I have looked at the example "SendRawDemo", but I can't figure out how to input my data into the program. There are two arrays, which both look different than my data. This is what the portion of the example code with both arrays looks like (if you need the full thing, its under example sketches and is called SendRawDemo):
const uint8_t rawDataP[]
#if defined(__AVR__)
PROGMEM
#endif
= { 180, 90 /*Start bit*/, 11, 11, 11, 11, 11, 34, 11, 34/*0011 0xC of 16 bit address LSB first*/, 11, 11, 11, 11, 11, 11, 11,
11/*0000*/, 11, 34, 11, 34, 11, 11, 11, 34/*1101 0xB*/, 11, 34, 11, 34, 11, 34, 11, 34/*1111*/, 11, 11, 11, 11, 11, 11, 11,
34/*0001 0x08 of command LSB first*/, 11, 34, 11, 11, 11, 11, 11, 11/*1000 0x01*/, 11, 34, 11, 34, 11, 34, 11,
11/*1110 Inverted 8 of command*/, 11, 11, 11, 34, 11, 34, 11, 34/*0111 inverted 1 of command*/, 11 /*stop bit*/};
#if !(defined(__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__))
* Send hand crafted data from RAM
* The values are NOT multiple of 50, but are taken from the NEC timing definitions
Serial.println(F("Send NEC 16 bit address=0xFB04 and command 0x08 with exact timing (16 bit array format)"));
Serial.flush();
const uint16_t rawData[] = { 9000, 4500/*Start bit*/, 560, 560, 560, 560, 560, 1690, 560,
560/*0010 0x4 of 16 bit address LSB first*/, 560, 560, 560, 560, 560, 560, 560, 560/*0000*/, 560, 1690, 560, 1690, 560,
560, 560, 1690/*1101 0xB*/, 560, 1690, 560, 1690, 560, 1690, 560, 1690/*1111*/, 560, 560, 560, 560, 560, 560, 560,
1690/*0001 0x08 of command LSB first*/, 560, 560, 560, 560, 560, 560, 560, 560/*0000 0x00*/, 560, 1690, 560, 1690, 560,
1690, 560, 560/*1110 Inverted 8 of command*/, 560, 1690, 560, 1690, 560, 1690, 560, 1690/*1111 inverted 0 of command*/,
560 /*stop bit*/}; // Using exact NEC timing
IrSender.sendRaw(rawData, sizeof(rawData) / sizeof(rawData[0]), NEC_KHZ); // Note the approach used to automatically calculate the size of the array.
delay(1000); // delay must be greater than 5 ms (RECORD_GAP_MICROS), otherwise the receiver sees it as one long signal
#endif
Do you know how I can input my results above into this code? Sorry for all the questions, I'm really new to arduino and I'm still trying to figure out raw ir codes.
