Hello,
thanks for the nice and short Code on global Flash-based strings!
A have copied michael_x’s code and changed it al little to my needs. All works fine.
Now i would like to save some strings stored in an array (e.g. LCD-Menu or Serial-Menu ect., in this case Commands CmdAR ) also to Flash but that does not work. It compiles, but the Ram and Flash compiler massages shows, it is not in flash. Is there an option to put Array based strings to Flash (and get them back for comparison to a, by serial read-in-sting and printing)?
Thanks in advance!
// Demonstrate easy use of global saved, Flash based strings
// Source: http://forum.arduino.cc/index.php?topic=110307.0
//### Defines for Flash saved Text #############################################
#define FPr(x); Serial.print(FP(x)); // FlashPrint(FT)
#define FPrL(x); Serial.println(FP(x)); // FlasPrintLine(FT)
#define SPFT(x); Serial.print(FP(FT_##x)); // shorter version (ID)
#define SPFTL(x); Serial.println(FP(FT_##x)); // shorter version (ID)
#define SFP(x); Serial.print(FP(x));
#define FT(x,y); const char FT_##x[] PROGMEM = {y};// generate FlashText(ID,FT)
#define FP(x) (__FlashStringHelper*)(x) // Helper
//### Shortening standard Serial.Print F() #####################################
#define SPr(x); Serial.print(x); // short for Serial.print
#define SPrL(x); Serial.println(x); // short for Serial.println
#define SPrF(x); SPr(F(x)); // short for F-Macro Serial.print
#define SPrLF(x); SPrL(F(x)); // short for F-Macro Serial.println
//### Generate global Flash saved strings ######################################
FT(0,"Text 0"); // Flash Text FT_0
FT(1,"This is a global saved and Flash "
"saved Text!"); // FT_1
FT(2,"File: " __FILE__ " Date: " __DATE__ " Time: " __TIME__);// FT_2
FT(3,"***************************************************"); // FT_3
FT(B4,"*\t RS232 Menu\t\t\t\t *"); // FT_4
FT(5,"###################################################"); // FT_3
//### Typedefs ################################################################
typedef void(*pF)(void); // Pointer to void FCN(void)
//### Struct RS232 Commands ###################################################
struct Commands
//char cmd1[10]; // Command 1
const char cmd1[10] PROGMEM;
//char cmd2[10]; // Command 2
const char cmd2[10] PROGMEM;
pF callback; // Callback-FCN
//String info; // Info on Command
//char info[60];
const char info[60] PROGMEM;
#define CMD_CNT (sizeof(CmdAR)/sizeof(CmdAR[0])) // Number of Commands
//### Define RS232-Command-Array ##############################################
Commands CmdAR[] = {
// cmd1, cmd2, callback, info
{"TASK", "t ", cTask, "set Task Parameter (ID, Periode, Set, CNT, Offset)"},
{"Set", "s ", cTask, "set Task Parameter (ID, Periode, Set, CNT, Offset)"},
{"LCDBL", "lcdb", cLcdBL, "set LCD BackLight (off/Auto-Off Periode)" }
void cTask(){
SPrLF("cTask");
void cLcdBL(){
SPrLF("cLcdBL");
void printComands(){
SPrL();
//SPrLF("**************************************************");
SPFTL(3);
//SPrLF("*\tRS232 Command List\t\t\t *");
SPFTL(B4);
SPFTL(3);
SPrLF("Cmd1\t, Cmd2\t, Info (Parameter)");
for(byte i=0; i<CMD_CNT; i++){
SPrF(" ");
//SPr(FP(CmdAR[i].cmd1)); SPrF("\t, ");
SFP(CmdAR[i].cmd1); SPrF("\t, ");
SFP(CmdAR[i].cmd2); SPrF("\t, ");
SFP(CmdAR[i].info);
SPrL();
SPrL();
SPFTL(3);
SPrLF("Type: < Command1/2, Val1, Val2, Val3, Val4, Val5");
SPrL();
//### Setup() #####################################################
Serial.begin(230400);
SPrL();
Serial.println(F("Macro-Based, only single "
"In-Function usable Flash saved Text."));
SPrLF("...the same, but shorter command ");
SPrL(); // Newline
FPrL(FT_0); // Serial Print Line Flash saved Text
FPrL(FT_1);
SPFTL(2); // Shortest Version SerialPrintFlashText(ID)
SPFTL(5);
}//void setup()
//### Main loop() #################################################
void loop(){
// reuse same string anywere in the Code
//SPrL(); // Newline
//SPFTL(3); // Headder, SerialPrintFlashTextLine
//SPFTL(B4);
//SPFTL(3);
SPrL();
printComands();
delay(10000);
}// void loop()
