expected primary-expression before '(' token
it is adafruit example
Original example configure at the start up with predefined server name port etc
Now I have change if (subscription == openClose->subscribe)
to
if (subscription == openClose) since mqtt is a pointer
compiler runs and doesn't give any error on the code. it is now complaining about the boad
Error compiling for board Generic ESP8266 Module.
I am really confused
hope you can help
this is the original code
// LED will blink when in config mode
#include <WiFiManager.h> // https://github.com/tzapu/WiFiManager
//for LED status
#include <Ticker.h>
Ticker ticker;
#if defined(ESP8266)
#include <ESP8266WiFi.h>          //https://github.com/esp8266/Arduino
#else
#include <WiFi.h>
#endif
/*#include <ESPAsyncWebServer.h>
#include <ESPAsyncTCP.h>
#include <Hash.h>
#include <FS.h>*/
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
//#define WIFI_SSID "<WiFi-F4B0>"
//#define WIFI_PASS "<49491500>"
/*#define MQTT_SERV "io.adafruit.com"
#define MQTT_PORT 1883
#define MQTT_NAME "behmadi"
#define MQTT_PASS "aio_hitc98ZLeJQLX5hX0SO1iZAoikz9" */
#define MQTT_NAME "abc"
#define MQTT_PASS "XXXX"
//String MQTT_PORT = String(MQTT_PORT_C);
//int test = MQTT_PORT.toInt();
#ifndef LED_BUILTIN
#define LED_BUILTIN 13 // ESP32 DOES NOT DEFINE LED_BUILTIN
#endif
int LED = LED_BUILTIN;
int ledPin = 12;
//const char* WIFI_SSID =  "WiFi-F4B0"; //"AndroidAPC616";
//const char* WIFI_PASS = "49491500"; //"brmc3813";
//Set up MQTT and WiFi clients
WiFiClient client;
Adafruit_MQTT_Client mqtt(&client, MQTT_SERV, MQTT_PORT, MQTT_NAME, MQTT_PASS);
//Set up the feed you're subscribing to
Adafruit_MQTT_Subscribe OpenClose = Adafruit_MQTT_Subscribe(&mqtt, MQTT_NAME "/f/OpenClose");
void tick()
  //toggle state
  digitalWrite(LED, !digitalRead(LED));     // set pin to the opposite state
//gets called when WiFiManager enters configuration mode
void configModeCallback (WiFiManager *myWiFiManager) {
  Serial.println("Entered config mode");
  Serial.println(WiFi.softAPIP());
  //if you used auto generated SSID, print it
  Serial.println(myWiFiManager->getConfigPortalSSID());
  //entered config mode, make led toggle faster
  ticker.attach(0.2, tick);
  WiFi.mode(WIFI_STA); // explicitly set mode, esp defaults to STA+AP
  //set led pin as output
  pinMode(LED, OUTPUT);
  // start ticker with 0.5 because we start in AP mode and try to connect
  ticker.attach(0.6, tick);
  //WiFiManager
  //Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wm;
  //reset settings - for testing
  // wm.resetSettings();
  //set callback that gets called when connecting to previous WiFi fails, and enters Access Point mode
  wm.setAPCallback(configModeCallback);
  //fetches ssid and pass and tries to connect
  //if it does not connect it starts an access point with the specified name
  //here  "AutoConnectAP"
  //and goes into a blocking loop awaiting configuration
  if (!wm.autoConnect()) {
    Serial.println("failed to connect and hit timeout");
    //reset and try again, or maybe put it to deep sleep
    ESP.restart();
  //if you get here you have connected to the WiFi
  Serial.println("connected...yeey :)");
  ticker.detach();
  //keep LED on
  digitalWrite(LED, LOW);
  pinMode(ledPin, OUTPUT);
  /*//Connect to WiFi
  Serial.print("\n\nConnecting Wifi... ");
  WiFi.begin(WIFI_SSID, WIFI_PASS);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print (".");
  Serial.println("OK!");
  //Subscribe to the onoff feed
  mqtt.subscribe(&OpenClose);
  digitalWrite(ledPin, HIGH);
  MQTT_connect();
  //Read from our subscription queue until we run out, or
  //wait up to 5 seconds for subscription to update
  Adafruit_MQTT_Subscribe * subscription;
  while ((subscription = mqtt.readSubscription(5000)))
    //If we're in here, a subscription updated...
    if (subscription == &OpenClose)
      //Print the new value to the serial monitor
      Serial.print("openClose: ");
      Serial.println((char*) OpenClose.lastread);
      //If the new value is  "ON", turn the light on.
