ethernet shield ws5100 not connecting
when i try to print my ip address it shows 2.0.2.0 in serial monitor(the code i have taken from examples in arduino ide...i changed ip,gateway and subnet mask according to my network)
solid leds are fulld, 100m, link
ethernet shield connected to mega board
please help
thnx in advance
We don't care where you got it. We care what code YOU are ACTUALLY running on YOUR Arduino. Post that code, since it is NOT the same as the example code.
Chat Server
A simple server that distributes any incoming messages to all
connected clients. To use, telnet to your device's IP address and type.
You can see the client's input in the serial monitor as well.
Using an Arduino Wiznet Ethernet shield.
Circuit:
  • Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 12);
IPAddress myDns(192,168,1, 1);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
// telnet defaults to port 23
EthernetServer server(23);
boolean alreadyConnected = false; // whether or not the client was connected previously
// initialize the ethernet device
Ethernet.begin(mac, ip, myDns, gateway, subnet);
// start listening for clients
server.begin();
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Chat server address:");
Serial.println(Ethernet.localIP());
// wait for a new client:
// when the client sends the first byte, say hello:
if (client) {
if (!alreadyConnected) {
// clear out the input buffer:
client.flush();
Serial.println("We have a new client");
client.println("Hello, client!");
alreadyConnected = true;
if (client.available() > 0) {
// read the bytes incoming from the client:
char thisChar = client.read();
// echo the bytes back to the client:
server.write(thisChar);
// echo the bytes to the server as well:
Serial.write(thisChar);
Does the client example work?
Isn't 192.168.1.1 the router?
Are you actually running a domain name server on the router?
no,the client example is not working
yes it is my router ip
i am not using it as dns (although i removed that part from the code..still no luck)
Are you certain the IC is a w5100?
Try this test sketch. Does it show 192.168.0.2 on the serial monitor?
#include <SPI.h>
byte mac[] = {  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,0,2);
  // disable SD card if one in the slot
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Serial.println("Starting w5100");
  Ethernet.begin(mac,ip);
