Experiencing an "else' without a previous 'if'" problem. when it has an 'if'
I'm experiencing an error I couldn't fix and I need help on how to just correct the error.
So as you can see from the title, I'm experiencing an "else' without a previous 'if'" problem.
and I am having this error on the 2nd last line where it says...
"else digitalWrite(LED, LOW); // Turn the LED off"
Thank You in Advance for the help.
ALARM_SYSTEM..ino (646 Bytes)
read this please;
Syntax problem. Your current code:
if(digitalRead(sensor)== HIGH);
    delay(5000);                           // 5 Seconds Before Alarm Sounds
             {if(digitalRead(sensor)== HIGH);
                digitalWrite(LED, HIGH);   // Turn the LED on
makes no sense. Do you understand the use of '{' and '}'?
What do you want to happen if "sensor" is high?
Something like this?
More studying of the language required.
