export hex
Hi
is it posible to get a ide code exported to hex for programming with alternative programmers
or even to get code like blinking LED to avg-Gcc arvstudio to bring it on a Atiny without learning C++
bmbbsr:
Sure. Do this:
  • (In the Arduino IDE) Open the sketch you want to compile.
  • Select the board you want to compile for from the Tools > Board menu. Note that the .hex file is going to be compiled for this specific target and may not work correctly if you program it to a microcontroller running at a different clock speed or using a different microcontroller.
  • Sketch > Export Compiled Binary
  • Wait for the compilation to finish.
  • Sketch > Show sketch folder. You will find the .hex file in the folder that opens.
bmbbsr:
I don't know what you mean by that. Please provide a more detailed explanation. You can find pre-written blink programs written in C++, C, or assembly online if you don't want to learn to write it yourself.
