Example code not working (wire.write and wire.read)
im using example code from the beginning Arduino programming by Brian Evans. Chapter 10 - RTC (DS1307)
when i try to complie the code it doesnt like Wire.write or Wire.read.
#include <Wire.h>
const int DS1307 = 0x68;
const char* days[] =
  {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
const char* months[] =
  {"January", "February", "March", "April", "May", "June", "July", "August",
   "September", "October", "November", "December"};
byte second = 0;
byte minute = 0;
byte hour = 0;
byte weekday = 0;
byte monthday = 0;
byte month = 0;
byte year = 0;
  Wire.begin();
  delay(2000);
  Serial.print("The current date and time is: ");
  printTime();
  Serial.println("To set the date and time please select Newline ending to continue.");
  Serial.println("Would you like to set the date and time now? Y/N");
  while (!Serial.available()) delay(10);
  if (Serial.read() == 'y' || Serial.read() == 'Y') {
    Serial.read();
    setTime();
    Serial.print("The current date and time is now: ");
    printTime();
  Serial.println("Goodbye.");
void loop() {}
byte decToBcd(byte val) {
  return ((val/10*16) + (val%10));
byte bcdToDec(byte val) {
  return ((val/16*10) + (val%16));
void setTime() {
  Serial.print("Please enter the current year, 00-99.  -  ");
  year = readByte();
  Serial.println(year);
  Serial.print("Please enter the current month, 1-12.  -  ");
  month = readByte();
  Serial.println(months[month-1]);
  Serial.print("Please enter the current day of the month, 1-31.  -  ");
  monthday = readByte();
  Serial.println(monthday);
  Serial.println("Please enter the current day of the week, 1-7.");
  Serial.print("1 Sun | 2 Mon | 3 Tues | 4 Weds | 5 Thu | 6 Fri | 7 Sat  -  ");
  weekday = readByte();
  Serial.println(days[weekday-1]);
  Serial.print("Please enter the current hour in 24hr format, 0-23.  -  ");
  hour = readByte();
  Serial.println(hour);
  Serial.print("Please enter the current minute, 0-59.  -  ");
  minute = readByte();
  Serial.println(minute);
  second = 0;
  Serial.println("Thank you.");
  Wire.beginTransmission(DS1307);
  Wire.write(byte(0));
  Wire.write(decToBcd(second));
  Wire.write(decToBcd(minute));
  Wire.write(decToBcd(hour));
  Wire.write(decToBcd(weekday));
  Wire.write(decToBcd(monthday));
  Wire.write(decToBcd(month));
  Wire.write(decToBcd(year));
  Wire.endTransmission();
byte readByte() {
  byte reading = 0;
  byte incomingByte = Serial.read();
  while (incomingByte != '\n') {
    if (incomingByte >= '0' && incomingByte <= '9') reading = reading * 10 + (incomingByte - '0');
    else;
  Serial.flush();
  return reading;
void printTime() {
  char buffer[3];
  const char* AMPM = 0;
  readTime();
  Serial.print(days[weekday-1]);
  Serial.print(" ");
  Serial.print(months[month-1]);
  Serial.print(" ");
  Serial.print(monthday);
  Serial.print(", 20");
  Serial.print(year);
  Serial.print(" ");
  if (hour > 12) {
    hour -= 12;
    AMPM = " PM";
  } else AMPM = " AM";
  Serial.print(hour);
  Serial.print(":");
  sprintf(buffer, "%02d", minute);
  Serial.print(buffer);
  Serial.println(AMPM);
void readTime() {
  Wire.requestFrom(DS1307, 7);
  second = bcdToDec(Wire.read());
  minute = bcdToDec(Wire.read());
  hour = bcdToDec(Wire.read());
  weekday = bcdToDec(Wire.read());
  monthday = bcdToDec(Wire.read());
  month = bcdToDec(Wire.read());
  year = bcdToDec(Wire.read());
Could you be a bit more specific about "doesn't like"?
it wont allow me to download the program to the arduino uno
Perhaps that code was written for an earlier version of Arduino. There were a number of changes in 1.0, probably including changes in the Wire library.
Does it tell you why?
this is what it says at the bottom in arduino 1 (lastest version)
L10_4.cpp: In function 'void setTime()':
L10_4:71: error: 'class TwoWire' has no member named 'write'
L10_4:73: error: 'class TwoWire' has no member named 'write'
L10_4:74: error: 'class TwoWire' has no member named 'write'
L10_4:75: error: 'class TwoWire' has no member named 'write'
L10_4:76: error: 'class TwoWire' has no member named 'write'
L10_4:77: error: 'class TwoWire' has no member named 'write'
L10_4:78: error: 'class TwoWire' has no member named 'write'
L10_4:79: error: 'class TwoWire' has no member named 'write'
L10_4:81: error: 'class TwoWire' has no member named 'write'
L10_4.cpp: In function 'void readTime()':
L10_4:127: error: 'class TwoWire' has no member named 'write'
L10_4:132: error: 'class TwoWire' has no member named 'read'
L10_4:133: error: 'class TwoWire' has no member named 'read'
L10_4:134: error: 'class TwoWire' has no member named 'read'
L10_4:135: error: 'class TwoWire' has no member named 'read'
L10_4:136: error: 'class TwoWire' has no member named 'read'
L10_4:137: error: 'class TwoWire' has no member named 'read'
L10_4:138: error: 'class TwoWire' has no member named 'read'
As Johnwasser said. Which version of the IDE are you using?
Edit: ah, missed that you had 1.0. Have you managed to get an old version of the library from somewhere?
the latest, Arduino 1.0
Perhaps you have an old copy of the Wire library somewhere. "As of Arduino 1.0, the library inherits from the Stream functions, making it consistent with other read/write libraries. Because of this, send() and receive() have been replaced with read() and write()."
Check the "libraries" folder in your sketch folder to make sure you don't have an old Wire library.
i will try downloading a new wire library
You don't need to do that. The wire library is included with the IDE.
if you change the write to send and the read to recieve it will work (complie) thank guys
