HI!
Can any one help me with basic Authentication for my SD webserver? I just cant find enough information on this or tutorials on it.
Any ways my code is.
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
#include <RemoteTransmitter.h>
// size of buffer used to capture HTTP requests
#define REQ_BUF_SZ 60
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 1, 200); // IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
File webFile; // the web page file on the SD card
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0; // index into HTTP_req buffer
boolean LED_state[3] = {0}; // stores the states of the LEDs
ActionTransmitter actionTransmitter(9);
// Everything resets to Off if arduino is reseted
actionTransmitter.sendSignal(1,'A',false);
actionTransmitter.sendSignal(1,'B',false);
actionTransmitter.sendSignal(1,'C',false);
// disable Ethernet chip
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
Serial.begin(9600); // for debugging
// initialize SD card
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
// check for index.htm file
if (!SD.exists("index.htm")) {
Serial.println("ERROR - Can't find index.htm file!");
return; // can't find index file
Serial.println("SUCCESS - Found index.htm file.");
// switches on pins
/*pinMode(2, INPUT);
pinMode(9, OUTPUT);*/
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// limit the size of the stored received HTTP request
// buffer first part of HTTP request in HTTP_req array (string)
// leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
if (req_index < (REQ_BUF_SZ - 1)) {
HTTP_req[req_index] = c; // save HTTP request character
req_index++;
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
// remainder of header follows below, depending on if
// web page or XML page is requested
// Ajax request - send XML file
if (StrContains(HTTP_req, "ajax_inputs")) {
// send rest of HTTP header
client.println("Content-Type: text/xml");
client.println("Connection: keep-alive");
client.println();
SetLEDs();
// send XML file containing input states
XML_response(client);
else { // web page request
client.println("Content-Type: text/html");
client.println();
// send web page
webFile = SD.open("index.htm"); // open web page file
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
// display received HTTP request on serial port
Serial.print(HTTP_req);
// reset buffer index and all buffer elements to 0
req_index = 0;
StrClear(HTTP_req, REQ_BUF_SZ);
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
// checks if received HTTP request is switching on/off LEDs
// also saves the state of the LEDs
void SetLEDs(void)
// LED 3 (pin 8)
if (StrContains(HTTP_req, "LED1=1")) {
LED_state[0] = 1; // save LED state
actionTransmitter.sendSignal(1,'A',true);
Serial.print("button 1 on ");
else if (StrContains(HTTP_req, "LED1=0")) {
LED_state[0] = 0; // save LED state
Serial.print("button 1 off");
// LED 4 (pin 9)
if (StrContains(HTTP_req, "LED2=1")) {
LED_state[1] = 1; // save LED state
actionTransmitter.sendSignal(1,'B',true);
else if (StrContains(HTTP_req, "LED2=0")) {
LED_state[1] = 0; // save LED state
if (StrContains(HTTP_req, "LED3=1")) {
LED_state[2] = 1; // save LED state
actionTransmitter.sendSignal(1,'C',true);
else if (StrContains(HTTP_req, "LED3=0")) {
LED_state[2] = 0; // save LED state
// send the XML file with analog values, switch status
// and LED status
void XML_response(EthernetClient cl)
int analog_val; // stores value read from analog inputs
int count; // used by 'for' loops
cl.print("<?xml version = \"1.0\" ?>");
cl.print("<inputs>");
// read analog inputs
/* for (count = 2; count <= 5; count++) { // A2 to A5
analog_val = analogRead(count);
cl.print("<analog>");
cl.print(analog_val);
cl.println("</analog>");
//read switches
for (count = 0; count < 3; count++) {
cl.print("<switch>");
if (digitalRead(sw_arr[count])) {
cl.print("ON");
else {
cl.print("OFF");
cl.println("</switch>");
// checkbox LED states
// LED1
/*cl.print("<LED>");
if (LED_state[0]) {
cl.print("checked");
else {
cl.print("unchecked");
cl.println("</LED>");
// LED2
cl.print("<LED>");
if (LED_state[1]) {
else {
cl.println("</LED>");*/
// button LED states
// LED3
cl.print("<LED>");
if (LED_state[0]) {
cl.print("on");
else {
cl.print("off");
// LED4
cl.print("<LED>");
if (LED_state[1]) {
cl.print("on");
else {
cl.print("off");
// new led
cl.print("<LED>");
if (LED_state[2]) {
cl.print("on");
else {
cl.print("off");
cl.print("</inputs>");
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
for (int i = 0; i < length; i++)
str[i] = 0;
// searches for the string sfind in the string str
// returns 1 if string found
// returns 0 if string not found
char StrContains(char *str, char *sfind)
char found = 0;
char index = 0;
char len;
len = strlen(str);
if (strlen(sfind) > len) {
return 0;
while (index < len) {
if (str[index] == sfind[found]) {
found++;
if (strlen(sfind) == found) {
return 1;
else {
found = 0;
index++;
return 0;
