checkBTcmd(); // verify if a comand is received from BT remote control
receiveCmd ();
if (turnOn) manualCmd ();
else stopRobot ();
void checkBTcmd()
if (BT1.available())
command = BT1.read();
BT1.flush();
void receiveCmd ()
switch (command)
case 'p':
Serial.println("command ==> p");
turnOn = !turnOn;
command = 0;
analogWrite(ledStatus, turnOn*128); // Robot ON - Led ON
beep(outBuz, 1000, 100);
BT1.print(" COMMAND ON/OFF");
BT1.println('\n');
delay(200); //Delay to call attention to mode change
case 'm': //not used here
void manualCmd()
switch (command)
case 'f':
moveStop(); //turn off both motors
state = command;
case 'w':
moveForward();
state = command;
case 'd':
moveRight();
case 'a':
moveLeft();
case 's':
moveBackward();
state = command;
case '+':
if (state == 'w')
motorSpeed = motorSpeed + 10;
if (motorSpeed > MAX_SPEED)
motorSpeed = MAX_SPEED;
command = 'w';
} else {command = state;}
case '-':
if (state == 'w')
motorSpeed = motorSpeed - 10;
if (motorSpeed < MIN_SPEED )
motorSpeed = MIN_SPEED;
Serial.println(motorSpeed);
command = state;
void moveForward() // rear motor FW
analogWrite(rearMtEne, motorSpeed);
digitalWrite(rearMtFw, HIGH);
digitalWrite(rearMtBw, LOW);
digitalWrite(frontMtEne, LOW);
digitalWrite(ledRed, LOW);
delay(5);
void stopRobot ()
digitalWrite(ledBlue, LOW);
state = 0;
// Motor Drives
const int rearMtFw = 4; // Rear Motor - FW
const int rearMtBw = 7; // Rear Motor - BW
const int rearMtEne = 6; // Rear Motor - enable
const int frontMtLeft = 2; // Front Motor - turn Left
const int frontMtRight = 3; // Front Motor - turn right
const int frontMtEne = 5; // Front Motor enable
delay(5);
void moveBackward() // rear motor BW
digitalWrite(rearMtFw, LOW);
digitalWrite(rearMtBw, HIGH);
digitalWrite(ledRed, HIGH);
delay(5);
void moveLeft() // front motor left
digitalWrite(frontMtEne, HIGH);
digitalWrite(frontMtLeft, HIGH);
digitalWrite(frontMtRight, LOW);
delay(10);
void moveRight() // front motor right
digitalWrite(frontMtLeft, LOW);
digitalWrite(frontMtRight, HIGH);
delay(10);
void stopRobot ()
state = 0;
