Excel Data Streamer - No Data
Running an Arduino Nano BLE Sense. Reads 4 sensors, analogWrites them to 4 PWM pins (Not sure if that's relevant), and in the meantime, prints all 4 to the serial monitor. They print to the serial monitor fine, and the analogWrite signals are working ok, but i need to kind of tune them so they are in the range i need. To do that i want to use Data Streamer to collect long-term data over time.
I can connect to the COM Port, and start the data, but nothing populates. Here's my code:
#include <Arduino_BMI270_BMM150.h> //Tilt
#include <Arduino_LPS22HB.h> //Pressure
#include <Arduino_HS300x.h> //Humidity
#include <Arduino_APDS9960.h> //Color
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  // Initialize sensors
 IMU.begin();/////Tilt
 BARO.begin();////Pressure
 HS300x.begin();//Humidity
 APDS.begin();/////Color
int r, g, b;
  //////////////////////////////////////////////// Read Pressure data///////////////////////////////////////////////////////
 float initialPressure = BARO.readPressure();
 delay(10000);//////////////////////////////////////////////////////// DELAY ////////////////////////
 float finalPressure = BARO.readPressure();
 float pressureDifference = abs(finalPressure - initialPressure);
     Serial.print(pressureDifference*25500);
     Serial.print(",");
     Serial.print("\t");
     //////////////////////////////////////////////////////Send Pressure Difference to pin 4////////////
     analogWrite(4, (pressureDifference*25500));
  ////////////////////////////////////////////////////////// Read Tilt data//////////////////////////////////////////
  float x, y, z;
  if (IMU.accelerationAvailable()) {
    IMU.readAcceleration(x, y, z);
    // Compile data for pin 2
    float compiledData = abs(((x + y) + (y + z) + (z + x)) / 3.0);
    int tilt = (compiledData * 255);
         ////////////// Print Tilt//////////////
     Serial.print(tilt);
     Serial.print(",");
     Serial.print("\t");
     ////////////////////////////////////////////////////// Send Tilt data to pin 2//////////////////
     analogWrite(2, tilt);
   ////////////////////////////////////////////////Read Humidity data//////////////////////////////////////////////////
   int humidity    = HS300x.readHumidity();
        /////////////////////////////////////////////////////// Send Humidity to pin 3////////////////
     analogWrite(3, float(map(humidity, 0, 100, 0, 3300) / 1000.0));
     ///////////// Print Humidity////////////////////
     Serial.print(map(humidity, 0, 100, 0, 255));
     Serial.print(",");
     Serial.print("\t");
   ////////////////////////////////////////////////////// Read Red light data////////////////////////////////////////////////
  while (! APDS.colorAvailable()) {
    delay(5);
   int r, g, b;
   APDS.readColor(r, g, b);
        //////////Print Red Light Amount/////////////
     Serial.print(map(r,0,4097,0,255));
     ///////////////////////////////////////////////////////////Send Red Light to pin 5//////////
     analogWrite(5, int(map(r,0,4097,0,255)));
Things I've tried:
-Restart the computer
-Restart the arduino
-Turned off the serial monitor
-matched the baud rates,
-reinstalled my COM driver
-reinstalled Data Streamer
Something to keep in mind: I connected the VBUS points to make 5v out possible, and since then, the COM ports have been a little weird. Usually, it defaults to COM 7 but I can't upload through COM 7. So I have to double click the reset button and go to boot mode every time. That changes it to COM 6 which allows me to upload. I have to do this while connecting in the IDE and in Excel. Could this have something to do with it?
Hi did u set the baud rate, com port and data bits in the data streamer in the advanced tab?
