Ethernet sACN and Fastled
Hello! I need some help combining Ethernet.h, sACN.h and Fastled.h
Im using an Arduino Uno with an Unofficial ethernet shield.
I have a ledstrip (WS2812B) connected to pin 4. and ground from the board to the strip.
When I try to receive sACN data (dmx) over ethernet, everything works as it should.
when I try to light up some leds, everything works as it should.
But...
When I combine both codes, as soon as I add the leds in void setup, the sacn input is gone.
Something is not going along nicely, but I have no idea what!? please help!
Here is the code:
#include "Ethernet.h"
#include "sACN.h"
#include "FastLED.h"
//Setup Ethernet
uint8_t mac[] = {0x90, 0xA2, 0xDA, 0x10, 0x14, 0x48}; // MAC Adress of your device
IPAddress ip(169, 254, 89, 67); // IP
IPAddress dns(169, 254, 89, 1); // IP
IPAddress gateway(169, 254, 89, 1); // IP
IPAddress subnet(255, 255, 0, 0); //
//Setup sACN
EthernetUDP sacn;
Receiver recv(sacn);
//Setup LEDs
const int DATA_PIN= 4;
const int NUM_LEDS= 5;
CRGB Led[NUM_LEDS];
//Array for input channels
int Channel[36] = {1,2,3,4,5,};
//Array for storing DMX values
int DMX[36];
// Define Colours
#define On 0,127,0
#define Off 127,0,0
  delay(2000);
  Ethernet.begin(mac, ip, dns, gateway, subnet);
  recv.begin(32); //Set Universe Here!
  Serial.println("sACN start");
  FastLED.addLeds<WS2812B, DATA_PIN> (Led, NUM_LEDS);
  FastLED.clear(true);
//Read DMX
  recv.update();
  for (int i=0; i<5; i++){
  DMX[i] = (recv.dmx(Channel[i]));
// Print to serial for visualisation
  Serial.print(i);
  Serial.print("= ");
  Serial.println(DMX[i]);
Did You try the two codes with everything connected or only the hardware needed for the one tested code?
Schematics might be valuable to see. Inadekvat powering is a frequent problem for many members.
Yes, I have everything connected.
Shield right on the Uno, D4 to a breadboard, ground to the breadboard, and external power to the breadboard.
Everything looks happy, until it doesn't.
All is connected and the two codes work separately but not together. Which code are You showing?
What does the Serial.print tell?
It tells nothing useful. Please post schematics.
And what is it?
I use the breadboard to power the strip and connect the arduino to the data line, with a resistor in between.
Only thin I haven't tried is run the code with the strip disconnected (i think).
The serial.print gives only zeros.
The code I shared is with ethernet, sacn and fastled combined.
When I remove the last two lines in the setup, the serial.print displays the dmx value.
Breadboards are generally not designed for powering things.
Analyzing code without knowing the schematics is in order has been a waste of time too many times.
Sorry but no more replies from here.
Your adding words is not requested.
