Whenever I want to load a new program on my Arduino Nano then "exit status 1" is displayed. I've already tried it with two different PCs and two different versions of the IDE. What can you do?
Here is the simple Programm i used:
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
delay(100);
digitalWrite(LED_BUILTIN, LOW);
delay(100);
Here is the Error message:
Using board 'nano' from platform in folder: C:\Users\moser\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\moser\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Verwendete Bibliotheken erkennen...
"C:\\Users\\moser\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\moser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\moser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\moser\\AppData\\Local\\Temp\\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1\\sketch\\sketch_feb11a.ino.cpp" -o nul
Funktionsprototypen werden generiert...
"C:\\Users\\moser\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\moser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\moser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\moser\\AppData\\Local\\Temp\\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1\\sketch\\sketch_feb11a.ino.cpp" -o "C:\\Users\\moser\\AppData\\Local\\Temp\\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\moser\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\moser\\AppData\\Local\\Temp\\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Sketch wird kompiliert...
"C:\\Users\\moser\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\moser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\moser\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\moser\\AppData\\Local\\Temp\\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1\\sketch\\sketch_feb11a.ino.cpp" -o "C:\\Users\\moser\\AppData\\Local\\Temp\\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1\\sketch\\sketch_feb11a.ino.cpp.o"
Bibliotheken werden kompiliert...
Kern wird kompiliert...
Using precompiled core: C:\Users\moser\AppData\Local\Temp\arduino-core-cache\core_arduino_avr_nano_cpu_atmega328_a108f025a0678d38fe02b648c92a725d.a
Linking everything together...
"C:\\Users\\moser\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\moser\\AppData\\Local\\Temp\\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1/sketch_feb11a.ino.elf" "C:\\Users\\moser\\AppData\\Local\\Temp\\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1\\sketch\\sketch_feb11a.ino.cpp.o" "C:\\Users\\moser\\AppData\\Local\\Temp\\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1/..\\arduino-core-cache\\core_arduino_avr_nano_cpu_atmega328_a108f025a0678d38fe02b648c92a725d.a" "-LC:\\Users\\moser\\AppData\\Local\\Temp\\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1" -lm
"C:\\Users\\moser\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\moser\\AppData\\Local\\Temp\\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1/sketch_feb11a.ino.elf" "C:\\Users\\moser\\AppData\\Local\\Temp\\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1/sketch_feb11a.ino.eep"
"C:\\Users\\moser\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\moser\\AppData\\Local\\Temp\\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1/sketch_feb11a.ino.elf" "C:\\Users\\moser\\AppData\\Local\\Temp\\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1/sketch_feb11a.ino.hex"
"C:\\Users\\moser\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\moser\\AppData\\Local\\Temp\\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1/sketch_feb11a.ino.elf"
Der Sketch verwendet 922 Bytes (3%) des Programmspeicherplatzes. Das Maximum sind 30720 Bytes.
Globale Variablen verwenden 9 Bytes (0%) des dynamischen Speichers, 2039 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
"C:\Users\moser\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\moser\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM7" -b115200 -D "-Uflash:w:C:\Users\moser\AppData\Local\Temp\arduino-sketch-B9F4DDC3F45BD9793F2C8C3CCE165BF1/sketch_feb11a.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\moser\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM7
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x3b
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x3b
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x3b
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x3b
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x3b
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x3b
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x3b
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x3b
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x3b
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x3b
avrdude done. Thank you.
Fehlgeschlagenes Hochladen: Hochladefehler: exit status 1
