UNO Q - can't get past failed update window to enter Linux password
I’ve flashed my Uno Q nine times this morning. I can’t begin to explain how frustrating an experience this has been…
The past couple days I’d get board errors, updates not downloading, examples failing (/run.sh: 39: .: cannot open /app/.cache/.venv/bin/activate: No such file) - just a whole slew of problems as others have gone through.
However, this morning I’m now unable to get past the failed “Error checking for updates: board update error” after entering my WiFi credentials, which means I can’t even set up the Linux password. Reconnected, restarted App Lab, reflashed, etc. - nothing fixes this. Thus my Uno Q is practically useless.
Any ideas? Should I just put this thing in a closet for a month and come back and try again?
I had a few times where it failed to upload changes. Although in my case
it may have been caused as I am also using it with Zephyr builds of the current
sources. When things get screwed up, what I have tried is to:
Start Arduino IDE - make sure you have the current release of the board.
plugged into Q into USB. Wait for it to boot up.
Choose the Q in as the current board.
Make sure in tools menu: that programmer is set. does not matter what.
Make sure the Tools Port is set to the Q's USB port
Then use the: tools -> Burn bootloader
And hopefully that works...
And then see if things work for you.
@bgbetz
  • Please download and install the Android Platform tools from https://developer.android.com/tools/releases/platform-tools.
  • Connect the board to your Mac/PC via a USB-C cable.
  • Open a terminal window and type:
    adb shell
  • You are now connected to the board.
  • From there type:
    sudo apt update && sudo apt upgrade -y
  • Wait for the upgrade to finish.
  • Close the terminal window.
  • Relaunch the App Lab.
Please let me know if this fixes your issue.
AND??? did you forget something?
Why Android? I don't have any Android devices, can you un-confuse me?
@sonofcy
It is because the Uno Q (and the Portenta X8, too) uses ADB as a low-level backend to interface with the board. Using ADB allows you to interact with the board just using a USB cable.
Thank you. Sorry for the first deleted post. The first couple tries apparently had connectivity issues. The third try seems to have updated/installed everything. I relaunched App Lab and it said it was checking for updates, then that window disappeared and I was able to create the Linux password. App Lab opened normally to the examples.
I opened the Blink LED and ran it. The App Launch monitor window showed a lot of stuff (below) and after about 5 minutes the app seems to have successfully launched and worked. I have not tried any of the others yet.
The library ArxContainer has been automatically added from sketch project.
The library ArxTypeTraits has been automatically added from sketch project.
The library DebugLog has been automatically added from sketch project.
The library MsgPack has been automatically added from sketch project.
Sketch uses 19352 bytes (0%) of program storage space. Maximum is 1966080 bytes.
Global variables use 4676 bytes (0%) of dynamic memory, leaving 518948 bytes for local variables. Maximum is 523624 bytes.
Open On-Chip Debugger 0.12.0+dev-ge6a2c12f4 (2025-05-22-15:51)
Licensed under GNU GPL v2
For bug reports, read
	http://openocd.org/doc/doxygen/bugs.html
debug_level: 2
clock_config
/tmp/remoteocd/sketch.elf-zsk.bin
Info : Linux GPIOD JTAG/SWD bitbang driver (libgpiod v2)
Info : Note: The adapter "linuxgpiod" doesn't support configurable speed
Info : SWD DPIDR 0x0be12477
Info : [stm32u5.ap0] Examination succeed
Info : [stm32u5.cpu] Cortex-M33 r0p4 processor detected
Info : [stm32u5.cpu] target has 8 breakpoints, 4 watchpoints
Info : [stm32u5.cpu] Examination succeed
Info : [stm32u5.ap0] gdb port disabled
Info : [stm32u5.cpu] starting gdb server on 3333
Info : Listening on port 3333 for gdb connections
CPU in Non-Secure state
[stm32u5.cpu] halted due to debug-request, current mode: Thread
xPSR: 0x41000000 pc: 0x0801748c psp: 0x2002ccf8
[stm32u5.cpu] halted due to breakpoint, current mode: Thread
xPSR: 0x09000000 pc: 0x0800513c psp: 0x20034a70
shutdown command invoked
20035490
python provisioning
python downloading
 main Pulling
 a16e55119267 Pulling fs layer
 46c16d549757 Pulling fs layer
 12d00bf9121f Pulling fs layer
 079ccd64f646 Pulling fs layer
 3330c4715eb1 Pulling fs layer
 a78651c5296d Pulling fs layer
 5bea91f645c6 Pulling fs layer
 dca79262ae41 Pulling fs layer
 e1c0035b8792 Pulling fs layer
 2a9b507f3461 Pulling fs layer
 7767ad302cf3 Pulling fs layer
 fb78fe106732 Pulling fs layer
 4f4fb700ef54 Pulling fs layer
 e1c0035b8792 Waiting
 079ccd64f646 Waiting
 3330c4715eb1 Waiting
 a78651c5296d Waiting
 5bea91f645c6 Waiting
 dca79262ae41 Waiting
 7767ad302cf3 Waiting
 2a9b507f3461 Waiting
 fb78fe106732 Waiting
 4f4fb700ef54 Waiting
 12d00bf9121f Downloading [>                                                  ]  131.1kB/11.67MB
 46c16d549757 Downloading [=======>                                           ]  178.4kB/1.273MB
 46c16d549757 Downloading [========>                                          ]  227.6kB/1.273MB
 12d00bf9121f Downloading [=>                                                 ]  262.1kB/11.67MB
 46c16d549757 Downloading [===========>                                       ]  293.1kB/1.273MB
 a16e55119267 Downloading [>                                                  ]  309.4kB/30.14MB
 46c16d549757 Downloading [=============>                                     ]  342.2kB/1.273MB
 12d00bf9121f Downloading [=>                                                 ]  386.9kB/11.67MB
 46c16d549757 Downloading [================>                                  ]  407.8kB/1.273MB
 46c16d549757 Downloading [==================>                                ]  473.3kB/1.273MB
 12d00bf9121f Downloading [==>                                                ]    518kB/11.67MB
 46c16d549757 Downloading [=====================>                             ]  538.9kB/1.273MB
 46c16d549757 Downloading [=======================>                           ]  601.1kB/1.273MB
 a16e55119267 Downloading [=>                                                 ]    620kB/30.14MB
 12d00bf9121f Downloading [==>                                                ]    649kB/11.67MB
 46c16d549757 Downloading [==========================>                        ]  686.8kB/1.273MB
 46c16d549757 Downloading [==============================>                    ]  785.1kB/1.273MB
 12d00bf9121f Downloading [===>                                               ]  780.1kB/11.67MB
 46c16d549757 Downloading [==================================>                ]    867kB/1.273MB
 46c16d549757 Downloading [====================================>              ]  932.5kB/1.273MB
 12d00bf9121f Downloading [===>                                               ]  911.2kB/11.67MB
 46c16d549757 Downloading [=======================================>           ]  1.014MB/1.273MB
 a16e55119267 Downloading [=>                                                 ]  931.3kB/30.14MB
 46c16d549757 Downloading [===========================================>       ]  1.096MB/1.273MB
 46c16d549757 Downloading [==============================================>    ]  1.178MB/1.273MB
 12d00bf9121f Downloading [====>                                              ]  1.042MB/11.67MB
 46c16d549757 Downloading [===============================================>   ]  1.211MB/1.273MB
 46c16d549757 Downloading [==================================================>]  1.273MB/1.273MB
 46c16d549757 Verifying Checksum
 46c16d549757 Download complete
 12d00bf9121f Downloading [=====>                                             ]  1.173MB/11.67MB
 a16e55119267 Downloading [==>                                                ]  1.243MB/30.14MB
 12d00bf9121f Downloading [=====>                                             ]  1.304MB/11.67MB
 12d00bf9121f Downloading [======>                                            ]  1.435MB/11.67MB
 12d00bf9121f Downloading [======>                                            ]  1.567MB/11.67MB
 a16e55119267 Downloading [==>                                                ]  1.553MB/30.14MB
 12d00bf9121f Downloading [=======>                                           ]  1.698MB/11.67MB
 12d00bf9121f Downloading [=======>                                           ]  1.828MB/11.67MB
 12d00bf9121f Downloading [========>                                          ]   1.96MB/11.67MB
 12d00bf9121f Downloading [========>                                          ]  2.091MB/11.67MB
 12d00bf9121f Downloading [=========>                                         ]  2.222MB/11.67MB
 12d00bf9121f Downloading [==========>                                        ]  2.353MB/11.67MB
 a16e55119267 Downloading [===>                                               ]  2.175MB/30.14MB
 12d00bf9121f Downloading [==========>                                        ]  2.484MB/11.67MB
 12d00bf9121f Downloading [===========>                                       ]  2.615MB/11.67MB
 12d00bf9121f Downloading [===========>                                       ]  2.746MB/11.67MB
 12d00bf9121f Downloading [============>                                      ]  2.877MB/11.67MB
 a16e55119267 Downloading [====>                                              ]  2.796MB/30.14MB
 079ccd64f646 Downloading [==================================================>]     249B/249B
 079ccd64f646 Verifying Checksum
 079ccd64f646 Download complete
 12d00bf9121f Downloading [=============>                                     ]  3.266MB/11.67MB
 12d00bf9121f Downloading [==============>                                    ]  3.397MB/11.67MB
 12d00bf9121f Downloading [===============>                                   ]  3.528MB/11.67MB
 a16e55119267 Downloading [=====>                                             ]  3.108MB/30.14MB
 12d00bf9121f Downloading [================>                                  ]  3.791MB/11.67MB
 12d00bf9121f Downloading [================>                                  ]  3.922MB/11.67MB
 12d00bf9121f Downloading [=================>                                 ]  4.053MB/11.67MB
 a16e55119267 Downloading [=====>                                             ]  3.416MB/30.14MB
 12d00bf9121f Downloading [==================>                                ]  4.315MB/11.67MB
 a16e55119267 Downloading [======>                                            ]  3.728MB/30.14MB
 12d00bf9121f Downloading [====================>                              ]  4.703MB/11.67MB
 12d00bf9121f Downloading [====================>                              ]  4.834MB/11.67MB
 12d00bf9121f Downloading [=====================>                             ]  4.965MB/11.67MB
 a16e55119267 Downloading [======>                                            ]  4.039MB/30.14MB
 12d00bf9121f Downloading [======================>                            ]  5.227MB/11.67MB
 12d00bf9121f Downloading [======================>                            ]  5.358MB/11.67MB
 12d00bf9121f Downloading [=======================>                           ]  5.487MB/11.67MB
 a16e55119267 Downloading [=======>                                           ]   4.35MB/30.14MB
 12d00bf9121f Downloading [=========================>                         ]   5.88MB/11.67MB
 12d00bf9121f Downloading [=========================>                         ]  6.011MB/11.67MB
 12d00bf9121f Downloading [==========================>                        ]  6.142MB/11.67MB
 a16e55119267 Downloading [=======>                                           ]  4.661MB/30.14MB
