Thanks for the clarification.
Did you disconnect the jumper and power cycle the board after successfully finishing the flashing operation?
That's correct. I was actually thinking about in another topic when you were talking about sharing files between Apple devices. iCloud is a way to easily "network" a few Apple products together through a common folder in iCloud.
Not pertinent to this topic.
Yes, disconnect the jumper, disconnect the Board from usb and power. Reconnect the Board via usb.
I couldn't connect over a laptop USB 3 port after many tries. So I tried switching to a USB A port and it WORKS !. I can run Arduino App Lab and flash memory now
Thanks for that, however, unfortunately, this does not work for me.
To be more specific this is what I get:-
Downloads/arduino-flasher-cli-0.2.3-darwin-arm64/arduino-flasher-cli flash latest
This does not work. Yet again I get
zsh: fork failed: resource temporarily unavailable
This seems to be the permanent state of the zsh port.
cd Downloads/arduino-flasher-cli-0.2.3-darwin-arm64
Returns the error, unsurprising to me, of
cd: no such file or directory: Downloads/arduino-flasher-cli-0.2.3-darwin-arm64
This is because I have no idea where you get the "cli-0.2.3-darwin-arm64" bit as it is never specified in any of the downloads.
EDIT
I restarted my iMac, as things had gone strange with my terminal window. Also I had dragged the unzipped file onto the desktop. Then after the restart I got this message
mikecook@iMac ~ % /Users/mikecook/Desktop/arduino-flasher-cli-0.2.3-linux-arm64
zsh: permission denied: /Users/mikecook/Desktop/arduino-flasher-cli-0.2.3-linux-arm64
Well that is a diffrent result, but as I am the administrator on this machine I am not sure why I don't have this permission.
The issue possibly isnât about macOS admin rights, but because the file isnât marked as executable. When you downloaded or unzipped it, macOS didnât automatically give it execute permission.
Try a chmod +x on it
I'll provide more precise instructions for the image flashing procedure. @Grumpy_Mike please follow these carefully. If you have any questions or problems while doing that, just let us know and we'll provide further assistance.
If connected, disconnect the USB board of the UNO Q board from your computer.
Connect a female-to-female jumper cable between these two pins on the UNO Q board:
Connect the USB cable of the UNO Q board to your computer.
This will result in the creation of a folder named arduino-flasher-cli-0.2.3-darwin-arm64, which contains the installation of the Arduino Flasher CLI tool.
arduino-flasher-cli-0.2.3-darwin-arm64 folder that was created by the "B. Install Arduino Flasher CLI" procedure above.arduino-flasher-cli-0.2.3-darwin-arm64 folder as the working directory../arduino-flasher-cli flash latest
Checking for Debian image releases
Found Debian image version: 20251006-395
Do you want to download it? (yes/no)
y.Now start Arduino App Lab. Hopefully this time it will detect the UNO Q.
Select Open With > Archive Utility from the menu.
The "Archive Utility" app will extract the downloaded archive file.
That might have been the issue. macOSâs Archive Utility automatically extracts a .tar.gz preserving the execute permissions, effectively doing what tar -xzf would do.
If you manually extract the .tar.gz without telling tar to preserve permissions (for example, using tar -x instead of tar -xzf or with incorrect options), the execute bits might be lost.
Hi @Grumpy_Mike,
Regarding the âpermission deniedâ error, it is because you are trying to âexecute a folderâ.
The correct command line should be
/Users/mikecook/Desktop/arduino-flasher-cli-0.2.3-linux-arm64/arduino-flasher-cli
Also, double-check the name of the extracted folder, because a few archiving tools might extract it in arduino-flasher-cli-0.2.3-linux-arm64.tar instead of arduino-flasher-cli-0.2.3-linux-arm64.
I canât believe it. This also solved my problem.
- Control-click on the downloaded file.
A context menu will open.- Select Open With > Archive Utility from the menu.
That is where it stops working. I can not see any option that says Open With > archive Utility
What I get as options is shown in this screen dump.
Please provide a screenshot of your full screen at that step. The additional context might allow us to understand the problem and how to solve it.
It appears you may have clicked on the icon in the macOS dock rather than the file in Finder:
Make sure to click on the item in the Finder window. Let us know if you still experience the same problem when you do that.
Wait for the process to finish successfully.