      //Otherwise, turn it off.
      if (!strcmp((char*) OpenClose.lastread, "ON"))
        //Active low logic
        digitalWrite(ledPin, LOW);
  // ping the server to keep the mqtt connection alive
  if (!mqtt.ping())
    mqtt.disconnect();
  Adafruit MQTT Library ESP8266 Example
  Must use ESP8266 Arduino from:
  Works great with Adafruit's Huzzah ESP board & Feather
  ----> https://www.adafruit.com/product/2471
  ----> https://www.adafruit.com/products/2821
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Tony DiCola for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
void MQTT_connect()
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected())
    return;
  Serial.print("Connecting to MQTT... ");
  uint8_t retries = 3;
  while ((ret = mqtt.connect()) != 0) // connect will return 0 for connected
       Serial.println(mqtt.connectErrorString(ret));
       Serial.println("Retrying MQTT connection in 5 seconds...");
       mqtt.disconnect();
       delay(5000);  // wait 5 seconds
       retries--;
       if (retries == 0)
         // basically die and wait for WDT to reset me
         while (1);
  Serial.println("MQTT Connected!");
Post the code. Copy and paste the error too.
aarg:
I'm saying that "void setup" or "void loop" are improper names for functions. They aren't "voids", they are functions that return a void type don't return any value.
Wildbill this is the latest one
#include <FS.h>
#else
#include <WiFi.h>
#endif
//for LED status
#include <Ticker.h>
Ticker ticker;
//needed for library
#include <DNSServer.h>
#include <ESPAsyncWiFiManager.h>
#include <ArduinoJson.h>
#include <stdio.h>
#include <string.h>
char MQTT_SERV[40] = "io.adafruit.com";
char MQTT_PORT_C[6] = "1883";
char MQTT_NAME[20] = "ABC";
char MQTT_PASS[33] = "XXX";
char static_ip[16] = "";
char static_gw[16] = "";
char static_sn[16] = "";
WiFiClient client;
void MQTT_connect();
Adafruit_MQTT_Client *mqtt;
Adafruit_MQTT_Subscribe *openClose;
//unsigned int mqtt_port = atoi (MQTT_PORT_C);
//char* mqtt_serv = MQTT_SERV;
//char* mqtt_name = MQTT_NAME;
//char* mqtt_pass = MQTT_PASS;
//#define mqtt_port 1883
//#define mqtt_serv "my server"
//#define mqtt_name "my name"
//#define mqtt_pass "my pass"
#ifndef LED_BUILTIN
#endif
int ledPin = 12;
//flag for saving data
bool shouldSaveConfig = false;
AsyncWebServer server(80);
DNSServer dns;
void tick()
  //toggle state
//callback notifying us of the need to save config
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
void Read_Config() {
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(MQTT_SERV, json["MQTT_SERV"]);
          strcpy(MQTT_PORT_C, json["MQTT_PORT_C"]);
          strcpy(MQTT_NAME, json["MQTT_NAME"]);
          strcpy(MQTT_PASS, json["MQTT_PASS"]);
          if (json["ip"]) {
            Serial.println("setting custom ip from config");
            //static_ip = json["ip"];
            strcpy(static_ip, json["ip"]);
            strcpy(static_gw, json["gateway"]);
            strcpy(static_sn, json["subnet"]);
            //strcat(static_ip, json["ip"]);
            //static_gw = json["gateway"];
            //static_sn = json["subnet"];
            Serial.println(static_ip);
            Serial.println("no custom ip in config");
          Serial.println("failed to load json config");
        configFile.close();
    Serial.println("failed to mount FS");
  //end read
void Save_Cust_Para() {
  if (shouldSaveConfig) {
    Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    //DynamicJsonDocument json(1024);
    json["MQTT_SERV"] = MQTT_SERV;
    json["MQTT_PORT_C"] = MQTT_PORT_C;
    json["MQTT_NAME"] = MQTT_NAME;
    json["MQTT_PASS"] = MQTT_PASS;
    json["ip"] = WiFi.localIP().toString();
    json["gateway"] = WiFi.gatewayIP().toString();
    json["subnet"] = WiFi.subnetMask().toString();
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.prettyPrintTo(Serial);
    //serializeJson(json, Serial);
    json.printTo(configFile);
    configFile.close();
    //end save
