hi there,
I recently bought Ethernet Shiled w5100, I tried to connect it to arduino, found the code, plugged in and nothing happened.
Today I tired to find out what I did wrong 2 months ago. And found out that timing is the problem, but not these 2 months!
After countless restarts of the board and connecting ethernet cable over and over again to the board, I found that my board is working if I connect cable around a one sec after I press restart button.
To be sure about this, I uploaded another sketch and did the same thing and got my board is on network.
BUT if I leave the cable in ethernet port and restart the board, arduino will not appear on the network.
I used sketch that is built in arduino ide.
So, my question is why this is happening and how can I fix this issue, so my board can connect to the network without removing the ethernet cable?
EDIT:
Youtube link with recorded issue.
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0x00, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 0, 150 }; // IP address in LAN – need to change according to your Network address
byte gateway[] = { 192, 168, 0, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
int ledPin = 2;
void setup(){
pinMode(ledPin, OUTPUT); //pin selected to control
// Test LED
digitalWrite(ledPin, HIGH); // set pin high
digitalWrite(ledPin, LOW); // set pin low
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
void loop(){
// Create a client connection
// if(server.available()){
// Serial.println("Server ok");
// } else {
// Serial.println("No Good");
// client = server.available();
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//if HTTP request has ended– 0x0D is Carriage Return \n ASCII
if (c == 0x0D) {
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE> ARDUINO ETHERNET SHIELD</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<hr>");
client.println("
client.println("<H3 style=\"color:green;\">ARDUINO ETHERNET SHIELD — LED ON/OFF FROM WEBPAGE</H3>");
client.println("
client.println("<H5><a href=\"/?LEDON\"\">Turn On LED</a>
</H5>");
client.println("<H5><a href=\"/?LEDOFF\"\">Turn Off LED</a>
</H5>");
client.println("</BODY>");
client.println("</HTML>");
delay(10);
//stopping client
client.stop();
// control arduino pin
if(readString.indexOf("?LEDON") > -1) //checks for LEDON
else{
if(readString.indexOf("?LEDOFF") > -1) //checks for LEDOFF
//clearing string for next read
readString="";
Thanks,
Lazar