That seems to be a problem here is what my terminal window says
Last login: Sun Oct 26 08:12:57 on ttys000
mikecook@iMac arduino-flasher-cli-0.2.3-darwin-arm64 % ./arduino-flasher-cli flash latest
Y
Downloading Debian image version 20251006-395
Download progress: 1.00 %
//I removed all the tedious in between points
Download progress: 99.05 %
Download of Debian image completed
Unzipping Debian image
arduino-unoq-debian-image-20251006-395/
arduino-unoq-debian-image-20251006-395/disk-sdcard.img.home
arduino-unoq-debian-image-20251006-395/disk-sdcard.img.root
arduino-unoq-debian-image-20251006-395/disk-sdcard.img.esp
arduino-unoq-debian-image-20251006-395/flash/
arduino-unoq-debian-image-20251006-395/flash/rpm.mbn
arduino-unoq-debian-image-20251006-395/flash/multi_image.mbn
arduino-unoq-debian-image-20251006-395/flash/devcfg.mbn
arduino-unoq-debian-image-20251006-395/flash/tz.mbn
arduino-unoq-debian-image-20251006-395/flash/qupv3fw.elf
arduino-unoq-debian-image-20251006-395/flash/xbl_feature_config.elf
arduino-unoq-debian-image-20251006-395/flash/gpt_main1.bin
arduino-unoq-debian-image-20251006-395/flash/prog_firehose_ddr.elf
arduino-unoq-debian-image-20251006-395/flash/gpt_backup1.bin
arduino-unoq-debian-image-20251006-395/flash/storsec.mbn
arduino-unoq-debian-image-20251006-395/flash/boot.img
arduino-unoq-debian-image-20251006-395/flash/imagefv.elf
arduino-unoq-debian-image-20251006-395/flash/zeros_1sector.bin
arduino-unoq-debian-image-20251006-395/flash/featenabler.mbn
arduino-unoq-debian-image-20251006-395/flash/hyp.mbn
arduino-unoq-debian-image-20251006-395/flash/gpt_both0.bin
arduino-unoq-debian-image-20251006-395/flash/gpt_empty0.bin
arduino-unoq-debian-image-20251006-395/flash/uefi_sec.mbn
arduino-unoq-debian-image-20251006-395/flash/gpt_main0.bin
arduino-unoq-debian-image-20251006-395/flash/patch0.xml
arduino-unoq-debian-image-20251006-395/flash/gpt_main2.bin
arduino-unoq-debian-image-20251006-395/flash/gpt_backup0.bin
arduino-unoq-debian-image-20251006-395/flash/km4.mbn
arduino-unoq-debian-image-20251006-395/flash/rawprogram0.xml
arduino-unoq-debian-image-20251006-395/flash/zeros_33sectors.bin
arduino-unoq-debian-image-20251006-395/flash/rawprogram0.nouser.xml
arduino-unoq-debian-image-20251006-395/flash/abl.elf
arduino-unoq-debian-image-20251006-395/flash/gpt_backup2.bin
arduino-unoq-debian-image-20251006-395/flash/cdt.bin
arduino-unoq-debian-image-20251006-395/flash/xbl.elf
WARNING: flashing a new Linux image on the board will erase any existing data you have on it.
Do you want to procede and flash /private/var/folders/0r/5d65776n19q2wvp1wf4bjsxr0000gn/T/flasher-updater-1746828856/arduino-unoq-debian-image-20251006-395 on the board? (yes/no)
yes
Flashing with qdl
Waiting for EDL device
At which point it just hangs, well for at least ten minutes so far.
I suspect this is caused by the same root problem as causes Arduino App Lab to not recognize the board. In this case, it is that the Qualcomm Download tool (qdl) used by arduino-flasher-cli is also not recognizing the connected board.
Unfortunately I don't know what might cause this. Maybe the more knowledgeable @AndreaRichetta and @manchuino will have an idea.
The thing is that I already used this board to run the Arduino App Lab to run the blink LED and the Pin Toggle successfully. Now it no longer works.
Just curious there â is it the step that places the board into Emergency Download mode (aka EDL mode) ?
@Grumpy_Mike - are you sure your jumper cable is good ?
As the two pins to be connected are adjacent, you could also use a 2.54mm, 0.1" jumper, as shown below:
Yes that is what I used.
Yes they feel very firm and I have used them many, many times in the past on numerous projects where options are required. For example all my musical instruments for disabled people have one in them in order to swap over between a right handed and left handed mode.
