Hello,
I tried to upload a sketch in a NodeMCU(ESP12E module). But in tools/programmer menu there is this message: no programmers available for this board .
I didn't find any solution on the forums.
Thanks for helping me.
Michel
No solution is needed.
The authors of the ESP8266 boards platform did not define any ISP programmers, so the Tools > Programmer menu being empty is normal and expected.
This is no problem at all. The Arduino IDE only uses this menu selection when you do the advanced "Burn Bootloader" or "Upload Using Programmer". Neither of those things are needed on the ESP8266. The "Tools > Programmer" menu selection is completely ignored when you do a standard "Upload" process, so you can use your ESP8266 without any need for a programmer.
Thanks for these useful answers but I can't compile any example.
I have this message:
exit status -1073741819
Erreur de compilation pour la carte NodeMCU 1.0 (ESP-12E Module)
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Post the code that caused the error. Read the forum guidelines to see how to properly post code and information on how to get the most from this forum.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Arduino : 1.8.19 (Windows 7), Carte : "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 16, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
There was a previous report about this error here:
The Arduino developer provided advice there:
it looks like a Windows10 filesystem error (File Error 1073740791 - Microsoft Q&A) . Try running
sfc /scannowin an Admin command shell to try fixing the filesystem.
I'am so sorry but i don't understand anything.
I've followed exactly the procedure of installation for ESP8266 and the compilation failed.
My system is Windows 7 (I know it's old). Why "it looks like a Windows 10 filesystem error"?
Do you think I should change my computer and buy a new system for working with ESP8266 ?
It would be a waste!
Did you consider following the advice provided?
Yes I did and the result was : No corruption is found.
I tried old programs i did with ESP32: all is right.
Hello the Forum
I can't compile any shetch on a NodeMcu module. Here after all the elements i've collected during my tries:
Blockquote
Arduino : 1.8.19 (Windows 7), Carte : "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
c:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\mornic\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\mornic\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Arduino sketches\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10819 -build-path C:\Users\mornic\AppData\Local\Temp\arduino_build_99085 -warnings=all -build-cache C:\Users\mornic\AppData\Local\Temp\arduino_cache_447383 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.python3.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mkspiffs.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -verbose C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\esp8266\examples\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\mornic\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\mornic\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Arduino sketches\libraries -fqbn=esp8266:esp8266:nodemcuv2:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,led=2,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10819 -build-path C:\Users\mornic\AppData\Local\Temp\arduino_build_99085 -warnings=all -build-cache C:\Users\mornic\AppData\Local\Temp\arduino_cache_447383 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.python3.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.mkspiffs.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -verbose C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\esp8266\examples\Blink\Blink.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Using core 'esp8266' from platform in folder: C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Detecting libraries used...
"C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\mornic\AppData\Local\Temp\arduino_build_99085/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\mornic\AppData\Local\Temp\arduino_build_99085\sketch\Blink.ino.cpp" -o nul
Generating function prototypes...
"C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include" "-IC:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include" "-IC:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\Users\mornic\AppData\Local\Temp\arduino_build_99085/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD="ESP8266_NODEMCU_ESP12E"" -DLED_BUILTIN=2 -DFLASHMODE_DIO -DESP8266 "-IC:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266" "-IC:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\variants\nodemcu" "C:\Users\mornic\AppData\Local\Temp\arduino_build_99085\sketch\Blink.ino.cpp" -o "C:\Users\mornic\AppData\Local\Temp\arduino_build_99085\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\mornic\AppData\Local\Temp\arduino_build_99085\preproc\ctags_target_for_gcc_minus_e.cpp"
Compilation du croquis...
"C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" -I "C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/signing.py" --mode header --publickey "C:\Users\mornic\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\esp8266\examples\Blink/public.key" --out "C:\Users\mornic\AppData\Local\Temp\arduino_build_99085/core/Updater_Signing.h"
Do you think there is a problem with the configuation of my PC ?
I have merged your cross-posts @mormic.
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please take some time to pick the forum category that best suits the subject of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide you will find at the top of every forum category. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
I understand what you wrote but the subjects are not exactly the same.
First i thought my problem was because "no programmer available for this board".
groundFungus explained me that it wasn't the problem.
Now, the problem in "No compilation at all for ESP8266". The problem is elsewhere.
If I keep the old subject, no body will answer.
