Exit Status 1 (ESP8266)
I have the code to turn off and on the relay light via Telegram and the error "Exit Status 1" appears. This is the code:
#include <CTBot.h>
#include <ArduinoJson.h>
#include <ESP8266WiFi.h>
CTBot myBot;
const char* wifiSsid = "wifi-ahsan";
const char* wifiPassword = "anyarlali";
String token = "censored";
const int id = censored
int Relay1 = 5;
int Relay2 = 4;
  delay(10);
  // Koneksi ke jaringan Wi-Fi
  WiFi.begin(wifiSsid, wifiPassword);
    Serial.println("Menghubungkan ke WiFi...");
  Serial.println("Tersambung ke Wi-Fi");
  // Inisialisasi bot Telegram
  myBot.wifiConnect(wifiSsid, wifiPassword);
  myBot.setTelegramToken(token);
  if (myBot.testConnection()) {
    Serial.println("testConnection OK");
    Serial.println("testConnection NOK");
  // Inisialisasi pin relay
  pinMode(Relay1, OUTPUT);
  digitalWrite(Relay1, HIGH);
  pinMode(Relay2, OUTPUT);
  digitalWrite(Relay2, HIGH);
  TBMessage msg;
  if (myBot.getNewMessage(msg)) {
    if (msg.text.equalsIgnoreCase("Mulai bot")) {
      myBot.sendMessage(msg.sender.id, "Silahkan Mulai");
    if (msg.text.equalsIgnoreCase("Relay1 ON")) {
      digitalWrite(Relay1, LOW);
      myBot.sendMessage(msg.sender.id, "Lampu 1 Menyala");
    } else if (msg.text.equalsIgnoreCase("Relay1 OFF")) {
      myBot.sendMessage(msg.sender.id, "Lampu 1 Padam");
    if (msg.text.equalsIgnoreCase("Relay2 ON")) {
      digitalWrite(Relay2, LOW);
      myBot.sendMessage(msg.sender.id, "Lampu 2 Menyala");
    } else if (msg.text.equalsIgnoreCase("Relay2 OFF")) {
      myBot.sendMessage(msg.sender.id, "Lampu 2 Padam");
    if (msg.text.equalsIgnoreCase("All Relay ON")) {
      myBot.sendMessage(msg.sender.id, "Semua Lampu Menyala");
    if (msg.text.equalsIgnoreCase("All Relay OFF")) {
      myBot.sendMessage(msg.sender.id, "Semua Lampu Padam");
and the error was
Any idea how to fix that, guys?
To see detailed compilation error message you need to switch on the options in the File-Preferences menu of Arduino IDE:
After that start the compilation again and copy the output to the forum as text, using code tags.
Do not include the screenshots - it mostly useless.
In this line you defined a variable named "id" containing the value of another variable named "censored", which was not previously defined,
and also when defining a precise variable, end the definition with ";".
Test your code with this modification.
#include <CTBot.h>
CTBot myBot;
int censored = 0;
const int id = censored;
See what is circled in red; there should be more info above what you showed.
You can right-click in the output window and select copy all. Next you can paste it here in a reply; please use code tags (as you did for your code in the opening post).
