Hello all
I am running a script at start up from /etc/rc.local that is supposed to call another script that resides at a /home directory that I created and I can see rc.local runs because I log to a text file but the script that it calls does not execute.
I changed the attributes of the sub-script
by executing
chmod a+x /etc/rc.local
and
chmod a+x runpython.sh
but it does not execute.
Do I have to set up something else?
Any help is greatly appreciated!
Here is the code inside /etc/rc.local
# Put your custom commands here that should be executed once
# the system init finished. By default this file does nothing.
wifi-live-or-reset
boot-complete-notify
# Uncomment the following line in order to reset the microntroller
# right after linux becomes ready
#reset-mcu
# Uncomment the following line in order to disable kernel console
# debug messages, thus having a silent and clean serial communication
# with the microcontroller
echo 0 > /proc/sys/kernel/printk
echo Starting runpython>/tmp/showtrol.log
cd /home
runpython.sh
exit 0
and here is the code inside runpython.sh:
echo Running Python server...
echo Starting script kronos.py at >>/tmp/showtrol.log
date>>/tmp/showtrol.log
cd /home
python sc.py
But If I check the showtrol.log file only the text written by the rc.local script is there and not the one written by runpython.sh
THANK YOU
Rod Magnus