 12d00bf9121f Downloading [===========================>                       ]  6.404MB/11.67MB
 12d00bf9121f Downloading [============================>                      ]  6.535MB/11.67MB
 12d00bf9121f Downloading [============================>                      ]  6.666MB/11.67MB
 a16e55119267 Downloading [========>                                          ]  4.973MB/30.14MB
 12d00bf9121f Downloading [==============================>                    ]  7.059MB/11.67MB
 12d00bf9121f Downloading [===============================>                   ]  7.321MB/11.67MB
 12d00bf9121f Downloading [===============================>                   ]  7.453MB/11.67MB
 12d00bf9121f Downloading [================================>                  ]  7.584MB/11.67MB
 12d00bf9121f Downloading [=================================>                 ]  7.715MB/11.67MB
 12d00bf9121f Downloading [=================================>                 ]  7.846MB/11.67MB
 12d00bf9121f Downloading [==================================>                ]  7.977MB/11.67MB
 12d00bf9121f Downloading [==================================>                ]  8.108MB/11.67MB
 12d00bf9121f Downloading [===================================>               ]   8.37MB/11.67MB
 3330c4715eb1 Downloading [>                                                  ]  538.1kB/131.3MB
 12d00bf9121f Downloading [====================================>              ]  8.632MB/11.67MB
 a16e55119267 Downloading [=========>                                         ]  5.903MB/30.14MB
 12d00bf9121f Downloading [=====================================>             ]  8.763MB/11.67MB
 12d00bf9121f Downloading [======================================>            ]  8.894MB/11.67MB
 12d00bf9121f Downloading [======================================>            ]  9.025MB/11.67MB
 12d00bf9121f Downloading [=======================================>           ]  9.156MB/11.67MB
 12d00bf9121f Downloading [=======================================>           ]  9.287MB/11.67MB
 12d00bf9121f Downloading [========================================>          ]  9.418MB/11.67MB
 a16e55119267 Downloading [==========>                                        ]  6.214MB/30.14MB
 12d00bf9121f Downloading [========================================>          ]   9.55MB/11.67MB
 12d00bf9121f Downloading [=========================================>         ]  9.678MB/11.67MB
 12d00bf9121f Downloading [==========================================>        ]   9.94MB/11.67MB
 12d00bf9121f Downloading [===========================================>       ]   10.2MB/11.67MB
 a16e55119267 Downloading [==========>                                        ]  6.525MB/30.14MB
 12d00bf9121f Downloading [============================================>      ]  10.33MB/11.67MB
 12d00bf9121f Downloading [============================================>      ]  10.46MB/11.67MB
 12d00bf9121f Downloading [=============================================>     ]   10.6MB/11.67MB
 12d00bf9121f Downloading [=============================================>     ]  10.73MB/11.67MB
 12d00bf9121f Downloading [==============================================>    ]  10.86MB/11.67MB
 12d00bf9121f Downloading [===============================================>   ]  10.99MB/11.67MB
 12d00bf9121f Downloading [===============================================>   ]  11.12MB/11.67MB
 a16e55119267 Downloading [===========>                                       ]  6.831MB/30.14MB
 12d00bf9121f Downloading [================================================>  ]  11.38MB/11.67MB
 12d00bf9121f Downloading [=================================================> ]  11.64MB/11.67MB
 12d00bf9121f Download complete
 3330c4715eb1 Downloading [>                                                  ]  1.074MB/131.3MB
 a16e55119267 Downloading [===========>                                       ]  7.142MB/30.14MB
 a16e55119267 Downloading [============>                                      ]  7.454MB/30.14MB
 a16e55119267 Downloading [============>                                      ]  7.765MB/30.14MB
 3330c4715eb1 Downloading [>                                                  ]  1.608MB/131.3MB
 a16e55119267 Downloading [=============>                                     ]  8.076MB/30.14MB
 a16e55119267 Downloading [=============>                                     ]  8.388MB/30.14MB
 a16e55119267 Downloading [==============>                                    ]  8.696MB/30.14MB
 3330c4715eb1 Downloading [>                                                  ]  2.149MB/131.3MB
 a16e55119267 Downloading [==============>                                    ]  9.008MB/30.14MB
 a16e55119267 Downloading [===============>                                   ]  9.319MB/30.14MB
 3330c4715eb1 Downloading [=>                                                 ]  2.683MB/131.3MB
 a16e55119267 Downloading [===============>                                   ]   9.63MB/30.14MB
 a78651c5296d Downloading [>                                                  ]    213kB/21.2MB
 a16e55119267 Downloading [================>                                  ]  9.941MB/30.14MB
 3330c4715eb1 Downloading [=>                                                 ]  3.224MB/131.3MB
 a16e55119267 Downloading [=================>                                 ]  10.25MB/30.14MB
 a16e55119267 Downloading [=================>                                 ]  10.56MB/30.14MB
 3330c4715eb1 Downloading [=>                                                 ]  3.764MB/131.3MB
 a16e55119267 Downloading [==================>                                ]  10.88MB/30.14MB
 a78651c5296d Downloading [=>                                                 ]    426kB/21.2MB
 3330c4715eb1 Downloading [=>                                                 ]    4.3MB/131.3MB