  Serial.println("mounting FS...");
  Read_Config();
  Serial.println(MQTT_NAME);
  Serial.println(MQTT_SERV);
  Serial.println(MQTT_PASS);
  AsyncWiFiManagerParameter custom_MQTT_SERV("server", "mqtt server", MQTT_SERV, sizeof(MQTT_SERV));
  AsyncWiFiManagerParameter custom_MQTT_PORT_C("port", "mqtt port", MQTT_PORT_C, 6);
  AsyncWiFiManagerParameter custom_MQTT_NAME("name", "mqtt name", MQTT_NAME, sizeof(MQTT_NAME) );
  AsyncWiFiManagerParameter custom_MQTT_PASS("pass", "mqtt pass", MQTT_PASS, sizeof(MQTT_PASS));
  AsyncWiFiManager wifiManager(&server, &dns);
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  //set static ip
  IPAddress _ip, _gw, _sn;
  _ip.fromString(static_ip);
  _gw.fromString(static_gw);
  _sn.fromString(static_sn);
  wifiManager.setSTAStaticIPConfig(_ip, _gw, _sn);
  //add all your parameters here
  wifiManager.addParameter(&custom_MQTT_SERV);
  wifiManager.addParameter(&custom_MQTT_PORT_C);
  wifiManager.addParameter(&custom_MQTT_NAME);
  wifiManager.addParameter(&custom_MQTT_PASS);
  wifiManager.setMinimumSignalQuality();
  if (!wifiManager.autoConnect("AutoConnectAP", "password")) {
    delay(3000);
    ESP.reset();
    delay(5000);
  ticker.detach();
  strcpy(MQTT_SERV, custom_MQTT_SERV.getValue());
  strcpy(MQTT_PORT_C, custom_MQTT_PORT_C.getValue());
  strcpy(MQTT_NAME, custom_MQTT_NAME.getValue());
  strcpy(MQTT_PASS, custom_MQTT_PASS.getValue());
  String S_MQTT_NAME(MQTT_NAME);
  char* feed = "/f/openClose";
  //int mqtt_name_len = S_MQTT_NAME.length() + feed.length() +1;
  char* mqtt_name;
  strcpy(mqtt_name, MQTT_NAME);
  strcat(mqtt_name, feed);
  puts(mqtt_name);
  mqtt = new Adafruit_MQTT_Client(&client, mqtt_serv, mqtt_port, mqtt_name, mqtt_pass);
  openClose = new Adafruit_MQTT_Subscribe(mqtt, mqtt_name );
  Save_Cust_Para();
  Serial.println("local ip");
  Serial.println(WiFi.gatewayIP());
  Serial.println(WiFi.subnetMask());
  mqtt->subscribe(openClose);
  MQTT_connect();
  while ((subscription = mqtt->readSubscription(5000)))
      Serial.println((char*) openClose->lastread);
      if (!strcmp((char*) openClose->lastread, "ON"))
        //Active low logic
  if (!mqtt->ping())
    mqtt->disconnect();
void MQTT_connect()
  int8_t ret;
  if (mqtt->connected())
    return;
  while ((ret = mqtt->connect()) != 0)
    Serial.println(mqtt->connectErrorString(ret));
    mqtt->disconnect();
    retries--;
    if (retries == 0)
      while (1);
  char* mqtt_name;
  strcpy(mqtt_name,MQTT_NAME);
  strcat(mqtt_name,feed);
  puts(mqtt_name);
Your pointer mqtt_name is uninitialized. You need to allocate some space...
char mqtt_name[20];
I am still getting the same error with
char mqtt_name[20];
or
char* mqtt_name;
exit status 1
That's what it says at the very end of the list of compilation errors. The useful information is above it.
Error file is too big.
I have attached it
errorfile.txt (27.6 KB)
That was silly. I always though error is the last line. I started looking at the error file and I have big problems.
thanks wildbill to pointing it out
Thank you Wildbill
you really put me in right directions
looking at the error file really opened a lots of door. I had duplicate declaration because of incompatible librarys
I wish I knew about error file before.
All fixed and it is compiled.
I check how it is running and let you know
After all these issue, code loaded fine,
Just found out SPIFFSEditor only except per defined up to 3 parameter.
this is so pain full.
wildbill, do you how to add an extra parameter for my mqtt_name
i have some idea but won't be clean by combining name and token and then split it before passing to adafruit
Thanks
Behzad
Hi there,
I have decided t build the project again from scratch and see where would be the error.
code is now just reading config files using WiFiManager. config file.
//for LED status
#include <Ticker.h>
Ticker ticker;
#ifndef LED_BUILTIN
#endif
//define your default values here, if there are different values in config.json, they are overwritten.
