Expected initializer before 'void'
Hello, I'm trying to make robot and getting the expected initializer before 'void' error when I try to upload.
// defines pins numbers
const int trigPin = 9;
const int echoPin = 10;
const int(motor1pin2)
  // Clears the trigPin
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  // Sets the trigPin on HIGH state for 10 micro seconds
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Reads the echoPin, returns the sound wave travel time in microseconds
  duration = pulseIn(echoPin, HIGH);
  // Calculating the distance
  distance = duration * 0.034 / 2;
 safetyDistance = distance;
if (safetyDistance <= 5){
  digitalWrite(motor1pin2, LOW);
  digitalWrite(motor1pin1, HIGH);
else{
  digitalWrite(motor1pin2, HIGH);
  digitalWrite(motor1pin1, LOW);
  digitalWrite(motor2pin2, LOW);
  digitalWrite(motor2pin1, HIGH);
Incomplete code.
You are missing setup(), and the braces in the loop function are not matched. Some pin definitions are missing.
Are you missing ; something ?
why not start with just trying to read the distance sensor and printing the value on the Serial monitor?
then add some code the prints something (e.g. "stop") when the distance is close?
then add code to run the motor if not close and stop the motor if close?
looks like you're trying to turn the robot by running each motor in opposite directions, but i don't see any code to stop turning or even stop both motors
No it tells the robot to go backward because of motor polarity.
looks like you're have 2 motors. do both motors need to be reversed?
I added mor pin definitions and now I'm getting exit status 1
expected constructor, destructor, or type conversion before 'int' on the const int trigPin = 9;
setup()
const int(motor1pin1)
const int(motor2pin1)
const int(motor2pin2)
  digitalWrite(motor2pin1, LOW);
  digitalWrite(motor2pin2, HIGH);
else{
No { or } in setup()
No ; after the last 4 lines of setup()
Yes.
Here is a complete Arduino program that compiles without errors. Start there and have fun.
isn't the above the same as
won't this just result in the robot moving back and forth in front of some obstacle? why not turn while reversing?
const int motor1pin2 = 2;
const int motor2pin2= 3;
const int motor1pin1 = 4;
const int motor2pin1= 5;
int distance, duration, safetyDistance;
void setup(){
pinMode(tripPin,OUTPUT);
pinMode(echoPin,INPUT);
pinMode(motor1pin1,OUTPUT);
pinMode(motor1pin2,OUTPUT);
pinMode(motor2pin1,OUTPUT);
pinMode(motor2pin2,OUTPUT);
else{
Hi, @snoopybeach
It looks like you have wrtten your code as one big proceedure.
Can I suggest you forget your code for the moment AND write some code that JUST makes the motors run back and forth at 5 second intervals.
You need to get your motor control done first BEFORE adding ultrasonics etc.
A schematic would help as we do not even know ;
What Arduino controller your are using.
What type of motor controller you are using.
What the motor specs are.
What you are using for a power supply.
Thanks.. Tom.. :grinning: :+1: :coffee: :australia:
Thanks!
