Hello everyone, I can't figure out why the external interrupt via the attachinterrupt() function on my arduino uno is not working. I'm using a National Instruments card to send the arduino an analog TTL (5V) pulse into digital pin 2 or 3. Per the instructions, I am using the 0 interrupt designation for digital pin 2. I've tried using pin 3 as well. Even the example code provided in the reference doesn't work. Reference code: http://arduino.cc/en/Reference/AttachInterrupt
Are there some special requirements for the TTL pulse? Any thoughts? I'm stumped.
Without wiring drawings and your sketch posted how are we to tell why it's not working for you? We can state that attachinterrupt command does function as designed when both the hardware and software is properly done. Did you wire a common ground from the NiQaq to the arduino? Are you relying on another interrupt to force you out of your ISR function? Interrupts are a powerful feature of the arduino platform, but many details must be correct to get useful results.