//length should be max size + 1
char mqtt_server[40];
char mqtt_port[6] = "8080";
char blynk_token[70] = "YOUR USERNAME,TOKEN";
//default custom static IP
char static_ip[16] = "10.0.1.56";
char static_gw[16] = "10.0.1.1";
char static_sn[16] = "255.255.255.0";
//adafruit mqtt parameters
void tick()
  //toggle state
void Read_config(){
  //clean FS, for testing
  //SPIFFS.format();
  //read configuration from FS json
      if (configFile) {
          strcpy(mqtt_server, json["mqtt_server"]);
          strcpy(mqtt_port, json["mqtt_port"]);
          strcpy(blynk_token, json["blynk_token"]);
          if (json["ip"]) {
            /*            Serial.println("converting ip");
                        IPAddress ip = ipFromCharArray(static_ip);
                        Serial.println(ip);*/
  //end read
  Read_config();
  Serial.println(blynk_token);
  Serial.println(mqtt_server);
  // The extra parameters to be configured (can be either global or just in the setup)
  // After connecting, parameter.getValue() will get you the configured value
  // id/name placeholder/prompt default length
  WiFiManagerParameter custom_mqtt_server("server", "mqtt server", mqtt_server, 40);
  WiFiManagerParameter custom_mqtt_port("port", "mqtt port", mqtt_port, 5);
  WiFiManagerParameter custom_blynk_token("blynk", "user name, blynk token", blynk_token, 70);
  //WiFiManager
  WiFiManager wm;
//set static ip
  wm.setSTAStaticIPConfig(_ip, _gw, _sn);
  wm.addParameter(&custom_mqtt_server);
  wm.addParameter(&custom_mqtt_port);
  wm.addParameter(&custom_blynk_token);
  //wifiManager.resetSettings();
  //set minimu quality of signal so it ignores AP's under that quality
  //defaults to 8%
  wm.setMinimumSignalQuality();
  //sets timeout until configuration portal gets turned off
  //useful to make it all retry or go to sleep
  //in seconds
  //wifiManager.setTimeout(120);
  if (!wm.autoConnect("AutoConnectAP")) {
    ESP.restart();
    delay(5000);
  ticker.detach();
  //keep LED on
  //read updated parameters
  strcpy(mqtt_server, custom_mqtt_server.getValue());
  strcpy(mqtt_port, custom_mqtt_port.getValue());
  strcpy(blynk_token, custom_blynk_token.getValue());
  //save the custom parameters to FS
    json["mqtt_server"] = mqtt_server;
    json["mqtt_port"] = mqtt_port;
    json["blynk_token"] = blynk_token;
    if (!configFile) {
    configFile.close();
    //end save
  //Star seting up MQTT Adafruit_MQTT_Client
  unsigned int MQTT_PORT = atoi (mqtt_port);
  char* MQTT_SERV = mqtt_server;
  //int init_size = strlen(blynk_token);
  //char* MQTT_NAME_LEN = strchr(blynk_token , ',');
  //char* MQTT_NAME = blynk_token.substring(0, MQTT_NAME_LEN-blynk_token+1);
  //char* MQTT_PASS = blynk_token.substring(MQTT_NAME_LEN-blynk_token+2 , init_size);
  char *strings[2];
  char *ptr = NULL;
  byte index = 0;
  ptr = strtok(blynk_token, ",");  // takes a list of delimiters
  while (ptr != NULL)
    strings[index] = ptr;
    index++;
    ptr = strtok(NULL, ",");  // takes a list of delimiters
  char* MQTT_NAME = strings[0];
  char* MQTT_PASS = strings[1];
  char* MQTT_NAME_FEED;
  strcpy(MQTT_NAME_FEED, MQTT_NAME);
  strcat(MQTT_NAME_FEED, feed);
  puts(MQTT_NAME_FEED);
  Serial.println("adafruit config");
  Serial.println(MQTT_PORT);
  Serial.println(MQTT_NAME_FEED);
it complies ok and run well until I press save on the AP then it just print series of hex code over and over again I am posting one cycle of serial output file is one cycle after the last line start from top
I have to wait 5 minutes before I can post again
ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3664, room 16
tail 0
chksum 0xee
csum 0xee
vcc1cc0b2
~ld
mounting FS...
mounted file system
reading config file
opened config file
{"mqtt_server":"Servername","mqtt_port":"8080","blynk_token":"Myname,2456fghjhvfdddfggh","ip":"10.0.1.56","gateway":"10.0.1.1","subnet":"255.255.255.0"}
parsed json
10.0.1.56
10.0.1.56
Servername
*WM: [3] allocating params bytes: 20
*WM: [2] Added Parameter: server
*WM: [2] Added Parameter: port
*WM: [2] Added Parameter: blynk
*WM: [1] AutoConnect
*WM: [2] Connecting as wifi client...
