Arduino Temperature Controller
YouTube video: https://www.youtube.com/watch?v=nPQIjApehwk
Made by Daedalus
#include <Wire.h>
#include <DallasTemperature.h>
#define RELAY1 4 // Relay heating
#define RELAY2 6 // Relay cooling
int red = 8; // red LED heating
int blue = 2; // blue LED cooling
#define BACKLIGHT_PIN 13
#define ONE_WIRE_BUS 7
LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
int Serial;
sensors.begin();
lcd.begin(20, 4);
lcd.backlight();
pinMode(red, OUTPUT);
pinMode(blue, OUTPUT);
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
lcd.setCursor(0, 0);
lcd.print(" TEMP CONTROL");
sensors.requestTemperatures();
float temperature = sensors.getTempCByIndex(0);
lcd.setCursor(0, 2);
lcd.print(" ");
lcd.print(sensors.getTempCByIndex(0));
lcd.print("\337C");
if (temperature < 25) ////// Had a bogus ';' here
digitalWrite(red, HIGH);
digitalWrite(blue, LOW);
lcd.setCursor(0, 3);
lcd.print(" Heating");
digitalWrite(RELAY1, 0);
digitalWrite(RELAY2, 1);
else if (temperature > 25) ////// Had a bogus ';' here
digitalWrite(RELAY1, 1);
digitalWrite(RELAY2, 0);
digitalWrite(red, LOW);
digitalWrite(blue, HIGH);
lcd.setCursor(0, 4);
lcd.print(" Cooling ");
While I was trying to run the code for the thermal temperature sensor using the Arduino, I am receiving the error to initialize the Serial and along with that, it is also showing the error that the '}' should be before input. It was also showing the error that the "{ " should not be assigned after a function and I put it before the void loop. Can you guys provide me some suggestions to remove the error and help me !!!
