Espnow two way communication error
hi, I'm using ESPNOW two way communication between two esp32s to control a robot with a remote . There are three stepper motors, 1 servo and 1 dc motor, 1 fsr on the robot (one dc motor at the remote, the speed of which is controlled by the fsr at the robot). Everything is working fine except the fsr, dc motor at the remote and the servo motor. below are the codes for robot and remote;
Remote:
#include <esp_now.h>
#include <WiFi.h>
#include <ESP32MX1508.h>
#define open_pin 12
//FEEDBACK MOTOR
#define ROTA 4
#define ROTB 15
#define CH1 0
#define CH2 1
#define RES 12
MX1508 motorA(ROTA, ROTB, CH1, CH2, RES); //object for yrot motor
int motorSpeedMin = 0;
int motorSpeedMax = 4095;
// Define FSR threshold and motor speed limits
const int fsrThreshold = 20000;  // Adjust thresho
int fsrVal = 0;
//// Yrotation button pins
#define CW_BUTTON_PIN  25
#define ACW_BUTTON_PIN  26
//joystick pins
#define x  32
#define y  33
#define z 34
//#define y2 35
//STATES
#define FWD     2
#define REV     1
#define STOP    0
#define OPEN    0
#define CLOSE   1
#define CW      1
#define ACW     2
byte xState = 0;
byte yState = 0;
byte zState = 0;
byte jawState = 0;
byte rotState = 0;
byte lastxState = 0;
byte lastyState = 0;
byte lastzState = 0;
byte lastjawState = 0;
byte lastrotState = 0;
bool move = false;
#define dead_pos 700
#define dead_neg -700
int map_x = 0;
int map_y = 0;
int map_z = 0;
int map_y2 = 0;
int val_jaw = 0;
int val_cw = 0;
int val_acw = 0;
// REPLACE WITH YOUR RECEIVER MAC Address
uint8_t broadcastAddress[] = {0xC0, 0x49, 0xEF, 0xD0, 0xDB, 0xB8};
// Structure example to send data
// Must match the receiver structure
typedef struct struct_message {
  byte xData = STOP;
  byte yData = STOP;
  byte zData = STOP;
  bool jaw = CLOSE;
  byte rot = STOP;
  int fsr;
} struct_message;
struct_message xTX;
struct_message xRX;
esp_now_peer_info_t peerInfo;
  // callback when data is sent
  void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  Serial.print("\r\nLast Packet Send Status:\t");
  Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
  // Init Serial Monitor
  pinMode(open_pin, INPUT_PULLUP);
    pinMode(CW_BUTTON_PIN, INPUT_PULLUP);
    pinMode(ACW_BUTTON_PIN, INPUT_PULLUP);
 motorA.motorBrake();
  // Set device as a Wi-Fi Station
  WiFi.mode(WIFI_STA);
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  // Once ESPNow is successfully Init, we will register for Send CB to
  // get the status of Trasnmitted packet
  //esp_now_register_send_cb(OnDataSent);
  // Register peer
  memcpy(peerInfo.peer_addr, broadcastAddress, 6);
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  // Add peer
  if (esp_now_add_peer(&peerInfo) != ESP_OK) {
    Serial.println("Failed to add peer");
    return;
   esp_now_register_recv_cb(OnDataRecv);
void OnDataRecv(const uint8_t *mac_addr, const uint8_t *data, int data_len) {
  memcpy(&xRX, data, sizeof(xRX));
  fsrVal = xRX.fsr;
// Map FSR value to motor speed
  int motorSpeed = map(fsrVal, fsrThreshold, 32767, motorSpeedMin, motorSpeedMax);
  // Limit motor speed within the defined range
  motorSpeed = constrain(motorSpeed, motorSpeedMin, motorSpeedMax);
  // Set motor speed
  motorA.motorGo(motorSpeed);
//state change for x link
void change_x() {
  if (map_x < dead_neg || map_x > dead_pos) {
    if (map_x > dead_pos) {
      xState = FWD;
    } else if (map_x < dead_neg) {
      xState = REV;
  else {
    xState = STOP;
  return;
//state change for y link
void change_y() {
  if (map_y < dead_neg || map_y > dead_pos) {