 a16e55119267 Downloading [==================>                                ]  11.19MB/30.14MB
 a16e55119267 Downloading [===================>                               ]   11.5MB/30.14MB
 3330c4715eb1 Downloading [=>                                                 ]   4.84MB/131.3MB
 a16e55119267 Downloading [===================>                               ]  11.81MB/30.14MB
 3330c4715eb1 Downloading [==>                                                ]   5.38MB/131.3MB
 a16e55119267 Downloading [====================>                              ]  12.12MB/30.14MB
 a78651c5296d Downloading [=>                                                 ]    639kB/21.2MB
 a16e55119267 Downloading [====================>                              ]  12.43MB/30.14MB
 3330c4715eb1 Downloading [==>                                                ]   5.92MB/131.3MB
 a16e55119267 Downloading [=====================>                             ]  12.74MB/30.14MB
 a78651c5296d Downloading [==>                                                ]  863.2kB/21.2MB
 3330c4715eb1 Downloading [==>                                                ]  6.458MB/131.3MB
 a16e55119267 Downloading [======================>                            ]  13.37MB/30.14MB
 3330c4715eb1 Downloading [==>                                                ]  6.999MB/131.3MB
 a16e55119267 Downloading [======================>                            ]  13.68MB/30.14MB
 3330c4715eb1 Downloading [==>                                                ]   7.54MB/131.3MB
 a16e55119267 Downloading [=======================>                           ]  13.99MB/30.14MB
 a78651c5296d Downloading [==>                                                ]  1.076MB/21.2MB
 a16e55119267 Downloading [=======================>                           ]   14.3MB/30.14MB
 3330c4715eb1 Downloading [===>                                               ]   8.08MB/131.3MB
 a78651c5296d Downloading [===>                                               ]  1.289MB/21.2MB
 a16e55119267 Downloading [========================>                          ]  14.62MB/30.14MB
 3330c4715eb1 Downloading [===>                                               ]  8.607MB/131.3MB
 a16e55119267 Downloading [========================>                          ]  14.92MB/30.14MB
 3330c4715eb1 Downloading [===>                                               ]  9.142MB/131.3MB
 a16e55119267 Downloading [=========================>                         ]  15.23MB/30.14MB
 a78651c5296d Downloading [===>                                               ]  1.513MB/21.2MB
 a78651c5296d Downloading [====>                                              ]  1.726MB/21.2MB
 a16e55119267 Downloading [=========================>                         ]  15.54MB/30.14MB
 3330c4715eb1 Downloading [===>                                               ]  9.678MB/131.3MB
 a78651c5296d Downloading [====>                                              ]  1.939MB/21.2MB
 3330c4715eb1 Downloading [===>                                               ]  10.22MB/131.3MB
 a16e55119267 Downloading [==========================>                        ]  16.17MB/30.14MB
 a16e55119267 Downloading [===========================>                       ]  16.48MB/30.14MB
 3330c4715eb1 Downloading [====>                                              ]  10.76MB/131.3MB
 a78651c5296d Downloading [=====>                                             ]  2.152MB/21.2MB
 a16e55119267 Downloading [===========================>                       ]  16.79MB/30.14MB
 3330c4715eb1 Downloading [====>                                              ]   11.3MB/131.3MB
 a16e55119267 Downloading [============================>                      ]   17.1MB/30.14MB
 a78651c5296d Downloading [=====>                                             ]   2.38MB/21.2MB
 a16e55119267 Downloading [============================>                      ]  17.41MB/30.14MB
 3330c4715eb1 Downloading [====>                                              ]  11.83MB/131.3MB
 a78651c5296d Downloading [======>                                            ]  2.593MB/21.2MB
 a16e55119267 Downloading [=============================>                     ]  17.72MB/30.14MB
 3330c4715eb1 Downloading [====>                                              ]  12.37MB/131.3MB
 a78651c5296d Downloading [======>                                            ]  2.806MB/21.2MB
 a16e55119267 Downloading [=============================>                     ]  18.03MB/30.14MB
 3330c4715eb1 Downloading [====>                                              ]  12.91MB/131.3MB
 a16e55119267 Downloading [==============================>                    ]  18.34MB/30.14MB
 a78651c5296d Downloading [=======>                                           ]  3.019MB/21.2MB
 a16e55119267 Downloading [==============================>                    ]  18.65MB/30.14MB
 a78651c5296d Downloading [=======>                                           ]  3.246MB/21.2MB
 3330c4715eb1 Downloading [=====>                                             ]  13.45MB/131.3MB
 a16e55119267 Downloading [===============================>                   ]  18.97MB/30.14MB
 a16e55119267 Downloading [===============================>                   ]  19.28MB/30.14MB
 a78651c5296d Downloading [========>                                          ]  3.459MB/21.2MB
 3330c4715eb1 Downloading [=====>                                             ]  13.99MB/131.3MB
 a16e55119267 Downloading [================================>                  ]  19.59MB/30.14MB
 a78651c5296d Downloading [========>                                          ]  3.672MB/21.2MB
 a16e55119267 Downloading [=================================>                 ]   19.9MB/30.14MB
