Greetings, it's me again, just to make it clear again , english is not my first language , I apologise if there is any mistake.
Let's get to the point.
I did this program and it seems to be working fine. however. once I tryed to add the ethernet shield code. it just do not show the web page.
I tryed to make it as clean as possible, and not gonne lie is based on examples that I found on internet.
Hope that you could tell me if there is something wrong with the code.
(The code is a bit long so I attached it )
I also found this code to test my ethernet shield , if it prints de ip the shield is working, and apparently it is working , but I'm not sure if it is true.
it is the most common habit of newbees to just add a complex code by copy & paste maybe adapt variable-names to their project and then - it does not work.
You should find a demo-code that is written for your ethernet-shield. Testing if the ethernet-shield works with this demo-code.
Then do a simple and small change like adding a single variable to the demo-code testing if the changed demo-code works
If Yes add the demo-code to your main program. Testing again if the http-functionality is working.
if it works add a small change - test
best regards Stefan
Well, if you get an IP address, why not enter it in your browser and check if your server is working? So - if you encounter a problem with your code - clearly state what problem you have.
As Juraj already stated, start with the Arduino IDE Example
Ethernet | WebServer
This example MUST Work when you are using an Arduino UNO.
If you can confirm, we can come up with more proposals.
Serial.begin(9600);//serial port speed
//People counter
pinMode(0, INPUT); //Infrared In
pinMode(1, INPUT); //Infrared Out
On the Arduino UNO, Pin 0 and Pin 1 are the Serial pins! You can't use them for both. Note: You can use A0 through A5 for digital I/O if you are running low on digital pins.
pinMode(4, OUTPUT); //Ultrasonic trigger
WARNING: If you have an SD card in the slot on the Ethernet Shield, setting Pin 4 to LOW will put that SD card on the SPI bus used by the Ethernet chip. Should be OK if you don't have an SD card in the slot.
WARNING: pulseIn() will return 0 if there is no pulse. This happens if there is nothing close enough to produce a readable echo. You may want to consider 0 to be greater than 5.
sorry for the late reply I got a bit busy .
It is working now , aparrently there was an error with the ethernet that I was using.
Juraj , I used a simple program that I found and it is working thanks for that , I didn't know arduino had many examples.
StefanL38 , I'll start to do that , seems better than just writte it all at once.
noiasca , that's what I did , but it wasn't working (a problem with the ethernet cable) , but now it is working.
jhonwasser :
I didn't know that , guess I'm going to have to do some little changes , thanks for pointing that.
I'm not using a SD card , still not sure If I will need one.
oh , so then I'll add that greater than 0 condition