    if (map_y > dead_pos) {
      yState = FWD;
    } else if (map_y < dead_neg) {
      yState = REV;
  else {
    yState = STOP;
  return;
//state change for z link
void change_z() {
  if (map_z < dead_neg || map_z > dead_pos) {
    if (map_z > dead_pos) {
      zState = FWD;
    } else if (map_z < dead_neg) {
      zState = REV;
  else {
    zState = STOP;
  return;
//state change for jaw
void change_jaw() {
  if (val_jaw == LOW ) {
    jawState = OPEN;
  else {
    jawState = CLOSE;
  //return;
//state change for ROTATION
void change_rot() {
  if (val_cw == LOW and val_acw == HIGH ) {
    rotState = CW;
  else if (val_cw == HIGH and val_acw == LOW ){
    rotState = ACW;
 else {
  rotState = STOP;
  //return;
// preparing and sending data
void cast() {
  if (xState != lastxState || yState != lastyState || zState != lastzState || jawState != lastjawState || rotState != lastrotState) {            //This makes the async xTX data flow
    xTX.xData = xState;
    xTX.yData = yState;
    xTX.zData = zState;
    xTX.jaw = jawState;
     xTX.rot = rotState;//Cast the changed state to the xTX callback
    //sending
    esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &xTX, sizeof(xTX));
    // getting feedback message
    //feedback();
    if (result == ESP_OK) {
      char x_buf[20];
      char y_buf[20];
      char z_buf[20];
      char j_buf[20];
      char r_buf[20];
      String sx, sy, sz, sj, sr = "";
      if (xState == FWD) {
        sx = "X_REV";
      } else if (xState == REV) {
        sx = "X_FWD";
      } else if (xState == STOP) {
        sx = "X_STOP";
      if (yState == FWD) {
        sy = "Y_REV";
      } else if (yState == REV) {
        sy = "Y_FWD";
      } else if (yState == STOP) {
        sy = "Y_STOP";
      if (zState == FWD) {
        sz = "Z_REV";
      } else if (zState == REV) {
        sz = "Z_FWD";
      } else if (zState == STOP) {
        sz = "Z_STOP";
      if (jawState == OPEN) {
        sj = "OPEN";
      } else if (jawState == CLOSE) {
        sj = "CLOSED";
      if (rotState == CW) {
        sr = "CW";
      } else if (rotState == ACW) {
        sr = "ACW";
      } else if (rotState == STOP) {
        sr = "NO ROT";
      sprintf(x_buf, "Sending %s", sx);
      sprintf(y_buf, "Sending %s", sy);
      sprintf(z_buf, "Sending %s", sz);
      sprintf(j_buf, "Sending %s", sj);
       sprintf(r_buf, "Sending %s", sr);
      Serial.println(x_buf);
      Serial.println(y_buf);
      Serial.println(z_buf);
      Serial.println(j_buf);
      Serial.println(r_buf);//Only prints when packet is sent
      Serial.println("Failed to send data over ESP-NOW");
  //reading values
  val_jaw = digitalRead(open_pin);
   val_cw = digitalRead(CW_BUTTON_PIN);
   val_acw = digitalRead(ACW_BUTTON_PIN);
  int val_x = analogRead(x);
  int val_y = analogRead(y);
  int val_z = analogRead(z);
  //int val_y2 = analogRead(y2);
  //mapping
  map_x = map(val_x, 0, 4095, -1000, 1000);
  map_y = map(val_y, 0, 4095, -1000, 1000);
  map_z = map(val_z, 0, 4095, -1000, 1000);
  //map_y2 = map(val_y2, 0, 4095, -1000, 1000);
  // observing state change
  change_x();
  change_y();
  change_z();
  change_jaw();
  change_rot();
  //casting, sending and getting feedback
  cast();
  lastxState = xState;
  lastyState = yState;
  lastzState = zState;
  lastjawState = jawState;
  lastrotState = rotState;
Robot:
#include "AccelStepper.h"
#include <ESP32Servo.h>
#include <WiFi.h>
#include <Wire.h>
#include <Adafruit_ADS1X15.h>
// Create ADS1115 instance
Adafruit_ADS1115 ads;
