Ethernet - SD + basic authentication
i know this question has been asked already but there are no answers, at least no answers that really helped me. Maybe i just dont dont understand some thing but i really have a hard time merging two example codes that ive found online. One is a simple basic authentication example and then theres the other one is reading files from an sd card.
I use this code to load a webpage with a htm file, css stylesheet and an image..
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// size of buffer used to capture HTTP requests
#define REQ_BUF_SZ   20
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 1, 178); // IP address, may need to change depending on network
EthernetServer server(80);  // create a server at port 80
File webFile;
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0;              // index into HTTP_req buffer
    // disable Ethernet chip
    pinMode(10, OUTPUT);
    digitalWrite(10, HIGH);
    Serial.begin(9600);       // for debugging
    // initialize SD card
    Serial.println("Initializing SD card...");
    if (!SD.begin(4)) {
        Serial.println("ERROR - SD card initialization failed!");
        return;    // init failed
    Serial.println("SUCCESS - SD card initialized.");
    // check for index.htm file
    if (!SD.exists("index.htm")) {
        Serial.println("ERROR - Can't find index.htm file!");
        return;  // can't find index file
    Serial.println("SUCCESS - Found index.htm file.");
    Ethernet.begin(mac, ip);  // initialize Ethernet device
    server.begin();           // start to listen for clients
    EthernetClient client = server.available();  // try to get client
    if (client) {  // got client?
        boolean currentLineIsBlank = true;
        while (client.connected()) {
            if (client.available()) {   // client data available to read
                char c = client.read(); // read 1 byte (character) from client
                // buffer first part of HTTP request in HTTP_req array (string)
                // leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
                if (req_index < (REQ_BUF_SZ - 1)) {
                    HTTP_req[req_index] = c;          // save HTTP request character
                    req_index++;
                // print HTTP request character to serial monitor
                Serial.print(c);
                // last line of client request is blank and ends with \n
                // respond to client only after last line received
                if (c == '\n' && currentLineIsBlank) {
                    // open requested web page file
                    if (StrContains(HTTP_req, "GET / ")
                                 || StrContains(HTTP_req, "GET /index.htm")) {
                        client.println(F("HTTP/1.1 200 OK"));
                        client.println(F("Content-Type: text/html"));
                        client.println(F("Connnection: close"));
                        client.println();
                        webFile = SD.open("index.htm");        // open web page file
                    else if (StrContains(HTTP_req, "GET /style.css")) {
                        client.println();
                        webFile = SD.open("style.css");        // open web page file
                    else if (StrContains(HTTP_req, "GET /temp128.png")) {
                        webFile = SD.open("temp128.png");
                        if (webFile) {
                            client.println();
                    if (webFile) {
                        while(webFile.available()) {
                            client.write(webFile.read()); // send web page to client
                        webFile.close();
                    // reset buffer index and all buffer elements to 0
                    req_index = 0;
                    StrClear(HTTP_req, REQ_BUF_SZ);
                // every line of text received from the client ends with \r\n
                if (c == '\n') {
                    // last character on line of received text
                    // starting new line with next character read
                else if (c != '\r') {
                    // a text character was received from client
                    currentLineIsBlank = false;
            } // end if (client.available())
        } // end while (client.connected())
        delay(1);      // give the web browser time to receive the data
        client.stop(); // close the connection
    } // end if (client)
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
    for (int i = 0; i < length; i++) {
        str[i] = 0;
// searches for the string sfind in the string str
// returns 1 if string found
// returns 0 if string not found
char StrContains(char *str, char *sfind)
    char found = 0;
    char index = 0;
    char len;
    len = strlen(str);
    if (strlen(sfind) > len) {
        return 0;
    while (index < len) {
        if (str[index] == sfind[found]) {
            found++;
            if (strlen(sfind) == found) {
                return 1;
        else {
            found = 0;
        index++;
    return 0;
now i would really love to use basic authentication from this example.
#include <SPI.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
IPAddress ip(192,168,2, 111);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection and the server:
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
void SendOKpage(EthernetClient &client)
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connnection: close");
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
                    // add a meta refresh tag, so the browser pulls again every 5 seconds:
          client.println("<meta http-equiv=\"refresh\" content=\"5\">");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("
          client.println("</html>");
void SendAuthentificationpage(EthernetClient &client)
          client.println("HTTP/1.1 401 Authorization Required");
          client.println("WWW-Authenticate: Basic realm=\"Secure Area\"");
          client.println();
          client.println("<HTML>  <HEAD>   <TITLE>Error</TITLE>");
          client.println(" </HEAD> <BODY><H1>401 Unauthorized.</H1></BODY> </HTML>");
char linebuf[80];
int charcount=0;
boolean authentificated=false;
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    memset(linebuf,0,sizeof(linebuf));
    charcount=0;
    // an http request ends with a blank line
        linebuf[charcount]=c;
        if (charcount<sizeof(linebuf)-1) charcount++;
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
          if (authentificated)
            SendOKpage(client);
            SendAuthentificationpage(client);
        if (c == '\n') {
          // you're starting a new line
          if (strstr(linebuf,"Authorization: Basic")>0 && strstr(linebuf,"c2F0YXJ1bjpwYXNzd29yZA==")>0)
            authentificated=true;
          charcount=0;
          // you've gotten a character on the current line
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
ive been trying for 3 days now haha :slight_smile:
i just need some guidance to get botch codes working together.
Thank you in advance
anyone? please? :-[
its been 4 days, and its driving me nuts.. i just need a hint or something, ive tried like everything, or so i think, and nothing works.. ill probably kill the arduino with writing cycles before i get it :stuck_out_tongue:
