Ethernet_Manager_Portenta_H7 library
How To Install Using Arduino Library Manager
Features
This is the new library, adding to the current WiFiManager sets of libraries. It's designed to help you eliminate
hardcodingyour Credentials in Portenta_H7 boards using Ethernet from Portenta Vision shields. It's currently not supporting SSL. Will support soon. -
You can update Credentials any time you need to change via Configure Portal. Data are saved in configurable locations in Portenta_H7 LittleFS.
DoubleDetectDetector feature to force Config Portal when double reset is detected within predetermined time, default 10s.
Configurable Config Portal Title to be either BoardName or default undistinguishable names.
Examples are redesigned to separate Credentials / Defines / Dynamic Params / Code so that you can change Credentials / Dynamic Params quickly for each device
The Portenta_H7 boards, are currently supported using ArduinoCore-mbed mbed_portenta core.
New recent features:
- DoubleDetectDetector feature to force Config Portal when double reset is detected within predetermined time, default 10s.
- Configurable Config Portal Title to be either BoardName or default undistinguishable names.
- Examples are redesigned to separate Credentials / Defines / Dynamic Params / Code so that you can change Credentials / Dynamic Params quickly for each device
Currently Supported Boards
This Ethernet_Manager_Portenta_H7 library currently supports these following boards:
- Portenta_H7 boards, using
Currently supported Ethernet shields/modules
- Portenta_H7 using Ethernet from Portenta Vision shields
Changelog
Initial Release v1.6.0
- Add support to Portenta_H7 boards, using
ArduinoCore-mbed mbed_portenta core - Add
Packages' Patches - Add
LibraryPatchesfor Adafruit_MQTT_Library to fix compiler error for Portenta_H7 and many other boards. - Bump version to v1.6.0 to sync with Ethernet_Manager library
Examples
Debug Terminal Output Samples
1. Portenta_H7_WiFi_MQTT on Portenta_H7
This is the terminal output when running MQTT_Ethernet_Portenta_H7 example on Portenta_H7:
1.1 Initial start, LittleFS format and Config Portal
Start MQTT_Ethernet_Portenta_H7 on PORTENTA_H7_M7
Ethernet Shield type : Ethernet using Portenta_Ethernet Library
EthernetManager_Portenta_H7 v1.6.0
DoubleResetDetector_Generic v1.7.2
Flash Size: (KB) = 2048.00
FlashIAP Start Address: = 0x8080000
LittleFS size (KB) = 1536.00
LittleFS Mount OK
LittleFS Flag read = 0xd0d01234
doubleResetDetected
Saving to DRD file : 0xd0d04321
Saving DRD file OK
LittleFS Flag read = 0xd0d04321
ClearFlag write = 0xd0d04321
[ETM] =====================
[ETM] DRD. Run ConfigPortal
[ETM] CCSum=0x 8e7 ,RCSum=0x 8e7
[ETM] CrCCsum=0x 19fa ,CrRCsum=0x 19fa
[ETM] Valid Stored Dynamic Data
[ETM] ======= Start Stored Config Data =======
[ETM] Header= PORTENTA-H7-ETH , BoardName= Portenta-MQTT
[ETM] StaticIP=
[ETM] Start connectEthernet using DHCP
[ETM] MAC:FE-98-FB-D7-D5-BA
[ETM] IP: 192.168.2.132
[ETM] bg: isForcedConfigPortal = false
[ETM] bg:Stay forever in CP: DRD/MRD
[ETM] clearForcedCP
[ETM] SaveCPFile
[ETM] OK
[ETM] CfgIP= 192.168.2.132
Connected! IP address: 192.168.2.132
H
Your stored Credentials :
AIO_SERVER = io.adafruit.com
AIO_SERVERPORT = 1883
AIO_USERNAME = private
AIO_KEY = private
AIO_PUB_TOPIC = /feeds/Temperature
AIO_SUB_TOPIC = /feeds/LED_Control
HHHHHHHHH HHHHHHHHHH HH
1.2 Save and Exit Config Portal
[ETM] CCSum=0x adb ,RCSum=0x adb
[ETM] CrCCsum=0x 2236 ,CrRCsum=0x 2236
[ETM] Header= PORTENTA-H7-ETH , BoardName= PORTENTA-H7-ETH
[ETM] StaticIP= 192.168.2.222
[ETM] Start connectEthernet using Static IP = 192.168.2.222
[ETM] MAC:FE-9E-FF-D6-DA-BA
[ETM] IP: 192.168.2.222
[ETM] begin:Ethernet Connected.
Connected! IP address: 192.168.2.222
H
AIO_USERNAME = user_name
AIO_KEY = aio_key
Creating new Ethernet client object OK
Creating new MQTT object OK
AIO_SERVER = io.adafruit.com, AIO_SERVERPORT = 1883
AIO_USERNAME = user_name, AIO_KEY = aio_key
Creating new MQTT_Pub_Topic, Temperature = user_name/feeds/Temperature
Creating new Temperature object OK
Temperature MQTT_Pub_Topic = user_name/feeds/Temperature
Creating new AIO_SUB_TOPIC, LED_Control = user_name/feeds/LED_Control
Creating new LED_Control object OK
LED_Control AIO_SUB_TOPIC = user_name/feeds/LED_Control
THTHTHT
