Author: Krishna Agarwal
#include <AFMotor.h>
//Objects
AF_DCMotor motorRight(1, MOTOR12_64KHZ); // create motor #1, 64KHz pwm
//Constants and variable
char dataIn = 'S';
char determinant;
char det;
int vel = 255; //Bluetooth Stuff
int god = 255;
int aod = 255;
int bod = 255;
int cod = 255;
int dod = 255;
Serial.begin(9600); // set up Serial library at 9600 bps
//Initalization messages
Serial.println("ab");
pinMode(8, OUTPUT); //1 Led
pinMode(9, OUTPUT); //2 Led
pinMode(10, OUTPUT); //3 Led
pinMode(11, OUTPUT); //4 Led
pinMode(12, OUTPUT); //5 Led
//turn off motors
motorRight.setSpeed(0);
motorRight.run(RELEASE);
det = check();
//serial code analysis
switch (det){
case 'F': // F, move forward
motorRight.setSpeed(vel);
motorRight.run(FORWARD);
det = check();
case 'B': // B, move back
motorRight.run(BACKWARD);
det = check();
case 'L':// L, move wheels left
motorRight.setSpeed(vel/4);
det = check();
case 'R': // R, move wheels right
motorRight.setSpeed(vel/2);
det = check();
case 'S':
// S, stop
det = check();
case 'G':
// G, 1 Light On
digitalWrite(8, god);
det = check();
case 'A':
// A, 2 Light on
digitalWrite(9, aod);
det = check();
case 'B':
// B, 3 Light on
digitalWrite(10, bod);
det = check();
case 'C':
// C, 4 Light On
digitalWrite(11, cod);
det = check();
case 'D':
// D, 5 Light On
digitalWrite(12, dod);
det = check();
case 'g':
// g, 1 Light off
digitalWrite(8, LOW);
det = check();
case 'a':
// a, 2 Light off
digitalWrite(9, LOW);
det = check();
case 'b':
// b, 3 Light off
digitalWrite(10, LOW);
det = check();
case 'c':
// c, 4 Light On
digitalWrite(11, LOW);
det = check();
case 'd':
// D, 5 Light Off
digitalWrite(12, LOW);
det = check();
case 'Z':
// Z, All Light On
det = check();
case 'z':
// z, All Light off
det = check();
//get bluetooth code received from serial port
int check(){
if (Serial.available() > 0){// if there is valid data in the serial port
dataIn = Serial.read();// stores data into a varialbe
//check the code
if (dataIn == 'F'){//Forward
determinant = 'F';
else if (dataIn == 'B'){//Backward
determinant = 'B';
else if (dataIn == 'L'){//Left
determinant = 'L';
else if (dataIn == 'R'){//Right
determinant = 'R';
else if (dataIn == 'S'){//Stop motor
determinant = 'S';
else if (dataIn == 'G'){//1 Light On
determinant = 'G';
else if (dataIn == 'A'){//2 Light On
determinant = 'A';
else if (dataIn == 'B'){//3 Light On
determinant = 'B';
else if (dataIn == 'C'){//4 Light On
determinant = 'C';
else if (dataIn == 'D'){//5 Light On
determinant = 'D';
else if (dataIn == 'g'){//1 Light Off
determinant = 'g';
else if (dataIn == 'a'){//2 Light off
determinant = 'a';
else if (dataIn == 'b'){//3 Light Off
determinant = 'b';
else if (dataIn == 'c'){//4 Light Off
determinant = 'c';
else if (dataIn == 'd'){//5 Light off
determinant = 'd';
}else if (dataIn == 'Z'){//All Light On
determinant = 'Z';
else if (dataIn == 'z'){//All light off
determinant = 'z';
else if (dataIn == '0'){//Speed 0
vel = 0;
else if (dataIn == '1'){//Speed 25
vel = 25;
else if (dataIn == '2'){//Speed 50
vel = 50;
else if (dataIn == '3'){//Speed 75
vel = 75;
else if (dataIn == '4'){//Speed 100
vel = 100;
else if (dataIn == '5'){//Speed 125
vel = 125;
else if (dataIn == '6'){//Speed 150
vel = 150;
else if (dataIn == '7'){//Speed 175
vel = 175;
else if (dataIn == '8'){//Speed 200
vel = 200;
else if (dataIn == '9'){//Speed 225
vel = 225;
else if (dataIn == '11'){//Led 0
god = 0;
else if (dataIn == '12'){//Led 25
god = 25;
} else if (dataIn == '13'){//Led 50
god = 50;
} else if (dataIn == '14'){//Led 75
god = 75;
} else if (dataIn == '15'){//Led 100
god = 100;
} else if (dataIn == '16'){//Led 125
god = 125;
} else if (dataIn == '17'){//Led 150
god = 150;
} else if (dataIn == '18'){//Led 200
god = 200;
else if (dataIn == '19'){//Led 255
god = 255;
return determinant;
