esptool.FatalError: Timed out waiting for packet header inNode MCU ESP8266
Arduino: 1.8.13 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Executable segment sizes:
ICACHE : 32768 - flash instruction cache
IROM : 426128 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 29829 / 32768 - code in IRAM (IRAM_ATTR, ISRs...)
DATA : 1688 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 7304 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 28752 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 464949 bytes (44%) of program storage space. Maximum is 1044464 bytes.
Global variables use 37744 bytes (46%) of dynamic memory, leaving 44176 bytes for local variables. Maximum is 81920 bytes.
esptool.py v3.0
Serial port COM4
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: c8:c9:a3:64:a1:cd
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Traceback (most recent call last):
File "C:\Users\jaazi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/upload.py", line 66, in
esptool.main(cmdline)
File "C:/Users/jaazi/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 3599, in main
detect_flash_size(esp, args)
File "C:/Users/jaazi/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 2848, in detect_flash_size
flash_id = esp.flash_id()
File "C:/Users/jaazi/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 688, in flash_id
return self.run_spiflash_command(SPIFLASH_RDID, b"", 24)
File "C:/Users/jaazi/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 948, in run_spiflash_command
old_spi_usr = self.read_reg(SPI_USR_REG)
File "C:/Users/jaazi/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 562, in read_reg
val, data = self.command(self.ESP_READ_REG, struct.pack('<I', addr))
File "C:/Users/jaazi/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 386, in command
p = self.read()
File "C:/Users/jaazi/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 331, in read
return next(self._slip_reader)
File "C:/Users/jaazi/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 2636, in slip_reader
raise FatalError("Timed out waiting for packet %s" % waiting_for)
option enabled in File -> Preferences.
I have an error message like this. Is anyone can able to help me....plz. Because it's very urgent. Thank you.