*WM: [3] STA static IP: 10.0.1.56
*WM: [2] Custom static IP/GW/Subnet/DNS
*WM: [2] Custom STA IP/GW/Subnet
*WM: [1] STA IP set: 10.0.1.56
*WM: [1] Connecting to SAVED AP: WiFi-F4B0
*WM: [3] Using Password: 49*****
*WM: [3] WiFi station enable
*WM: [3] enableSTA PERSISTENT ON
*WM: [1] connectTimeout not set, ESP waitForConnectResult...
*WM: [2] Connection result: WL_CONNECTED
*WM: [3] lastconxresult: WL_CONNECTED
*WM: [1] AutoConnect: SUCCESS
*WM: [1] STA IP Address: 10.0.1.56
connected...yeey :)
local ip
10.0.1.56
10.0.1.1
255.255.255.0
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Exception (29):
epc1=0x4021f387 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffb70 end: 3fffffc0 offset: 0190
3ffffd00:  3ffe88d0 00ffffff 0101000a 4021b994
3ffffd10:  3ffe88d0 00001f90 3ffeef08 40202e8f
3ffffd20:  00000000 00000000 3fff07bc 3fff07bf
3ffffd30:  3fff07c0 3fff0794 3fff07a4 3fff07a4
3ffffd40:  3fff07ac 3fff07b8 3fff07b8 4021a540
3ffffd50:  00000000 4021a540 00000000 4021a540
3ffffd60:  00000000 4021a540 3801000a 4021a540
3ffffd70:  0101000a 4021a540 00ffffff 4021a540
3ffffd80:  00000000 feef5035 6e2d6f6e fe007465
3ffffd90:  86efeffe feefef00 feefeffe 80efeffe
3ffffda0:  feefef00 feefeffe 80efeffe feefef00
3ffffdb0:  feefeffe 80efeffe 00000000 00000000
3ffffdc0:  00000000 00000000 00000000 00000001
3ffffdd0:  00505345 feefeffe 83efeffe feefef03
3ffffde0:  00000000 00000000 00000000 000007d0
3ffffdf0:  00010000 00000000 0050ef00 feefef07
3ffffe00:  00000008 00000000 00000000 01000001
3ffffe10:  00010101 01010001 feef0100 3ffe86ea
3ffffe20:  3ffe86ea feefef00 feefeffe 80efeffe
3ffffe30:  feef0001 00007530 feefef00 feefef00
3ffffe40:  feefeffe 80efeffe feef0100 00000000
3ffffe50:  feef0100 00000000 00000003 00000005
3ffffe60:  3fff07c4 feef0301 3ffeef08 40201264
3ffffe70:  3ffe8538 40219810 402197fc feefeffe
3ffffe80:  feefeffe 00000000 feefeffe feefeffe
3ffffe90:  feefeffe 00000000 feefeffe feefeffe
3ffffea0:  feefeffe 00000000 feefeffe feefeffe
3ffffeb0:  feefeffe 00000000 feefeffe feefeffe
3ffffec0:  feefeffe 00000000 feefeffe 3ffe8548
3ffffed0:  3ffe854f 40219810 402197fc feefeffe
3ffffee0:  feefeffe feefeffe feefeffe feefeffe
3ffffef0:  3ffe8831 3ffe8837 3fff0744 00000046
3fffff00:  00000001 3ffe86ea 3ffe882c 3ffe8827
3fffff10:  3fff0734 00000005 00000001 3ffe86ea
3fffff20:  3ffe8820 3ffe881b 3fff0704 00000028
3fffff30:  00000001 3ffe86ea 4021a540 0101000a
3fffff40:  feefeffe feefeffe 4021a540 3801000a
3fffff50:  feefeffe feefeffe feefeffe feefeffe
3fffff60:  feefeffe 4021a540 00ffffff 4021a540
3fffff70:  0101000a 4021a540 3801000a feefeffe
3fffff80:  feefeffe feefeffe 3ffe854f feefeffe
3fffff90:  feefeffe feefeffe feefeffe 3ffef03c
3fffffa0:  3fffdad0 00000000 3ffeeff8 402109b0
3fffffb0:  feefeffe feefeffe 3ffe85ac 40100ced
<<<stack<<<
A string pointer, not initialized to anything.
