Ethernet_Manager_STM32 for STM32 Credentials Management. Now supports LAN8720
Ethernet_Manager_STM32 Library
How To Install Using Arduino Library Manager
Why do we need this Ethernet_Manager_STM32 Library
  • This is the new library, adding to the current WiFiManager sets of libraries. It's designed to help you eliminate hardcoding your Credentials in STM32F/L/H/G/WB/MP1 boards using Ethernet shields (W5100, W5200, W5500, ENC28J60, built-in LAN8742A Ethernet). It's currently not supporting SSL. Will support soon.
  • You can update Credentials any time you need to change via Configure Portal. Data are saved in configurable locations in EEPROM.
  • DoubleDetectDetector feature to force Config Portal when double reset is detected within predetermined time, default 10s.
  • Configurable Config Portal Title to be either BoardName or default undistinguishable names.
  • Examples are redesigned to separate Credentials / Defines / Dynamic Params / Code so that you can change Credentials / Dynamic Params quickly for each device. Example MQTT_ThingStream_Ethernet_STM32 will demonstrate how to use the dynamic parameters, entered via Config Portal, to connect to ThingStream MQTT Server at mqtt.thingstream.io.
New recent features:
Releases v1.0.0
  1. Initial coding to support STM32F/L/H/G/WB/MP1.
  2. Provide support to W5x00, ENC28J60 and built-in LAN8742A Ethernet.
  3. Supporting Ethernet, EthernetLarge, Ethernet2, Ethernet3, EthernetENC, UIPEthernet and STM32Ethernet Libraries
Currently Supported Boards
  1. STM32 boards with built-in Ethernet LAN8742A such as :
  • Nucleo-144 (F429ZI, F767ZI)
  • Discovery (STM32F746G-DISCOVERY)
  • All STM32 boards (STM32F/L/H/G/WB/MP1) with 32K+ Flash, with Built-in Ethernet
  1. STM32F/L/H/G/WB/MP1 boards (with 32+K Flash) running W5x00 or ENC28J60 shields)
  • Nucleo-144
  • Nucleo-64
  • Discovery
  • Generic STM32F0, STM32F1, STM32F2, STM32F3, STM32F4, STM32F7 (with 64+K Flash): x8 and up
  • STM32L0, STM32L1, STM32L4
  • STM32G0, STM32G4
  • STM32H7
  • STM32WB
  • STM32MP1
  • LoRa boards
  • 3-D printer boards
  • Generic Flight Controllers
  • Midatronics boards
Currently Supported Ethernet shields/modules
  1. Built-in LAN8742A Ethernet using STM32Ethernet library v1.2.0+ and LwIP library v2.1.2+
  2. W5x00 using Ethernet, EthernetLarge, Ethernet2 or Ethernet3 library
  3. ENC28J60 using EthernetENC or UIPEthernet library
Examples:
  1. AM2315_Ethernet_STM32
  2. DHT11_Ethernet_STM32
  3. Ethernet_STM32
  4. MQTT_ThingStream_Ethernet_STM32
Debug Termimal Output Samples
  1. The following is the sample terminal output when running example Ethernet_STM32 on NUCLEO_F767ZI board with LAN8742A Ethernet & STM32Ethernet Library demonstrating doubleResetDetect feature.
  • 1.1. Normal run with TO_LOAD_DEFAULT_CONFIG_DATA = true
Start Ethernet_STM32 on NUCLEO_F767ZI
Ethernet Shield type : W5x00 using Ethernet Library
Ethernet_Manager_STM32 v1.0.0
EEPROM size = 16384, start = 0
Flag read = 0xd0d04321
No doubleResetDetected
SetFlag write = 0xd0d01234
[ETM] ======= Start Default Config Data =======
[ETM] Header= Eth_NonSSL , BoardName= STM32-Ethernet
[ETM] StaticIP=
[ETM] Header= STM32 , BoardName= STM32-Ethernet
[ETM] StaticIP= 192.168.2.222
[ETM] CCSum=0x 8ab ,RCSum=0x 8ab
[ETM] Start connectEthernet using Static IP = 192.168.2.222
[ETM] MAC:FE-98-FE-DE-D9-BA
  • 1.2. DRD detected
Flag read = 0xd0d01234
doubleResetDetected
ClearFlag write = 0xd0d04321
[ETM] =====================
[ETM] DRD. Run ConfigPortal
[ETM] StaticIP=
[ETM] MAC:FE-9A-FD-D6-D9-BA
W5100 init, using SS_PIN_DEFAULT = 10, new ss_pin = 10, W5100Class::ss_pin = 10
W5100::init: W5500, SSIZE =4096
[ETM] IP: 192.168.2.222
[ETM] begin:Stay in CfgPortal: DRD
Connected! IP address: 192.168.2.222
Ethernet type is W5500
Your stored Credentials :
MQTT Server = mqtt_server
Port = 1883
MQTT UserName = mqtt_user
MQTT PWD = mqtt_pass
Subs Topics = mqtt_sub
Pubs Topics = mqtt_pub
H[ETM] h:Updating EEPROM. Please wait for reset
[ETM] h:Rst
H
  • 1.3. Credentials entered and Saved
[ETM] StaticIP=
[ETM] MAC:FE-98-FE-DE-DC-BA
[ETM] begin:Ethernet Connected.
Port = 1883
Stop doubleResetDetecting
HH
Major Releases v1.2.0
  1. Configurable Customs HTML Headers, including Customs Style, Customs Head Elements, CORS Header.
  2. Add functions to control Config Portal from software or Virtual Switches.
  3. Use more efficient FlashStorage_STM32 library
  4. Fix Config Portal Bug.
  5. Update examples
  6. Bump up to version v1.2.0 to sync with Ethernet_Manager library
Releases v1.3.0
  1. Add support to LAN8720 Ethernet for many STM32F4 (F407xx, NUCLEO_F429ZI) and STM32F7 (DISCO_F746NG, NUCLEO_F746ZG, NUCLEO_F756ZG) boards.
  2. Add LAN8720 examples
  3. Add Packages' Patches for STM32 to use LAN8720 with STM32Ethernet and LwIP libraries
