extending PCB tactile momentary buttons through panel
Ive just finished building the case for my project and mounting all the hardware, the only problem i have is the LCD shelid buttons are below the level of the panel, so you need a pin or pen tip to use them. Can you get button extenders for the PCB mounted tactile momentary switches. I know you can get longer ones but i didn't want to have to de-solder them and swap them over if i don't need to. I was going to try a small piece of tube maybe held on with a blob of glue? Any other suggestions. Below is the link to the LCD sheild i'm using with the buttons on. https://sites.google.com/a/gridshield.net/experimentos-en-hardware-libre/home/lcd-keypad-shield-test
There are extenders for those that look like small top hats but they need to fit under a faceplate (presume that is what you have)
3D printing also comes in useful for those as there are lots of pre made designs out there F.O.C.
Or a drop of super glue to mount some small extenders of your own making eg wooden dowel etc.
Maybe one of these with epoxy.
https://www.google.com/search?q=push+button+switch+caps&tbm=isch&ved=2ahUKEwiehdj7mo_rAhWY6J4KHbQEBb0Q2-cCegQIABAC&oq=push+button+switch+caps&gs_lcp=ChJtb2JpbGUtZ3dzLXdpei1pbWcQAzICCAA6BAgeEAo6BAgAEBg6BggAEAgQHjoGCAAQBRAeUM0hWJBDYP5GaABwAHgAgAFZiAHiB5IBAjEzmAEAoAEBwAEB&sclient=mobile-gws-wiz-img&ei=Dn4wX57GE5jR-wS0iZToCw&bih=719&biw=1112&prmd=sivn&rlz=1C9BKJA_enCA902CA902&hl=en-US
However, suggest you solder these in parallel:
