I'm having problems compiling sketches with the error "exec: "cmd": executable file not found in %PATH%"
The sketch I'm trying to upload is the Wifi Scan example sketch below. (I'm tying this as the one I actually want to use had the same error ).
Any ideas?
* This sketch demonstrates how to scan WiFi networks.
* The API is based on the Arduino WiFi Shield library, but has significant changes as newer WiFi functions are supported.
* E.g. the return value of `encryptionType()` different because more modern encryption is supported.
#include "WiFi.h"
// Set WiFi to station mode and disconnect from an AP if it was previously connected.
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
Serial.println("Setup done");
Serial.println("Scan start");
// WiFi.scanNetworks will return the number of networks found.
int n = WiFi.scanNetworks();
Serial.println("Scan done");
if (n == 0) {
Serial.println("no networks found");
Serial.print(n);
Serial.println(" networks found");
Serial.println("Nr | SSID | RSSI | CH | Encryption");
for (int i = 0; i < n; ++i) {
// Print SSID and RSSI for each network found
Serial.printf("%2d",i + 1);
Serial.print(" | ");
Serial.printf("%-32.32s", WiFi.SSID(i).c_str());
Serial.printf("%4d", WiFi.RSSI(i));
Serial.printf("%2d", WiFi.channel(i));
switch (WiFi.encryptionType(i))
case WIFI_AUTH_OPEN:
Serial.print("open");
case WIFI_AUTH_WEP:
Serial.print("WEP");
case WIFI_AUTH_WPA_PSK:
Serial.print("WPA");
case WIFI_AUTH_WPA2_PSK:
Serial.print("WPA2");
case WIFI_AUTH_WPA_WPA2_PSK:
Serial.print("WPA+WPA2");
case WIFI_AUTH_WPA2_ENTERPRISE:
Serial.print("WPA2-EAP");
case WIFI_AUTH_WPA3_PSK:
Serial.print("WPA3");
case WIFI_AUTH_WPA2_WPA3_PSK:
Serial.print("WPA2+WPA3");
case WIFI_AUTH_WAPI_PSK:
Serial.print("WAPI");
default:
Serial.print("unknown");
delay(10);
Serial.println("");
// Delete the scan result to free memory for code below.
WiFi.scanDelete();
// Wait a bit before scanning again.
delay(5000);
Error log is;
Arduino: 1.8.19 (Windows 10), TD: 1.57-beta3, Board: "ESP32 Wrover Module, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), QIO, 80MHz, 921600, None, Disabled"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Nick Kay\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Nick Kay\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Nick Kay\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32wrover:PartitionScheme=default,FlashMode=qio,FlashFreq=80,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=1A86_55D4 -ide-version=10819 -build-path C:\Users\NICKKA~1\AppData\Local\Temp\arduino_build_147620 -warnings=all -build-cache C:\Users\NICKKA~1\AppData\Local\Temp\arduino_cache_440839 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -prefs=runtime.tools.esptool_py-4.5.1.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -prefs=runtime.tools.openocd-esp32.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20230419 -prefs=runtime.tools.openocd-esp32-v0.12.0-esp32-20230419.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20230419 -prefs=runtime.tools.mklittlefs.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gdb-11.2_20220823.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.dfu-util.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb-11.2_20220823.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -verbose C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14\libraries\WiFi\examples\WiFiScan\WiFiScan.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Nick Kay\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Nick Kay\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Nick Kay\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32wrover:PartitionScheme=default,FlashMode=qio,FlashFreq=80,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=1A86_55D4 -ide-version=10819 -build-path C:\Users\NICKKA~1\AppData\Local\Temp\arduino_build_147620 -warnings=all -build-cache C:\Users\NICKKA~1\AppData\Local\Temp\arduino_cache_440839 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -prefs=runtime.tools.esptool_py-4.5.1.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -prefs=runtime.tools.openocd-esp32.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20230419 -prefs=runtime.tools.openocd-esp32-v0.12.0-esp32-20230419.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20230419 -prefs=runtime.tools.mklittlefs.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gdb-11.2_20220823.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.dfu-util.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb-11.2_20220823.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -verbose C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14\libraries\WiFi\examples\WiFiScan\WiFiScan.ino
Using board 'esp32wrover' from platform in folder: C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14
Using core 'esp32' from platform in folder: C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14
cmd /c if exist "C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14\libraries\WiFi\examples\WiFiScan\partitions.csv" COPY /y "C:\Users\Nick Kay\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14\libraries\WiFi\examples\WiFiScan\partitions.csv" "C:\Users\NICKKA~1\AppData\Local\Temp\arduino_build_147620\partitions.csv"
Error compiling for board ESP32 Wrover Module.
