Experiencing the following error , need help
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_loadaddr(): (a) protocol error, expect=0x14, resp=0x10
avrdude: stk500_paged_load(): (a) protocol error, expect=0x14, resp=0x04
avrdude: stk500_cmd(): programmer is out of sync
avr_read(): error reading address 0x0000
    read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x04
option enabled in File -> Preferences.
help please
As advised in the end of upload - check the options in the `File ->Preferences
"Show verbose output during compilation" and "Show verbose output during upload"
Try checking if you have the correct board selected, if not select it. If you do then try powering everything down and then reboot.
