Expected initializer before setup
Hey, I always get this error:
/usr/local/bin/arduino-cli compile --fqbn esp8266:esp8266:d1_mini_pro:baud=921600,dbg=Disabled,eesz=16M14M,exception=disabled,ip=lm2f,lvl=None____,vt=flash,wipe=none,xtal=80 --libraries /home/builder/opt/libraries/latest --build-cache-path /tmp --output-dir /tmp/843741678/build --build-path /tmp/arduino-build-5AE03CAE92B301D6D7EE4053D2D87096 /tmp/843741678/Untitled_mar17a
Using library arduino_debugutils_1_1_0 at version 1.1.0 in folder: /home/builder/opt/libraries/arduino_debugutils_1_1_0
Using library arduinomqttclient_0_1_5 at version 0.1.5 in folder: /home/builder/opt/libraries/arduinomqttclient_0_1_5
/tmp/843741678/Untitled_mar17a/Untitled_mar17a.ino:20:23: error: expected initializer before 'setup'
bool wateringSuccess;
/tmp/843741678/Untitled_mar17a/Untitled_mar17a.ino:24:1: error: expected initializer before 'void'
/tmp/843741678/Untitled_mar17a/Untitled_mar17a.ino: In function 'void onMessageChange()':
/tmp/843741678/Untitled_mar17a/Untitled_mar17a.ino:65:38: error: request for member 'length' in 'charsOfMessage', which is of non-class type 'char [(((sizetype)<anonymous>) + 1)]'
for (int i = 0; i < charsOfMessage.length(); i++) {
/tmp/843741678/Untitled_mar17a/Untitled_mar17a.ino:66:31: error: request for member 'isDigit' in 'charsOfMessage[i]', which is of non-class type 'char'
if (not charsOfMessage[i].isDigit()) {
/tmp/843741678/Untitled_mar17a/Untitled_mar17a.ino:75:13: error: 'Message' was not declared in this scope
timer = Message.toInt();
/tmp/843741678/Untitled_mar17a/Untitled_mar17a.ino:93:42: error: request for member 'length' in 'charsOfMessage', which is of non-class type 'char [(((sizetype)<anonymous>) + 1)]'
/tmp/843741678/Untitled_mar17a/Untitled_mar17a.ino:94:35: error: request for member 'isDigit' in 'charsOfMessage[i]', which is of non-class type 'char'
/tmp/843741678/Untitled_mar17a/Untitled_mar17a.ino:96:36: error: invalid use of 'void'
if (message.toLowerCase().compareTo("stop") == 0) {
Error during build: exit status 1
I already double checked every bracket and semicolon, but I cant figure out my mistake...
  Sketch generated by the Arduino IoT Cloud Thing "Untitled"
  https://create.arduino.cc/cloud/things/6eb14f19-2a6f-4f0e-b2db-0fe1b122b32e
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  String message;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
int timer;
unsigned long currentMillis;
bool isNumber;
char testForDigit
  // Initialize serial and wait for port to open:
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(1500);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
     The following function allows you to obtain more information
     related to the state of network and IoT Cloud connection and errors
     the higher number the more granular information you’ll get.
     The default is 0 (only errors).
     Maximum is 4
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  pinMode(16, OUTPUT);
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);
  message = "started right now";
  ArduinoCloud.update();
  // Your code here
void onMessageChange()  {
  // check if String is a number
  isNumber = true;
  // convert string to char, so you can use .isDigit()
  char charsOfMessage[message.length()];
  message.toCharArray(charsOfMessage, message.length());
      isNumber = false;
  // code if mesage is a number
  if (isNumber) {
    // convert message to number
    // start loop, activate led and pin
    currentMillis = millis();
    digitalWrite(LED_BUILTIN, LOW);
    digitalWrite(16, HIGH);
    wateringSuccess = true;
    while (currentMillis > timer * 1000 + currentMillis) {
      yield();
      // check if changed message is string
          // if you send the stop message
            digitalWrite(16, LOW);
            wateringSuccess = false;
      //send back succes message
      if (wateringSuccess) {
        message = "watered successfully";
      else {
        message = "stopped successfully";
      /* if message is no number
        if(not isNumber){
        if(message.compareTo("HI") == 0){
          message = "HI";
I dont know what to do anymore.
Could you please help me troubleshooting?
Thanks!
@kaffemitmilf
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Thanks!
Im always dont know in which categorie I should place my questions, the categories are a bit overwhelming ^^
I tend to agree with you, there are too many. Only a small number get most of the questions.
Oops
Woops, someone beat me to it.
I sat on this for about 2 hours...
