sketch\MiniKame.cpp: In constructor 'MiniKame::MiniKame()':
MiniKame.cpp:37: error: expected primary-expression before ']' token
board_pins,[FRONT_LEFT_LEG] = (9); // front right outer
In file included from sketch\MiniKame.cpp:2:0:
MiniKame.h:19: error: expected identifier before numeric constant
#define BACK_RIGHT_LEG 6];
sketch\MiniKame.cpp:39:15: note: in expansion of macro 'BACK_RIGHT_LEG'
board_pins,[BACK_RIGHT_LEG] = (5); // back left outer
sketch\MiniKame.cpp: In lambda function:
MiniKame.h:19: error: expected '{' before ';' token
MiniKame.cpp:39: error: expected primary-expression before ']' token
MiniKame.cpp:41: error: 'poard_pins' was not declared in this scope
poard_pins,[BACK_LEFT_LEG] = (7); // back right outer
MiniKame.h:21: error: expected identifier before numeric constant
#define BACK_LEFT_LEG 7];
sketch\MiniKame.cpp:41:15: note: in expansion of macro 'BACK_LEFT_LEG'
MiniKame.h:21: error: expected '{' before ';' token
MiniKame.cpp:41: error: expected primary-expression before ']' token
sketch\MiniKame.cpp: In member function 'void MiniKame::hello()':
sketch\MiniKame.cpp:312:43: warning: narrowing conversion of 'T' from 'int' to 'float' inside { } [-Wnarrowing]
float period[] = {T, T, T, T, T, T, T, T};
sketch\MiniKame.cpp: In member function 'void MiniKame::jump()':
sketch\MiniKame.cpp:343:23: warning: narrowing conversion of '(ap + 90)' from 'int' to 'float' inside { } [-Wnarrowing]
float salto[] = {90 + ap, 90 - ap, 90 - hi, 90 + hi, 90 - ap * 3, 90 + ap * 3, 90 + hi, 90 - hi};
sketch\MiniKame.cpp:343:32: warning: narrowing conversion of '(90 - ap)' from 'int' to 'float' inside { } [-Wnarrowing]
sketch\MiniKame.cpp:343:41: warning: narrowing conversion of '(90 - hi)' from 'int' to 'float' inside { } [-Wnarrowing]
sketch\MiniKame.cpp:343:50: warning: narrowing conversion of '(hi + 90)' from 'int' to 'float' inside { } [-Wnarrowing]
sketch\MiniKame.cpp:343:59: warning: narrowing conversion of '((ap * -3) + 90)' from 'int' to 'float' inside { } [-Wnarrowing]
sketch\MiniKame.cpp:343:72: warning: narrowing conversion of '((ap * 3) + 90)' from 'int' to 'float' inside { } [-Wnarrowing]
sketch\MiniKame.cpp:343:85: warning: narrowing conversion of '(hi + 90)' from 'int' to 'float' inside { } [-Wnarrowing]
sketch\MiniKame.cpp:343:94: warning: narrowing conversion of '(90 - hi)' from 'int' to 'float' inside { } [-Wnarrowing]
exit status 1
