users\Zed\AppData\Local\Temp\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\sketch_oct13a -iprefix C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/include/ @C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/flags/includes -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-33fbade6\esp32/qio_qspi/include -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\cores\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\variants\esp32 -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src -IC:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\FS\src -Ic:\Users\Zed\Documents\Arduino\libraries\AsyncTCP\src -Ic:\Users\Zed\Documents\Arduino\libraries\ESP32Servo\src @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/build_opt.h @C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F/file_opts C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\sketch\sketch_oct13a.ino.cpp -o C:\Users\Zed\AppData\Local\Temp\3771092770\sketch_merged.cpp
C:\Users\Zed\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Zed\AppData\Local\Temp\3771092770\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/flags/defines" "-IC:\\Users\\Zed\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\\sketch_oct13a" -iprefix "C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/include/" "@C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/flags/includes" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/qio_qspi/include" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\cores\\esp32" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\variants\\esp32" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries\\WiFi\\src" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries\\Network\\src" "-Ic:\\Users\\Zed\\Documents\\Arduino\\libraries\\ESPAsyncWebServer\\src" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries\\FS\\src" "-Ic:\\Users\\Zed\\Documents\\Arduino\\libraries\\AsyncTCP\\src" "-Ic:\\Users\\Zed\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "@C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F/build_opt.h" "@C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F/file_opts" "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\sketch\\sketch_oct13a.ino.cpp" -o "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\sketch\\sketch_oct13a.ino.cpp.o"
Compiling libraries...
Compiling library "WiFi"
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\WiFi\WiFiMulti.cpp.o
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\WiFi\AP.cpp.o
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\WiFi\WiFi.cpp.o
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\WiFi\WiFiSTA.cpp.o
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\WiFi\WiFiGeneric.cpp.o
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\WiFi\WiFiAP.cpp.o
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\WiFi\STA.cpp.o
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\WiFi\WiFiScan.cpp.o
Compiling library "Networking"
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\Network\NetworkServer.cpp.o
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\Network\NetworkEvents.cpp.o
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\Network\NetworkClient.cpp.o
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\Network\NetworkUdp.cpp.o
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\Network\NetworkInterface.cpp.o
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\Network\NetworkManager.cpp.o
Compiling library "ESPAsyncWebServer"
"C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/flags/defines" "-IC:\\Users\\Zed\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\\sketch_oct13a" -iprefix "C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/include/" "@C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/flags/includes" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/qio_qspi/include" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\cores\\esp32" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\variants\\esp32" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries\\WiFi\\src" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries\\Network\\src" "-Ic:\\Users\\Zed\\Documents\\Arduino\\libraries\\ESPAsyncWebServer\\src" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries\\FS\\src" "-Ic:\\Users\\Zed\\Documents\\Arduino\\libraries\\AsyncTCP\\src" "-Ic:\\Users\\Zed\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "@C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F/build_opt.h" "@C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F/file_opts" "c:\\Users\\Zed\\Documents\\Arduino\\libraries\\ESPAsyncWebServer\\src\\AsyncEventSource.cpp" -o "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\libraries\\ESPAsyncWebServer\\AsyncEventSource.cpp.o"
"C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/flags/defines" "-IC:\\Users\\Zed\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\\sketch_oct13a" -iprefix "C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/include/" "@C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/flags/includes" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/qio_qspi/include" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\cores\\esp32" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\variants\\esp32" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries\\WiFi\\src" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries\\Network\\src" "-Ic:\\Users\\Zed\\Documents\\Arduino\\libraries\\ESPAsyncWebServer\\src" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries\\FS\\src" "-Ic:\\Users\\Zed\\Documents\\Arduino\\libraries\\AsyncTCP\\src" "-Ic:\\Users\\Zed\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "@C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F/build_opt.h" "@C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F/file_opts" "c:\\Users\\Zed\\Documents\\Arduino\\libraries\\ESPAsyncWebServer\\src\\AsyncWebSocket.cpp" -o "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\libraries\\ESPAsyncWebServer\\AsyncWebSocket.cpp.o"
"C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/flags/cpp_flags" -Wall -Wextra -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/flags/defines" "-IC:\\Users\\Zed\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024913-21576-1o01ro5.ea7d\\sketch_oct13a" -iprefix "C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/include/" "@C:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/flags/includes" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-33fbade6\\esp32/qio_qspi/include" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\cores\\esp32" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\variants\\esp32" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries\\WiFi\\src" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries\\Network\\src" "-Ic:\\Users\\Zed\\Documents\\Arduino\\libraries\\ESPAsyncWebServer\\src" "-IC:\\Users\\Zed\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries\\FS\\src" "-Ic:\\Users\\Zed\\Documents\\Arduino\\libraries\\AsyncTCP\\src" "-Ic:\\Users\\Zed\\Documents\\Arduino\\libraries\\ESP32Servo\\src" "@C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F/build_opt.h" "@C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F/file_opts" "c:\\Users\\Zed\\Documents\\Arduino\\libraries\\ESPAsyncWebServer\\src\\WebAuthentication.cpp" -o "C:\\Users\\Zed\\AppData\\Local\\Temp\\arduino\\sketches\\64D85D37038F9B6553E5FE847141B04F\\libraries\\ESPAsyncWebServer\\WebAuthentication.cpp.o"
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\ESPAsyncWebServer\WebRequest.cpp.o
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\ESPAsyncWebServer\WebHandlers.cpp.o
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\ESPAsyncWebServer\WebResponses.cpp.o
Using previously compiled file: C:\Users\Zed\AppData\Local\Temp\arduino\sketches\64D85D37038F9B6553E5FE847141B04F\libraries\ESPAsyncWebServer\WebServer.cpp.o
c:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src\WebAuthentication.cpp: In function 'bool getMD5(uint8_t*, uint16_t, char*)':
c:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src\WebAuthentication.cpp:74:3: error: 'mbedtls_md5_starts_ret' was not declared in this scope; did you mean 'mbedtls_md5_starts'?
