Hi everyone. I am very new to the world of microcontrollers so I barely know anything. I have a quick question: Is a 9.6V 2000mAh battery ok to power my arduino uno board? And I would just have to connect the ground and the positive wires directly into the arduino ground and Vin pins right? I want to make sure before I do it so as not to burn up my board. Thank you for taking your time to help out a complete noob.
It all depends what is connected to the board , a few servos or relays will draw more than 10 LED's (depending on type of LED ![]()
Add up all what is connected for a particular project and you can compare it to the battery.
Thanks a lot for the help. I really appreciate it.
amateur:
Yes, it will work...depending on what you're going to connect to it. If you try to suck maximum current out of every Arduino pin then you might run into problems.
PS: Poking a wire into the Vin connector will work but you'll get a much solid connection with a proper power connector plug.
