The command "ether.begin(sizeof Ethernet::buffer,mymac,8)" fails for me but i was able to access the server created but very slowly it takes about two minutes to connect,but my internet connection is fast.I am using enc28j60 as ethernet controller(ethercard library) with arduino uno.Is there any issue in my code,but how am i able to access it and what does the command mean actually.
#include <EtherCard.h>
#define STATIC 0 // set to 1 to disable DHCP
// mac address
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
// ethernet interface ip address
static byte myip[] = { 172,26,40,250 };
// gateway ip address
static byte gwip[] = { 172,26,40,1 };
// LED to control output
int ledPin10 = 10;
byte Ethernet::buffer[700];
const char page[] PROGMEM =
"HTTP/1.0 503 Service Unavailable\r\n"
"Content-Type: text/html\r\n"
"Retry-After: 600\r\n"
"\r\n"
"<html>"
/* "<head><title>"
"Service Temporarily Unavailable"
"</title></head>" */
"<body>"
"<h3>This service is currently unavailable</h3>"
/* "<p><em>"
"The main server is currently off-line.
"Please try again later."
"</em></p>" */
"</body>"
"</html>"
void setup () {
pinMode(ledPin10, OUTPUT);
Serial.println("Trying to get an IP...");
Serial.print("MAC: ");
for (byte i = 0; i < 6; ++i) {
Serial.print(mymac[i], HEX);
if (i < 5)
Serial.print(':');
if (ether.begin(sizeof Ethernet::buffer,mymac,8) == 0)
Serial.println( "Failed to access Ethernet controller");
Serial.println("\nEthernet Controller Initialized");
#if STATIC
Serial.println( "Getting static IP.");
if (!ether.staticSetup(myip, gwip)){
Serial.println( "could not get a static IP");
// blinkLed(); // blink forever to indicate a problem
#else
Serial.println("Setting up DHCP");
if (!ether.dhcpSetup()){
Serial.println( "DHCP failed");
#endif
ether.printIp("My IP: ", ether.myip);
ether.printIp("GW IP: ", ether.gwip);
ether.printIp("DNS IP: ", ether.dnsip);
void loop () {
word len = ether.packetReceive();
word pos = ether.packetLoop(len);
// IF LED10=ON turn it ON
if(strstr((char *)Ethernet::buffer + pos, "GET /?LED10=ON") != 0) {
Serial.println("Received ON command");
digitalWrite(ledPin10, HIGH);
// IF LED10=OFF turn it OFF
if(strstr((char *)Ethernet::buffer + pos, "GET /?LED10=OFF") != 0) {
Serial.println("Received OFF command");
digitalWrite(ledPin10, LOW);
// show some data to the user
memcpy_P(ether.tcpOffset(), page, sizeof page);
ether.httpServerReply(sizeof page - 1);