 a78651c5296d Downloading [=========>                                         ]  3.885MB/21.2MB
 a16e55119267 Downloading [=================================>                 ]  20.21MB/30.14MB
 a16e55119267 Downloading [==================================>                ]  20.52MB/30.14MB
 3330c4715eb1 Downloading [=====>                                             ]  15.07MB/131.3MB
 a78651c5296d Downloading [=========>                                         ]  4.098MB/21.2MB
 a16e55119267 Downloading [==================================>                ]  20.83MB/30.14MB
 a78651c5296d Downloading [==========>                                        ]  4.311MB/21.2MB
 3330c4715eb1 Downloading [=====>                                             ]  15.59MB/131.3MB
 a16e55119267 Downloading [===================================>               ]  21.45MB/30.14MB
 a78651c5296d Downloading [==========>                                        ]  4.538MB/21.2MB
 3330c4715eb1 Downloading [======>                                            ]  16.13MB/131.3MB
 a16e55119267 Downloading [====================================>              ]  21.76MB/30.14MB
 a78651c5296d Downloading [===========>                                       ]  4.751MB/21.2MB
 a16e55119267 Downloading [====================================>              ]  22.07MB/30.14MB
 a78651c5296d Downloading [===========>                                       ]  4.964MB/21.2MB
 a16e55119267 Downloading [=====================================>             ]  22.39MB/30.14MB
 a16e55119267 Downloading [=====================================>             ]   22.7MB/30.14MB
 a78651c5296d Downloading [============>                                      ]  5.191MB/21.2MB
 3330c4715eb1 Downloading [======>                                            ]  17.21MB/131.3MB
 a16e55119267 Downloading [======================================>            ]  23.01MB/30.14MB
 a78651c5296d Downloading [============>                                      ]  5.404MB/21.2MB
 a78651c5296d Downloading [=============>                                     ]  5.617MB/21.2MB
 a78651c5296d Downloading [=============>                                     ]   5.83MB/21.2MB
 3330c4715eb1 Downloading [======>                                            ]  17.75MB/131.3MB
 a16e55119267 Downloading [=======================================>           ]  23.63MB/30.14MB
 a78651c5296d Downloading [==============>                                    ]  6.042MB/21.2MB
 a16e55119267 Downloading [=======================================>           ]  23.94MB/30.14MB
 3330c4715eb1 Downloading [======>                                            ]  18.29MB/131.3MB
 a78651c5296d Downloading [==============>                                    ]  6.255MB/21.2MB
 a78651c5296d Downloading [===============>                                   ]  6.468MB/21.2MB
 3330c4715eb1 Downloading [=======>                                           ]  18.82MB/131.3MB
 a16e55119267 Downloading [========================================>          ]  24.56MB/30.14MB
 a78651c5296d Downloading [===============>                                   ]  6.681MB/21.2MB
 a78651c5296d Downloading [================>                                  ]  6.894MB/21.2MB
 a16e55119267 Downloading [=========================================>         ]  24.88MB/30.14MB
 a78651c5296d Downloading [================>                                  ]  7.107MB/21.2MB
 a78651c5296d Downloading [=================>                                 ]  7.332MB/21.2MB
 3330c4715eb1 Downloading [=======>                                           ]  19.36MB/131.3MB
 a78651c5296d Downloading [=================>                                 ]  7.545MB/21.2MB
 a78651c5296d Downloading [==================>                                ]  7.758MB/21.2MB
 a16e55119267 Downloading [==========================================>        ]  25.49MB/30.14MB
 3330c4715eb1 Downloading [=======>                                           ]   19.9MB/131.3MB
 a16e55119267 Downloading [==========================================>        ]  25.81MB/30.14MB
 a16e55119267 Downloading [===========================================>       ]  26.12MB/30.14MB
 a78651c5296d Downloading [==================>                                ]   7.97MB/21.2MB
 a78651c5296d Downloading [====================>                              ]  8.836MB/21.2MB
 3330c4715eb1 Downloading [=======>                                           ]  20.44MB/131.3MB
 a16e55119267 Downloading [===========================================>       ]  26.43MB/30.14MB
 a78651c5296d Downloading [=====================>                             ]  9.049MB/21.2MB
 a16e55119267 Downloading [============================================>      ]  26.74MB/30.14MB
 a78651c5296d Downloading [======================>                            ]  9.503MB/21.2MB
 3330c4715eb1 Downloading [=======>                                           ]  20.98MB/131.3MB
 a16e55119267 Downloading [============================================>      ]  27.05MB/30.14MB
 a78651c5296d Downloading [=======================>                           ]  9.929MB/21.2MB
 a78651c5296d Downloading [=======================>                           ]  10.15MB/21.2MB
 a16e55119267 Downloading [=============================================>     ]  27.36MB/30.14MB
 a78651c5296d Downloading [========================>                          ]  10.37MB/21.2MB
 3330c4715eb1 Downloading [========>                                          ]  21.52MB/131.3MB
 a16e55119267 Downloading [=============================================>     ]  27.66MB/30.14MB
 a78651c5296d Downloading [========================>                          ]  10.58MB/21.2MB
 a78651c5296d Downloading [=========================>                         ]  10.79MB/21.2MB
 a78651c5296d Downloading [=========================>                         ]     11MB/21.2MB
 a16e55119267 Downloading [==============================================>    ]  28.27MB/30.14MB
 3330c4715eb1 Downloading [========>                                          ]  22.06MB/131.3MB
 a78651c5296d Downloading [==========================>                        ]  11.22MB/21.2MB
 a78651c5296d Downloading [==========================>                        ]  11.44MB/21.2MB
 a78651c5296d Downloading [===========================>                       ]  11.65MB/21.2MB
 a16e55119267 Downloading [===============================================>   ]  28.58MB/30.14MB
 3330c4715eb1 Downloading [========>                                          ]   22.6MB/131.3MB
 a78651c5296d Downloading [============================>                      ]  11.87MB/21.2MB
 a16e55119267 Downloading [================================================>  ]  29.21MB/30.14MB
 a78651c5296d Downloading [============================>                      ]   12.1MB/21.2MB
 a78651c5296d Downloading [=============================>                     ]  12.31MB/21.2MB
 3330c4715eb1 Downloading [========>                                          ]  23.14MB/131.3MB
 a16e55119267 Downloading [================================================>  ]  29.52MB/30.14MB
 a78651c5296d Downloading [=============================>                     ]  12.52MB/21.2MB
 a78651c5296d Downloading [==============================>                    ]  12.74MB/21.2MB
 a16e55119267 Downloading [=================================================> ]  29.83MB/30.14MB
 a78651c5296d Downloading [==============================>                    ]  12.96MB/21.2MB
 3330c4715eb1 Downloading [=========>                                         ]  23.67MB/131.3MB
 a78651c5296d Downloading [===============================>                   ]  13.18MB/21.2MB
 a16e55119267 Verifying Checksum
 a16e55119267 Download complete
 a78651c5296d Downloading [===============================>                   ]  13.39MB/21.2MB
 a16e55119267 Extracting [>                                                  ]  327.7kB/30.14MB
 a78651c5296d Downloading [================================>                  ]   13.6MB/21.2MB
 a16e55119267 Extracting [=>                                                 ]    983kB/30.14MB
 3330c4715eb1 Downloading [=========>                                         ]  24.21MB/131.3MB
 a16e55119267 Extracting [==>                                                ]  1.638MB/30.14MB
 a78651c5296d Downloading [================================>                  ]  13.82MB/21.2MB
 a16e55119267 Extracting [===>                                               ]  2.294MB/30.14MB
 a78651c5296d Downloading [=================================>                 ]  14.03MB/21.2MB
 a16e55119267 Extracting [====>                                              ]  2.949MB/30.14MB
 a78651c5296d Downloading [=================================>                 ]  14.24MB/21.2MB
 a16e55119267 Extracting [=====>                                             ]  3.604MB/30.14MB
 3330c4715eb1 Downloading [=========>                                         ]  24.76MB/131.3MB
 a78651c5296d Downloading [==================================>                ]  14.45MB/21.2MB
 a16e55119267 Extracting [========>                                          ]  4.915MB/30.14MB
 a16e55119267 Extracting [=========>                                         ]  5.571MB/30.14MB
 a78651c5296d Downloading [==================================>                ]  14.68MB/21.2MB
 a16e55119267 Extracting [==========>                                        ]  6.554MB/30.14MB
 a16e55119267 Extracting [===========>                                       ]  7.209MB/30.14MB
 a78651c5296d Downloading [===================================>               ]  14.89MB/21.2MB
 a16e55119267 Extracting [=============>                                     ]  7.864MB/30.14MB
 a16e55119267 Extracting [==============>                                    ]  8.847MB/30.14MB
 3330c4715eb1 Downloading [=========>                                         ]   25.3MB/131.3MB
 a16e55119267 Extracting [===============>                                   ]  9.503MB/30.14MB
 a16e55119267 Extracting [================>                                  ]   9.83MB/30.14MB
 a78651c5296d Downloading [====================================>              ]  15.33MB/21.2MB
 a16e55119267 Extracting [=================>                                 ]  10.49MB/30.14MB
 a16e55119267 Extracting [==================>                                ]  11.14MB/30.14MB
 a78651c5296d Downloading [====================================>              ]  15.55MB/21.2MB
 a16e55119267 Extracting [===================>                               ]   11.8MB/30.14MB
 3330c4715eb1 Downloading [=========>                                         ]  25.84MB/131.3MB
 a16e55119267 Extracting [====================>                              ]  12.12MB/30.14MB
 a16e55119267 Extracting [=====================>                             ]  12.78MB/30.14MB
 a16e55119267 Extracting [======================>                            ]  13.76MB/30.14MB
 a78651c5296d Downloading [=====================================>             ]  15.97MB/21.2MB
 a16e55119267 Extracting [=======================>                           ]  14.42MB/30.14MB
 a16e55119267 Extracting [=========================>                         ]  15.07MB/30.14MB
 a78651c5296d Downloading [======================================>            ]  16.19MB/21.2MB
 a16e55119267 Extracting [==========================>                        ]  15.73MB/30.14MB
 3330c4715eb1 Downloading [==========>                                        ]  26.38MB/131.3MB
 a78651c5296d Downloading [======================================>            ]   16.4MB/21.2MB
 a16e55119267 Extracting [============================>                      ]  17.04MB/30.14MB
 a16e55119267 Extracting [=============================>                     ]  18.02MB/30.14MB
 a78651c5296d Downloading [=======================================>           ]  16.63MB/21.2MB
 a16e55119267 Extracting [==============================>                    ]  18.68MB/30.14MB
 3330c4715eb1 Downloading [==========>                                        ]  26.92MB/131.3MB
 a78651c5296d Downloading [=======================================>           ]  16.84MB/21.2MB
 a16e55119267 Extracting [================================>                  ]  19.33MB/30.14MB
 a16e55119267 Extracting [=================================>                 ]  19.99MB/30.14MB
 a16e55119267 Extracting [==================================>                ]  20.64MB/30.14MB
 a16e55119267 Extracting [==================================>                ]  20.97MB/30.14MB
 a78651c5296d Downloading [========================================>          ]  17.26MB/21.2MB
 a16e55119267 Extracting [===================================>               ]  21.63MB/30.14MB
 3330c4715eb1 Downloading [==========>                                        ]  27.46MB/131.3MB
 a78651c5296d Downloading [=========================================>         ]  17.48MB/21.2MB
 a16e55119267 Extracting [======================================>            ]  22.94MB/30.14MB
 a78651c5296d Downloading [=========================================>         ]  17.69MB/21.2MB
 a16e55119267 Extracting [=======================================>           ]  23.92MB/30.14MB
 a78651c5296d Downloading [==========================================>        ]   17.9MB/21.2MB
 a16e55119267 Extracting [=========================================>         ]   24.9MB/30.14MB
 a16e55119267 Extracting [=========================================>         ]  25.23MB/30.14MB
 a78651c5296d Downloading [==========================================>        ]  18.12MB/21.2MB
 3330c4715eb1 Downloading [==========>                                        ]     28MB/131.3MB
 5bea91f645c6 Downloading [>                                                  ]  196.6kB/19.17MB
 a78651c5296d Downloading [===========================================>       ]  18.54MB/21.2MB
 a16e55119267 Extracting [==========================================>        ]  25.89MB/30.14MB
 a16e55119267 Extracting [============================================>      ]  26.54MB/30.14MB
 a78651c5296d Downloading [============================================>      ]  18.75MB/21.2MB
 a16e55119267 Extracting [=============================================>     ]   27.2MB/30.14MB
 a16e55119267 Extracting [==============================================>    ]  27.85MB/30.14MB
 a78651c5296d Downloading [============================================>      ]  18.97MB/21.2MB
 3330c4715eb1 Downloading [==========>                                        ]  28.54MB/131.3MB
 a78651c5296d Downloading [=============================================>     ]  19.18MB/21.2MB
 a16e55119267 Extracting [===============================================>   ]  28.84MB/30.14MB
 a78651c5296d Downloading [=============================================>     ]  19.39MB/21.2MB
 a78651c5296d Downloading [==============================================>    ]  19.61MB/21.2MB
 a16e55119267 Extracting [================================================>  ]  29.16MB/30.14MB
 a78651c5296d Downloading [==============================================>    ]  19.82MB/21.2MB
 a16e55119267 Extracting [================================================>  ]  29.49MB/30.14MB
 a16e55119267 Extracting [=================================================> ]  29.82MB/30.14MB
 a78651c5296d Downloading [===============================================>   ]  20.04MB/21.2MB
 a16e55119267 Extracting [==================================================>]  30.14MB/30.14MB
 a78651c5296d Downloading [===============================================>   ]  20.26MB/21.2MB
 5bea91f645c6 Downloading [=>                                                 ]  393.2kB/19.17MB
 a78651c5296d Downloading [================================================>  ]  20.47MB/21.2MB
 a16e55119267 Pull complete
 46c16d549757 Extracting [=>                                                 ]  32.77kB/1.273MB
 3330c4715eb1 Downloading [===========>                                       ]  29.62MB/131.3MB
 46c16d549757 Extracting [==>                                                ]  65.54kB/1.273MB
 46c16d549757 Extracting [=========================>                         ]  655.4kB/1.273MB
 46c16d549757 Extracting [=============================>                     ]  753.7kB/1.273MB
 a78651c5296d Downloading [=================================================> ]   20.9MB/21.2MB
 46c16d549757 Extracting [==================================================>]  1.273MB/1.273MB
 46c16d549757 Pull complete
 12d00bf9121f Extracting [>                                                  ]  131.1kB/11.67MB
 a78651c5296d Downloading [=================================================> ]  21.11MB/21.2MB
 a78651c5296d Verifying Checksum
 a78651c5296d Download complete
 12d00bf9121f Extracting [==>                                                ]  524.3kB/11.67MB
 3330c4715eb1 Downloading [===========>                                       ]  30.16MB/131.3MB
 12d00bf9121f Extracting [===>                                               ]  786.4kB/11.67MB
 5bea91f645c6 Downloading [=>                                                 ]  596.1kB/19.17MB
 12d00bf9121f Extracting [=========>                                         ]  2.228MB/11.67MB
 3330c4715eb1 Downloading [===========>                                       ]   30.7MB/131.3MB
