I am using the FadeLed library to control 4 leds in 8 different scenarios.
The code I have works almost 100% every time I change to a new scenario; however, If I switch scenarios in the middle of a fade sequence some of the LEDS stay on and will not fade out. Is there a way to turn off all leds a once before starting the next scenario.
Attached is my code; so far I am only using scenes 1 thru 4. Selecting scenes 1 and work very well however when I change to the single led scenarios one of the leds stays on, usually the RED led( leds[3]).
Any help appreciated
* @file
* @Author Septillion (https://github.com/sseptillion)
* @date 2016-08-11
* 6/16/18 - WJL modified to work for lighthouse
* 6/17/18 - Modified to add four scenarios
* 6/18/18 - Modified to use LINK system with 5-stand REV_1 board
* 7/22/18 - Changed to 4 LED
* 6/12/19 Added delay(500) to on-off switch
* EAGLE BOARD "LIGHTHOUSE_LINX_4LED_NORELAY
* 4/22/2021 MADE NEW BOARD REV A
* 6/28/2023 CONVERTED TO NEW LIGHTHOUSE USING MOTEINO RADIOS
#include <FadeLed.h>
//make four FadeLed objects for pin 3 (leds[0]), pin 9 (leds[1], pin 10(leds[2] and pin 11(leds[3])
FadeLed leds[] = {3, 9, 10, 11};
//leds[0] = WHITE
//leds[1] = GREEN
//leds[2] = BLUE
//leds[3] = RED
int seqA = 8; //BUTTON LINX#D0
int seqB = 4; //BUTTON LINX#D1
int seqC = 7; //BUTTON LINX#D2
int seqD = 12; //BUTTON LINX#D3
int seqE = 2; //BUTTON LINX#D4
int seqF = 17; //BUTTON LINX#D6
int seqG = 16; //BUTTON LINX#D5
int seqH = 15; //scene #8 , 9 button pushes
int out_on_off = 16; //POLOLU SWITCH
int state = HIGH; //current state of the output pin
int previous = LOW; //previous reading from the input pin
int patA;
int patB;
int patC;
int patD;
int patE;
int patF;
int patG;
unsigned long millisLast_0;
unsigned long millisLast_1;
unsigned long millisLast_2;
unsigned long millisLast_3;
unsigned long millisLast_4;
unsigned long millisLast_5;
unsigned long millisLast_6;
int patA_A = 1;
int patB_A = 0;
int patC_A = 0;
int patD_A = 0;
int patE_A = 0;
int patF_A = 0;
int patG_A = 0;
byte currentLed = 0;
pinMode (seqA, INPUT);
pinMode (seqB, INPUT);
pinMode (seqC, INPUT);
pinMode (seqD, INPUT);
pinMode (seqE, INPUT);
pinMode (seqF, INPUT);
pinMode (seqG, INPUT);
pinMode (out_on_off, OUTPUT);
delay(5000);
Serial.println("File name = LIGHTHOUSE_9_4LED_NORELAY_MOTEINO");
FadeLed::update();
patA = digitalRead(seqA);
patB = digitalRead(seqB);
patC = digitalRead(seqC);
patD = digitalRead(seqD);
patE = digitalRead(seqE);
patF = digitalRead(seqF);
patG = digitalRead(seqG);
//Serial.print("patA = ");Serial.println(patA);
//Serial.print("patB = ");Serial.println(patB);
//Serial.print("patC = ");Serial.println(patC);
//Serial.print("patD = ");Serial.println(patD);
if (patA == HIGH) //LINX BUTTON #1
patA_A = 1;
patB_A = 0;
patC_A = 0;
patD_A = 0;
patE_A = 0;
patF_A = 0;
patG_A = 0;
leds[0].setTime(2000,true);
leds[1].setTime(2000,true);
leds[2].setTime(2000,true);
leds[3].setTime(2000,true);
//and I start fading the first
currentLed = 0;
leds[currentLed].on();
if (patA_A == 1)
routineA();
if (patB == HIGH) //LINX BUTTON #2
patA_A = 0;
patB_A = 1;
patC_A = 0;
patD_A = 0;
patE_A = 0;
patF_A = 0;
patG_A = 0;
currentLed = 3; //3 = RED
if (patB_A == 1)
routineB();
if (patC == HIGH) //LINX BUTTON #3
patA_A = 0;
patB_A = 0;
patC_A = 1;
patD_A = 0;
patE_A = 0;
patF_A = 0;
patG_A = 0;
leds[0].begin(0);
leds[1].begin(0);
leds[2].begin(0);
leds[2].setTime(2000);
if (patC_A == 1)
routineC();
if (patD == HIGH) //LINX BUTTON #4
patA_A = 0;
patB_A = 0;
patC_A = 0;
patD_A = 1;
patE_A = 0;
patF_A = 0;
patG_A = 0;
leds[0].begin(0);
leds[1].begin(0);
leds[2].begin(0);
if (patD_A == 1)
leds[0].setTime(2000);
routineD ();
if (patE == HIGH) //LINX BUTTON #5
patA_A = 0;
patB_A = 0;
patC_A = 0;
patD_A = 0;
patE_A = 1;
patF_A = 0;
patG_A = 0;
if (patE_A == 1)
routineE ();
if (patF == HIGH)
patA_A = 0;
patB_A = 0;
patC_A = 0;
patD_A = 0;
patE_A = 0;
patF_A = 1;
patG_A = 0;
leds[0].begin(0);
leds[1].begin(0);
leds[3].begin(0);
if (patF_A == 1)
leds[0].setTime(1000);
routineD ();
if (patG == HIGH)
patA_A = 0;
patB_A = 0;
patC_A = 0;
patD_A = 0;
patE_A = 0;
patF_A = 0;
patG_A = 1;
leds[0].begin(0);
leds[1].begin(0);
leds[2].begin(0);
if (patG_A == 1)
routineD ();
void routineA() //RED-WHITE-GREEN-BLUE, LINX BUTTON #1
Serial.println("AT routineA()");
if(leds[currentLed].done() && leds[currentLed].get())
//Serial.print("FADE DOWN - leds[current.led].get = "); Serial.println(leds[currentLed].get());
//fade down again
leds[currentLed].off();
//if done fading down
else if(leds[currentLed].done() && !leds[currentLed].get())
// Serial.print("FADE UP - !leds[current.led].get = "); Serial.println(leds[currentLed].get());
//go to next led
currentLed++;
if(currentLed >= 4)
currentLed = 0;
Serial.println("ROUTINE A, NEXT LED");
//and start fading that
leds[currentLed].set(100);
void routineB() //RED-WHITE-BLUE, LINX BUITTON #2
Serial.println("AT routineB()");
//fade down again
//go to next led
if(currentLed == 3)
Serial.println("ROUTINE b, NEXT LED #0");
Serial.print("currentLed = "); Serial.println(currentLed);
currentLed = 0;
else if(currentLed == 0)
Serial.println("ROUTINE b, NEXT LED #2");
currentLed = 2;
else if(currentLed == 2)
Serial.println("ROUTINE b, NEXT LED #3");
currentLed = 3;
else if (currentLed == 3)
currentLed = 0;
leds[currentLed].set(75);
//leds[currentLed].set(75);
void routineC() //BLUE LED, LINX BUTON#3
Serial.println("at routineC()");
leds[0].off();
leds[1].off();
leds[3].off();
if(leds[2].done()) //BLUE LED
//.get() will return the current brightness
//so this will tell us if we are not at 0
if(leds[2].get())
//then we are done fading up, let's fade down again
leds[2].off();
//or we are at 0
if (millis() - millisLast_2 > 7000)
leds[2].setTime(1000,true);
//then we are done fading down, let's fade up again
leds[2].set(100);
millisLast_2 = millis();
void routineD() //WHITE LED, LINX BUTTON #4
Serial.println("at routineD()");
leds[1].off();
leds[2].off();
leds[3].off();
if(leds[0].done()) //WHITE LED
if(leds[0].get())
leds[0].setTime(1000, true);
leds[0].off();
//or we are at 0
if (millis() - millisLast_0 > 7000)
leds[0].setTime(1000,true);
leds[0].set(100);
millisLast_0 = millis();
void routineE() //RED-WHITE-GREEN, LINX BUTTON #5
Serial.println("at routinE()");
//fade down again
//go to next led
if(currentLed == 3)
currentLed = 0;
Serial.println("ROUTINE b, NEXT LED #1");
currentLed = 1;
else if(currentLed == 1)
currentLed = 3;
currentLed = 0;
if(leds[1].done()) //GREEN LED
if(leds[1].get())
leds[1].setTime(3000,true);
leds[1].off();
//or we are at 0
//if (millis() - millisLast_1 > 7000)
leds[1].set(25);
//millisLast_1 = millis();
if(leds[2].done()) //WHITE LED
if(leds[2].get())
leds[2].off();
//or we are at 0
leds[2].set(25);
void routineE()
Serial.println("at routineE");
if(leds[0].done())
if(leds[0].get())
leds[0].off();
//or we are at 0
if (millis() - millisLast_0 > 14000)
leds[0].set(50);
if(leds[1].done())
if(leds[1].get())
leds[1].off();
//or we are at 0
if (millis() - millisLast_1 > 14000)
leds[1].set(50);
if(leds[2].done())
if(leds[2].get())
leds[2].off();
//or we are at 0
if (millis() - millisLast_2 > 14000)
leds[2].set(50);
void routineF()
if(leds[0].done())
if(leds[0].get())
leds[0].off();
//or we are at 0
leds[0].set(50);
if(leds[1].done())
if(leds[1].get())
leds[1].off();
//or we are at 0
leds[1].set(50);
if(leds[2].done())
if(leds[2].get())
leds[2].off();
//or we are at 0
leds[2].set(50);
void routineG()
Serial.println("at routineF");
if(leds[0].done())
//so this will tell us if we are not at 0 or using !xxx if we are at zero
if(leds[0].get())
leds[0].off();
//or we are at 0
leds[0].set(50);
if(leds[1].done())
if(leds[1].get())
leds[1].off();
//or we are at 0
leds[1].set(50);
if(leds[2].done())
if(leds[2].get())
leds[2].off();
//or we are at 0
leds[2].set(50);
