Ok so here I was trying to compile Ethernet 2.0.0 selecting chip esp8266 "Adafruit feather HUZZAH" . But I am getting errors.
It fails to Compile. I am trying to compile basic example provided "LinkStatus".
Below is the error.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\libraries\Ethernet\src\Ethernet.cpp: In static member function 'static void EthernetClass::begin(uint8_t*, IPAddress, IPAddress, IPAddress, IPAddress)':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\libraries\Ethernet\src\Ethernet.cpp:87:24: error: 'class IPAddress' has no member named '_address'
W5100.setIPAddress(ip._address.bytes);
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\libraries\Ethernet\src\Ethernet.cpp:88:29: error: 'class IPAddress' has no member named '_address'
W5100.setGatewayIp(gateway._address.bytes);
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\libraries\Ethernet\src\Ethernet.cpp:89:29: error: 'class IPAddress' has no member named '_address'
W5100.setSubnetMask(subnet._address.bytes);
delete the Ethernet library bundled with esp8266 Arduino core.
I tried this, and that's when I got the error @I_think reported. The problem is the ESP8266 Core for Arduino platform's IPAddress class does not have the _address member used by the Ethernet 2.0.0 library:
I don't have time to actually wire up an Ethernet module to an ESP8266 board right now, but the sketch does compile when using the Ethernet library at the tip of the master branch. I know Paul Stoffregen did testing of the Ethernet library with ESP8266 for the 2.0.0 release, so I think it has a good chance of working.
@I_think if you want to give the beta testing version of the Ethernet library a try, do this:
