Yea, so I know this post is super old but I am looking for a library that will work with teensy 3.6's audio library (which uses interrupts that interfere with the adafruit neopixel library) and also supports rgbw sk6812's. It appears as though your library would work, but I'm just not getting anything. If you have any suggestions I would appreciate them. Simply nothing is happening, so I'm not sure what to do. Is it possible that I cannot use pin 29 to send data?
Here's the strips that I'm using. There are two, back to back, with the data lines in parallel, so essentially only 144 leds to address. Adafruit NeoPixel Digital RGBW LED Strip - White PCB 144 LED/m [1m] : ID 2847 : $69.95 : Adafruit Industries, Unique & fun DIY electronics and kits
//////////////////////////LIBRARIES AND VARIABLES////////////////////////////
#include <Audio.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <SerialFlash.h>
//#include <Adafruit_NeoPixel.h>
#include <FAB_LED.h>
const int ledPin = 13;
//initialize button
#define primaryButton 31
//blade status
int activated = 0;
int prevState = 0;
int bladeDelay = 1; //delay between led ignition
//NEOPIXEL SETUP:
//number leds
const uint8_t nLeds = 144;
//pin
const uint8_t nPin = 29;
//power factor
const uint8_t pf = 4;
//Default colors (preset 0):
const uint8_t red = 0;
const uint8_t green = 0;
const uint8_t blue = 0;
const uint8_t white = 255;
//Adafruit_NeoPixel blade = Adafruit_NeoPixel(nLeds, nPin, NEO_RGBW + NEO_KHZ800);
//uint32_t colorOn = blade.Color(green/pf, red/pf, blue/pf, white/pf);
//uint32_t colorOff = blade.Color(0,0,0,0);
//FAB TEST
sk6812b<D,nPin> blade;
const uint8_t maxBrightness = 16; //max 255
const uint8_t numPixels = 144;
grbw pixels[numPixels] = {};
////////////////////////////////AUDIO SETUP//////////////////////////////////
// GUItool: begin automatically generated code
AudioPlaySdWav playSdWav1; //xy=363.3333435058594,1350.333251953125
AudioPlaySdWav playSdWav7; //xy=362.75,1674.75
AudioPlaySdWav playSdWav2; //xy=366.3333435058594,1411.333251953125
AudioPlaySdWav playSdWav5; //xy=374.3333435058594,1569.333251953125
AudioPlaySdWav playSdWav4; //xy=375.3333435058594,1518.333251953125
AudioPlaySdWav playSdWav6; //xy=376.3333435058594,1619.333251953125
AudioPlaySdWav playSdWav3; //xy=377.3333435058594,1465.333251953125
AudioMixer4 mixer2; //xy=806.3333435058594,1618.333251953125
AudioMixer4 mixer1; //xy=816.3333435058594,1410.333251953125
AudioOutputAnalog dac1; //xy=1082.3333435058594,1412.333251953125
AudioConnection patchCord1(playSdWav1, 0, mixer1, 0);
AudioConnection patchCord2(playSdWav7, 0, mixer2, 3);
AudioConnection patchCord3(playSdWav2, 0, mixer1, 1);
AudioConnection patchCord4(playSdWav5, 0, mixer2, 1);
AudioConnection patchCord5(playSdWav4, 0, mixer2, 0);
AudioConnection patchCord6(playSdWav6, 0, mixer2, 2);
AudioConnection patchCord7(playSdWav3, 0, mixer1, 2);
AudioConnection patchCord8(mixer2, 0, mixer1, 3);
AudioConnection patchCord9(mixer1, dac1);
// GUItool: end automatically generated code
float volumeGain = 4; //volume control variable
////////////////////////////////SDCARD SETUP/////////////////////////////////
// Use these with the Teensy Audio Shield
//#define SDCARD_CS_PIN 10
//#define SDCARD_MOSI_PIN 7
//#define SDCARD_SCK_PIN 14
// Use these with the Teensy 3.5 & 3.6 SD card
#define SDCARD_CS_PIN BUILTIN_SDCARD
#define SDCARD_MOSI_PIN 11 // not actually used
#define SDCARD_SCK_PIN 13 // not actually used
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN 4
//#define SDCARD_MOSI_PIN 11
//#define SDCARD_SCK_PIN 13
///////////////////////////////////SETUP/////////////////////////////////////
Serial.begin(115200); //initialize serial communication
delay(100);
AudioMemory(16); //set memory allocated to audio functions
dac1.analogReference(EXTERNAL); //much louder!
delay(50); //time for DAC voltage stabilization
pinMode(5, OUTPUT);
delay(50);
digitalWrite(5, HIGH); // turn on the amplifier
delay(50);
SPI.setMOSI(SDCARD_MOSI_PIN); //set SD card MOSI pin
SPI.setSCK(SDCARD_SCK_PIN); //set SD card clock pin
//return error if SD card cannot be accessed
if (!(SD.begin(SDCARD_CS_PIN)))
while (1) {
Serial.println("Unable to access the SD card");
pinMode(ledPin, OUTPUT); //board indicator LED
//Set the gain on one of the mixer's channels. Input "channel" must be 0 to 3.
//Input "level" may be any floating point number from 0.00004 to 32768.0.
//The default is 1.0.
//Values less than 1.0 attenuate the inputs, and values greater than 1.0 cause amplification.
mixer1.gain(0, volumeGain * .25); //sdwav1
mixer1.gain(1, volumeGain * .25); //sdwav2
mixer1.gain(2, volumeGain * .25); //sdwav3
mixer2.gain(0, volumeGain * .25); //sdwav4
mixer2.gain(1, volumeGain * .25); //sdwav5
mixer2.gain(2, volumeGain * .25); //sdwav6
mixer2.gain(3, volumeGain * .25); //sdwav7
//setup button
pinMode(primaryButton, INPUT_PULLUP);
//neopixel start
// blade.begin();
// blade.show();
blade.clear(2 * numPixels);
////////////////////////////////////LEDS/////////////////////////////////////
void updateColors(char r, char g, char b, char w)
for(int i = 0; i < numPixels; i++)
pixels[i].r = r;
pixels[i].g = g;
pixels[i].b = b;
pixels[i].w = w;
////////////////////////////////////LOOP/////////////////////////////////////
if(digitalRead(primaryButton)==LOW)
if(activated==0&&prevState==0)
prevState=1;
digitalWrite(ledPin, HIGH);
playSdWav1.play("PON.WAV");
activated = 1;
// Write the pixel array green
updateColors(0, maxBrightness, 0, 0);
// Display the pixels on the LED strip
blade.sendPixels(numPixels, pixels);
// Wait 0.1 seconds
delay(100);
// for(byte i=0; i<nLeds; i++)
// blade.setPixelColor(i,colorOn);
// blade.show();
// delay(bladeDelay);
}else if(activated==1&&prevState==0)
prevState=1;
digitalWrite(ledPin, LOW);
playSdWav1.stop();
delay(25); //prevents some weird clipping that happens when the sounds are played back to back
playSdWav2.play("POFF.WAV");
activated = 0;
updateColors(0, 0, 0, 0);
// Wait 0.1 seconds
delay(100);
// for(byte i=nLeds; i>=0; i--)
// blade.setPixelColor(i,colorOff);
// blade.show();
}else
//do nothing
prevState=0;
