program stops after disconnecting from computer
i have a new arduino uno and a i noticed that the program stops after disconnecting from computer.
i am programing it on a mac 10.6 and powering it with a 9 volt rechargeable battery by makeing this Arduino Playground - 9VBatteryAdapter
has someone had this problem before?
Other than a 9 V battery, what is connected to the board?
legoaceking:
i am programing it on a mac 10.6 and powering it with a 9 volt rechargeable battery by makeing this http://www.arduino.cc/playground/Learning/9VBatteryAdapter
With the arduino unplugged from USB but with battery plugged in measure the voltage between the Vin pin and ground pin and tell us what you read. I suspect you have too low a battery voltage. Those small 9vdc batteries are almost useless for arduino useage as they have very low current capacity.
Lefty
after disconnecting from the computer just the 9 volt battery.
in the program i use the led connected to pin 13.
how much voltage does the Arduino uno use?
In your case, it is not a question of voltage (9 V is fine) it is a question of current. A 9 V battery has very little to offer.
@retrolefty's test will determine if you are trying to draw too much current from your battery. It will also determine if the battery is near dead.
before i did that i noticed that the 9 volt rechargeable battery that i was using did not give off 9 volts.
on the battery itself it said below 9 volt part in small text "7.2V-150" mAh.
can someone tell me how much power the arduino uno needs?
legoaceking:
After having to go through the series polarity protection diode, 7.2vdc is just at the threshold of the auto-voltage selection function for the board. I would suggest that one needs at least 7.5vdc at the external power connector to reliably trigger the board's auto-voltage selector switch.
So you need a higher voltage if you want to utilize external voltage connector to power your board, 7.2vdc doesn't cut it. And a small 9vdc barrey (even if providing 9 volts) is still a poor choice to power an arduino board because of the low current capacity they offer.
Lefty
what would you recommend to power my arduino uno?
If you'd like a satisfactory answer, you will have to provide a description of your intended application. At this point, the best choice for power is the USB port.
legoaceking:
Something like this maybe:
what would you recommend to power my arduino uno thats is portable?
I would recommend 4 1.5 volt batteries. It should provide enough current, and in my opinion 9v batteries are a ripoff anyway.
This probably doesn't apply to many people, but when I used my nxt in conjunction with my arduino, I found that my rechargeable lego battery could power both at once. Also, 6 batteries worked, though it may not be recommended to use 12 volts.
zonedabone:
No, 4 1.5 volt batteries equals 6 volts, that is not enough voltage for the external power connector and too much for direct connection to the +5vdc pin, as the AVR chip has a 5.5vdc max voltage limit. One would need to use 6 AA cells if using the external power connector.
