expected initializer before void
I'm new to the Arduino programming world. I'm just trying to get my ultrasonic sensor to activate the servo. So I pieced together 2 sketches, but when I uncomment these 2 lines I get errors that make no sense. "Initializer expected before void" Not very helpful.
int cm;
cm = microsecondsToCentimeters(duration);
// Program for using continuous rotation servos
#include <Servo.h> //this adds code to our program that defines what a Servo object is and can do
Servo amotor; // create a servo object to control a servo
int mspeed = 1500; // variable to store the motor speed
const int buttonPin = 2;     // the number of the pushbutton pin
int buttonState = 0;
const int pingPin = 13;
const int greenLed = 7;
//pin which delivers time to receive echo using pulseIn()
int inPin = 12;
//range in cm which is considered safe to enter, anything
//coming within less than 5 cm triggers red LED
int safeZone = 5;
//int cm;
  amotor.attach(9); // attaches the servo on pin 10 to the servo object amotor
  pinMode(buttonPin, INPUT);
  pinMode(greenLed, OUTPUT);
void loop(){
  //raw duration in milliseconds, cm is the
  //converted amount into a distance
  long duration, cm;
  pinMode(pingPin, OUTPUT);
//sending the signal, starting with LOW for a clean signal
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
//setting up the input pin, and receiving the duration in
  //microseconds for the sound to bounce off the object infront
  pinMode(inPin, INPUT);
  duration = pulseIn(inPin, HIGH);
  // convert the time into a distance
 // cm = microsecondsToCentimeters(duration);
  //printing the current readings to ther serial display
  Serial.print(cm);
  Serial.print("cm");
 //checking if anything is within the safezone, if not, keep
  //green LED on if safezone violated, activate red LED instead
  if (cm > safeZone)
  digitalWrite(greenLed, HIGH);
  mspeed = 1300; //set position variable
  amotor.writeMicroseconds(mspeed); // tell servo to move as indicated by  variable 'mspeed'
  delay(1000); //time for the servo to move
  mspeed = 1500; //set position variable
}/code]
(deleted)
Meanpplsuk - you have corrected the code in your original post which makes a nonsense of spycatcher's post. This is regarded as bad etiquette in the forum.
Although the code now compiles does it actually work ? What values do you get for cm ?
