expected '}' before 'else'
I'm getting the error "expected '}' before 'else' in the following code. I'm sure it's something simple, but I can't figure it out. All of my braces line up.
Any suggestions?
int SSbuttonPress = 0;
int buttonTime;
int SSButtonPin;
int cycleDisplayFlag;
int lastState;
 // int checkButtons()
 int ssDebounceTime = 200;    //Set Debounce at 2 seconds for Start/Stop
 int cdDebounceTime = 25;      //and 25mS for cycle display
 int buttonPressed = 0;       //This is what will be returned. 1 for Start/Stop and 2 for Cycle Display
 noInterrupts();
 if (SSbuttonPress)           //Has the Start/Stop Button been pressed
  long int x = millis();
  long int y = x-buttonTime;
  int currentState = digitalRead(SSButtonPin);
  if (currentState);
   if (y >= cdDebounceTime)      //Has it been pressed for appropiate time
    cycleDisplayFlag = true;
    if (y >= 2000)
     cycleDisplayFlag = 0;    //If it's been pressed for more than 2 seconds then it's a start/stop situation.
     SSbuttonPress = 0;
     lastState = 0;
     buttonTime = 0;
     buttonPressed = 1;   //This means the The Start/Stop button has been pressed.
  else if(cycleDisplayFlag)   //If the cycle display flag is set and the button is no loger pressed then the Cycle Display Button has been pressed.
   buttonPressed = 2;
   lastState = 0;
   buttonTime = 0;
 //interrupts();
 //return(buttonPressed);
Here is your problem:
    if (currentState);
Thank you. Thank you! THANK YOU!
I knew it was something really simple.
