Hey all, I'm using the example WebServer code from the Ethernet library with a genuine Ethernet shield, and the web-server eventually stops responding. Sometimes it's a couple days, sometimes it's a couple of weeks. I ran into a post which had some code to display the state of the sockets, here (post #3):
http://forum.arduino.cc/index.php?topic=216772.0
So I added that, and am calling it in each loop. I've let it run for a couple of days now, and have one socket reporting 0x17. The example code calls client.stop(), so why is the socket still connected? The post referenced above also indicates this is a known problem, but doesn't hint at a solution. Is there one?
The shield is directly connected to a switch, and is not available to the internet. Thanks!
Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
modified 02 Sept 2015
by Arturo Guadalupi
#include <SPI.h>
#include <Ethernet.h>
#include <utility/w5100.h>
byte socketStat[MAX_SOCK_NUM];
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(10, 1, 1, 198);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
void showSockStatus()
for (int i = 0; i < MAX_SOCK_NUM; i++) {
Serial.print(F("Socket#"));
Serial.print(i);
uint8_t s = W5100.readSnSR(i);
socketStat[i] = s;
Serial.print(F(":0x"));
Serial.print(s,16);
Serial.print(F(" "));
Serial.print(W5100.readSnPORT(i));
Serial.print(F(" D:"));
uint8_t dip[4];
W5100.readSnDIPR(i, dip);
for (int j=0; j<4; j++) {
Serial.print(dip[j],10);
if (j<3) Serial.print(".");
Serial.print(F("("));
Serial.print(W5100.readSnDPORT(i));
Serial.println(F(")"));
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println("</html>");
if (c == '\n') {
// you're starting a new line
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
// check sockets
showSockStatus();
// small delay to not flood serial monitor
