Example project using Arduino Nano Matter, Modulino Thermo and Latch Relay publishing temperature and humidity to Matter with optional relay control
Hi everyone,
I created a working example using the Arduino Nano Matter with Modulino modules.
Hardware used:
• Arduino Nano Matter
• Nano Connector Carrier
• Modulino Thermo
• Modulino Latch Relay (optional)
The sketch publishes temperature and humidity to Matter and can optionally
control a relay based on a temperature threshold.
Full project and sketch available on GitHub:
Features:
• Matter temperature sensor
• Matter humidity sensor
• Optional thermostat-style relay control
• Reduced Matter traffic (values are only published when they change)
Notes from development:
• Modulino.begin() must be called before accessing modules
• Some Matter examples reuse the same device ID, so a previously
commissioned board may need to be decommissioned before uploading
a new sketch
• Google Home displays humidity as integer percentages
Hopefully this helps others getting started with the Nano Matter + Modulino ecosystem.
Feedback or improvements welcome!