   74 |   mbedtls_md5_starts_ret(&_ctx);
      |   mbedtls_md5_starts
c:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src\WebAuthentication.cpp:75:3: error: 'mbedtls_md5_update_ret' was not declared in this scope; did you mean 'mbedtls_md5_update'?
   75 |   mbedtls_md5_update_ret(&_ctx, data, len);
      |   mbedtls_md5_update
c:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src\WebAuthentication.cpp:76:3: error: 'mbedtls_md5_finish_ret' was not declared in this scope; did you mean 'mbedtls_md5_finish'?
   76 |   mbedtls_md5_finish_ret(&_ctx, _buf);
      |   mbedtls_md5_finish
c:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src\AsyncEventSource.cpp: In member function 'void AsyncEventSourceClient::_queueMessage(AsyncEventSourceMessage*)':
c:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src\AsyncEventSource.cpp:189:7: error: 'ets_printf' was not declared in this scope; did you mean 'vswprintf'?
  189 |       ets_printf("ERROR: Too many messages queued\n");
      |       vswprintf
c:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src\AsyncWebSocket.cpp: In member function 'void AsyncWebSocketClient::_queueMessage(AsyncWebSocketMessage*)':
c:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer\src\AsyncWebSocket.cpp:549:7: error: 'ets_printf' was not declared in this scope; did you mean 'vswprintf'?
  549 |       ets_printf("ERROR: Too many messages queued\n");
      |       vswprintf
Using library WiFi at version 3.0.5 in folder: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\WiFi
Using library Networking at version 3.0.5 in folder: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\Network
Using library ESPAsyncWebServer at version 3.1.0 in folder: C:\Users\Zed\Documents\Arduino\libraries\ESPAsyncWebServer
Using library FS at version 3.0.5 in folder: C:\Users\Zed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\FS
Using library AsyncTCP at version 1.1.4 in folder: C:\Users\Zed\Documents\Arduino\libraries\AsyncTCP
Using library ESP32Servo at version 3.0.5 in folder: C:\Users\Zed\Documents\Arduino\libraries\ESP32Servo
exit status 1
Compilation error: exit status 1
Hi @zadkiel_01,
welcome to the arduino-forum.
Well done posting the error-messages as code-section in your fist posting.
From this line
I can see that you are using the ESP32-core 3.0.5
espressif made breaking changes in the core-files when moving on from core-versions 2.X to 3.X
The compiler-error might be related to this.
You could try and install the ESP32-core-version 2.0.17 and try to compile again.
You should provide more information:
what exaxt type of ESP32-board are you using?
Remove WiFi-credenatials then post your complete sketch.
Hi Stefan! Thanks for replying.
The ESP32 I'm using is an ESP32-WROOM-32 (Sorry if the pic is bad)
Ok it is a "real" ESP32-board (not an arduino-nano-"ESP32"-board)
Take a look at
Thanks Stefan! I'll try this and get back with an update
these seem to be the acutal errors
and here are some pages discussing mbedtls_md5_starts_ret errors
Hey, I'm back. So after downgrading the ESP32 I used in the IDE to 2.0.17, it compiled properly
What board did you choose? FQBN looks quite short compared to mine. Is your target "ESP32 Dev Module"?
The function you are missing are hardware-specific (i.e. different on every esp32 model). Probably you are getting these errors because of wrong target
