Everything runs fine individually, but when connected it doesn't seem to work
I am using an Arduino Uno for these tests, then eventually once done I am going to make a PCB that can house an Arduino Nano.
But during my test the distance keeps reading 0cm on my ultrasonic sensor, and my servo just rotates about 10 degrees then back to 0 in under 0.5 seconds. I have the servo power connected to 5v, and the ultrasonic connected to 3.3v, this is the only problem I could think of that would be causing this.
What I am wanting it to do is when it can sense a distance closer then 20cm, it will rotate the servo 80 degrees and hold for 1 second.
//defining trig and echo pin
#define trigPin 2
#define echoPin 3
//defining servo pin
#define servoPin 9
//library implimintation
#include <Servo.h>
//defining servo name
Servo servo1;
//a variable to store the servo position
int angle = 0;
//defining the variables
long duration;
int distance;
  //defining inputs and outputs
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  //the servo is now attatched to pin 9 or the servo pin
  servo1.attach(servoPin);
  //Begining the serial communication at a rate of 9600
  //Clearing the trigPin by setting it to LOW
  digitalWrite(trigPin, LOW);
  delayMicroseconds(5);
  //Triggering the sensor by setting the trigPin to high for 10 microseconds
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Read the echoPin, pulseIn() returns the duration (length of the pulse) in microseconds:
  duration = pulseIn(echoPin, HIGH);
  // Calculate the distance:
  distance = duration * 0.034 / 2;
  // Print the distance on the Serial Monitor (Ctrl+Shift+M):
  Serial.print("Distance = ");
  Serial.print(distance);
  Serial.println(" cm");
  delay(50);
  if (distance >20);{ // if the distance read, is further then 20cm, then activate code below
    servo1.write(80);
    servo1.write(0);
This is my code, if you want to ask any other questions feel free to ask in replys. Thanks.
  if (distance > 20);
Delete the semicolon. It is the only code dependant on the outcome of the comparison. The code in the code block following the line with the if will be executed unconditionally
Lose the
I have and the distance still reads zero, but that at least fixed the servo motor bug. What should I do to fix the distance reading 0?
Yep did that and it fixed the servo motor bug, but the distance on the ultrasonic still reads 0, any tip?
There’s no point putting this in loop()
You might initialise the pin state in setup(), but there’s no point wasting time in loop repeating it on every pass.
That means that no pulse was received from the echo pin. Could be a wiring error or a faulty rangefinder.
The default pulseIn() timeout is 1 second (1,000,000 microseconds) but the rangefinder is only capable of about 5 meters so a timeout of 30000 microseconds is more appropriate:
duration = pulseIn(echoPin, HIGH, 30000);
Yes, that can be a problem. You didn´t mention your sensor, but the HC-SR04 works with 5V.