Writing to random memory, whatever the uninitialised string pointer happens to be pointing at.
I showed you how to allocate a buffer for this properly in an earlier post. See #45
I couldn't believe it pcbpc. I had to try it several times. such a small thing created a big headache
thanks a lot
Thanks to pcbbc, wildbill and PaulMurrayCbr.
your contribution and help resolve the issue. it was combinations of lib conflict , bad coding and not being familiar with Arduino.
Cheers guys I am closing this post
The issue is now back
OP1= new Adafruit_MQTT_Subscribe(mqtt, MQTT_FEED1);
I have been trying to construct MQTT_FEED to include account name and feed
account name is uploaded from WiFiconfig in to string(0).
  WiFiClient client;
  Adafruit_MQTT_Subscribe *OP1;
void setup () {
  char *strings[2];
  string[0] = "behmadi"
  const char* MQTT_NAME  = strings[0];
  const char* feed1 =  "/feeds/op1";
  char MQTT_NAME_FEED1[20] = "\0";
  strcat(MQTT_NAME_FEED1,MQTT_NAME);
  strcat(MQTT_NAME_FEED1,feed1);
  delay(200);
  String s1((const __FlashStringHelper*) MQTT_NAME_FEED1);
  const char* MQTT_FEED1 = s1.c_str();
   Serial.println(MQTT_FEED1); //"prints -- behmadi/feeds/op1 ---- in serial monitor
   mqtt = new Adafruit_MQTT_Client(&client, MQTT_SERV, MQTT_PORT, MQTT_NAME, MQTT_PASS);
   OP1 = new Adafruit_MQTT_Subscribe(mqtt, MQTT_NAME_FEED1);
   mqtt->subscribe(OP1);
I have tried many ways combining the two, all attempt resulted the combined "behmadi/feeds/op1" in my serial print.
My IO dashboard displays
"MQTT ERROR: rejected, not a valid topic format"
or
"MQTT ERROR: aedes_FNQbOxBN9C9T 60.240.148.110 PUBLISH to topic rejected, topic is not a recognized format"
if I change " const char* MQTT_FEED1 = s1.c_str(); " line in above code to "const char* MQTT_FEED1 = "behmadi/feeds/op1;"
it works perfectly
if I use "OP1= new Adafruit_MQTT_Subscribe(mqtt, MQTT_NAME "/feeds/op1"); it results in compile error "expected ')' before string constant"
anyone knows how to construct this to include username and feed
You seem to be tying yourself in an awful mess...
// no idea what this array is for since you are just populating it with a pointer to one static string
  char *strings[2];
// missing semicolon
// why do you need this variable? Anywhere you want this just write strings[0] or indeed "behmadi"
// why do you need this variable...
// just write strcat(MQTT_NAME_FEED1, "/feeds/op1"); here
  delay(200);
// no idea what this nonsense is all about. No strings in flash here...
// as far as I can see Serial.println(MQTT_NAME_FEED1); would have been fine
// my guess is there is probably something important here you don’t show us
// or just that the whole unfathomable mess above broke something
This really isn’t rocket science. Define some char[] buffers of suitable size, copy the strings you want into them with strcpy and/or strcat, call the required functions.
And why you feel the need to use the same names for the parameters (all upper case) when the are no longer #defines is beyond me.
But anyway, why not just...
mqtt = new Adafruit_MQTT_Client(&client, MQTT_SERV, MQTT_PORT,  "behmadi", MQTT_PASS);
OP1 = new Adafruit_MQTT_Subscribe(mqtt,  "behmadi/feeds/op1");
Yes, this syntax only works when you have...
Because it then effectively becomes...
OP1= new Adafruit_MQTT_Subscribe(mqtt, "behmadi" "/feeds/op1");
Which the compiler then treats as...
OP1= new Adafruit_MQTT_Subscribe(mqtt, "behmadi/feeds/op1");
But you cannot combine runtime strings this way.
Thanks for your reply
username is from
  WiFiManagerParameter custom_blynk_token("blynk", "user name,blynk token", blynk_token, 70);
when configured, custom_blynk_token has both username and token
once they get separated in to const char* MQTT_NAME and char* MQTT_PASS
MQTT_NAME need to be combined to /feeds/op1
MQTT_NAME works in (eg:behmadi")
and connects to adafruit IO
why can't be combined to /feeds/op1 to create
I need to enter log in as different username