//#define open_pin 12
// Yrotation driver pins
#define ROTA 12
#define ROTB 14
#define CH1 0
#define CH2 1
#define RES 12
#define XSTEP   23
#define XDIR    22
#define YSTEP   33
#define YDIR    32
#define ZSTEP   26
#define ZDIR    25
#define DRIVER  1
AccelStepper stepperX(DRIVER, XSTEP, XDIR);
AccelStepper stepperY(DRIVER, YSTEP, YDIR);
AccelStepper stepperZ(DRIVER, ZSTEP, ZDIR);
int servoPin = 5;
Servo myservo;
int fsrValue = 0;
//STATES
#define FWD     2
#define REV     1
#define STOP    0
#define OPEN    0
#define CLOSE   1
#define CW      1
#define ACW     2
uint8_t broadcastAddress[] = {0xEC, 0x62, 0x60, 0x9A, 0x62, 0x60};
byte xData = STOP;
  byte yData = STOP;
  byte zData = STOP;
  bool jaw = CLOSE;
  byte rot = STOP;
  int fsr;
} struct_message;
struct_message xRX;
struct_message xTX;
bool xmove = false;
bool ymove = false;
bool zmove = false;
  if (lastxState != xRX.xData || lastyState != xRX.yData || lastzState != xRX.zData || lastjawState != xRX.jaw || lastrotState != xRX.rot) {
    // moving x
    if (xRX.xData == FWD) {
      stepperX.setSpeed(500);
      xmove = true;
    } else if (xRX.xData == REV) {
      stepperX.setSpeed(-500);
      xmove = true;
    } else if (xRX.xData == STOP) {
      xmove = false;
      stepperX.stop();
    // moving y
    if (xRX.yData == FWD) {
      stepperY.setSpeed(500);
      ymove = true;
    } else if (xRX.yData == REV) {
      stepperY.setSpeed(-500);
      ymove = true;
    } else if (xRX.yData == STOP) {
      ymove = false;
      stepperY.stop();
    //Moving Z
    if (xRX.zData == FWD) {
      stepperZ.setSpeed(500);
      zmove = true;
    } else if (xRX.zData == REV) {
      stepperZ.setSpeed(-500);
      zmove = true;
    } else if (xRX.zData == STOP) {
      zmove = false;
      stepperZ.stop();
    // jaw
    if (xRX.jaw == OPEN) {
      myservo.write(0);
    }else if (xRX.jaw == CLOSE){
      myservo.write(180);
    // rot
    if (xRX.rot == CW) {
      motorA.motorGo(4095);
    } else if (xRX.rot == ACW) {
       motorA.motorRev(4095);
    else if (xRX.rot == STOP){
  lastxState = xRX.xData;
  lastyState = xRX.yData;
  lastzState = xRX.zData;
  lastjawState = xRX.jaw;
  lastrotState = xRX.rot;
  //Serial.begin(115200);
    return;
  myservo.attach(servoPin, 500, 2400);
  stepperX.setMaxSpeed(1000);
  stepperX.setAcceleration(30);
  stepperX.setSpeed(50);
  stepperX.stop();
  stepperY.setMaxSpeed(1000);
  stepperY.setAcceleration(30);
  stepperY.setSpeed(50);
  stepperY.stop();
  stepperZ.setMaxSpeed(1000);
  stepperZ.setAcceleration(30);
  stepperZ.setSpeed(50);
  stepperZ.stop();
  if (xmove) {
    stepperX.runSpeed();
   if (ymove) {
    stepperY.runSpeed();
   if (zmove) {
    stepperZ.runSpeed();
  fsrValue = ads.readADC_SingleEnded(0);
  xTX.fsr = fsrValue;
   //sending
     Serial.println("fsr value sent");
the esp32 at the robot is showing this error:
Include a drawing and a picture of how you are powering the Robot's stepper motors, motor drivers, servos and the ESP32.
Everything is fine, but nothing works.
everything that works includes (3 stepper motors and a dc motor at the robot)
that'll be a complex task. I've powered drivers via 12 V and stepped it down to 5V for esp32 , servo and dc motor. I've made a pcb for it and it works fine as the stepper motors work fine (12v) and the esp32 and dc motor is also working (5V).
Seems the robot is okay.
Because Serial was never begun, first Serial.print will crash the esp..
sorry, good luck.. ~q
Just tried the blink sketch to test it. ESP is fine, thank God
