expected initializer before '.' token
Hi there,
Trying to compile this "hello world" sketch from the arduino cookbook I get the message "expected initializer before '.' token".
I am newby in programming. Can somebody help me please?
LiquidCrystal Library - Hello World
Demonstrates the use of a 16 × 2 LCD display.
#include <LiquidCrystal.h> // include the library code
//constants for the number of rows and columns in the LCD
const int numRows = 2;
const int numCols = 16;
// initialize the library with the numbers of the interface pins LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
LiquidCrystal lcd.init()
LiquidCrystal lcd.begin(numCols, numRows);
LiquidCrystal lcd.print("hello, world!"); // Print a message to the LCD. }
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
LiquidCrystal lcd.setCursor(0, 1);
// print the number of seconds since reset:
LiquidCrystal lcd.print((millis) / 1000);
Expected code tag before "/*" token.
  lcd.init();
etc
Does the code in the book really look like that?
@AWOL, I guess that's a bit cryptic :slight_smile:
@MD1951
What are all those LiquidCrystal 'things' doing in your setup and loop?
  LiquidCrystal lcd.init();
This would declare a variable of type LiquidCrystal called lcd.init() (if it would compile). Get rid of the LiquidCrystal.
You're also missing a semi colon at the end of that line.
Go back to the cookbook and compare your code with the code that the book presented. If it's the same, feed the cookbook to the dogs, else fix the code.
MD1951:
Hi there,
AWOL:
  lcd.init();
etc
AWOL:
  lcd.init();
etc
Is there a question ?