 12d00bf9121f Extracting [============>                                      ]  2.884MB/11.67MB
 12d00bf9121f Extracting [==============>                                    ]  3.277MB/11.67MB
 12d00bf9121f Extracting [===============>                                   ]  3.539MB/11.67MB
 3330c4715eb1 Downloading [===========>                                       ]  31.24MB/131.3MB
 12d00bf9121f Extracting [================>                                  ]  3.801MB/11.67MB
 12d00bf9121f Extracting [=======================>                           ]  5.505MB/11.67MB
 5bea91f645c6 Downloading [==>                                                ]  792.7kB/19.17MB
 12d00bf9121f Extracting [=========================>                         ]  5.898MB/11.67MB
 12d00bf9121f Extracting [==========================>                        ]  6.291MB/11.67MB
 3330c4715eb1 Downloading [============>                                      ]  31.78MB/131.3MB
 12d00bf9121f Extracting [=============================>                     ]  6.947MB/11.67MB
 5bea91f645c6 Downloading [==>                                                ]  986.8kB/19.17MB
 12d00bf9121f Extracting [===================================>               ]  8.258MB/11.67MB
 3330c4715eb1 Downloading [============>                                      ]  32.32MB/131.3MB
 12d00bf9121f Extracting [=====================================>             ]  8.651MB/11.67MB
 12d00bf9121f Extracting [======================================>            ]  9.044MB/11.67MB
 12d00bf9121f Extracting [========================================>          ]  9.437MB/11.67MB
 3330c4715eb1 Downloading [============>                                      ]  32.86MB/131.3MB
 5bea91f645c6 Downloading [===>                                               ]  1.193MB/19.17MB
 12d00bf9121f Extracting [==========================================>        ]  9.961MB/11.67MB
 12d00bf9121f Extracting [===========================================>       ]  10.22MB/11.67MB
 12d00bf9121f Extracting [============================================>      ]  10.49MB/11.67MB
 dca79262ae41 Downloading [==================================================>]  1.022kB/1.022kB
 dca79262ae41 Verifying Checksum
 dca79262ae41 Download complete
 3330c4715eb1 Downloading [============>                                      ]   33.4MB/131.3MB
 12d00bf9121f Extracting [==============================================>    ]  10.88MB/11.67MB
 12d00bf9121f Extracting [===============================================>   ]  11.14MB/11.67MB
 12d00bf9121f Extracting [=================================================> ]  11.67MB/11.67MB
 12d00bf9121f Extracting [==================================================>]  11.67MB/11.67MB
 12d00bf9121f Pull complete
 5bea91f645c6 Downloading [====>                                              ]  1.587MB/19.17MB
 079ccd64f646 Extracting [==================================================>]     249B/249B
 3330c4715eb1 Downloading [============>                                      ]  33.94MB/131.3MB
 079ccd64f646 Pull complete
 5bea91f645c6 Downloading [====>                                              ]  1.794MB/19.17MB
 3330c4715eb1 Downloading [=============>                                     ]  34.48MB/131.3MB
 5bea91f645c6 Downloading [=====>                                             ]  1.991MB/19.17MB
 5bea91f645c6 Downloading [=====>                                             ]  2.188MB/19.17MB
 5bea91f645c6 Downloading [======>                                            ]  2.384MB/19.17MB
 5bea91f645c6 Downloading [======>                                            ]  2.581MB/19.17MB
 3330c4715eb1 Downloading [=============>                                     ]  35.56MB/131.3MB
 5bea91f645c6 Downloading [=======>                                           ]   2.78MB/19.17MB
 5bea91f645c6 Downloading [=======>                                           ]  2.977MB/19.17MB
 3330c4715eb1 Downloading [=============>                                     ]   36.1MB/131.3MB
 5bea91f645c6 Downloading [========>                                          ]  3.173MB/19.17MB
 5bea91f645c6 Downloading [========>                                          ]  3.381MB/19.17MB
 5bea91f645c6 Downloading [=========>                                         ]  3.578MB/19.17MB
 3330c4715eb1 Downloading [=============>                                     ]  36.64MB/131.3MB
 5bea91f645c6 Downloading [=========>                                         ]  3.774MB/19.17MB
 5bea91f645c6 Downloading [==========>                                        ]  3.971MB/19.17MB
 5bea91f645c6 Downloading [==========>                                        ]  4.168MB/19.17MB
 5bea91f645c6 Downloading [===========>                                       ]  4.364MB/19.17MB
 5bea91f645c6 Downloading [===========>                                       ]  4.561MB/19.17MB
 5bea91f645c6 Downloading [============>                                      ]  4.764MB/19.17MB
 5bea91f645c6 Downloading [============>                                      ]  4.961MB/19.17MB
 3330c4715eb1 Downloading [==============>                                    ]  37.72MB/131.3MB
 5bea91f645c6 Downloading [=============>                                     ]  5.157MB/19.17MB
 5bea91f645c6 Downloading [=============>                                     ]  5.365MB/19.17MB
 5bea91f645c6 Downloading [==============>                                    ]  5.562MB/19.17MB
 5bea91f645c6 Downloading [===============>                                   ]  5.758MB/19.17MB
 3330c4715eb1 Downloading [==============>                                    ]  38.26MB/131.3MB
 5bea91f645c6 Downloading [===============>                                   ]  5.966MB/19.17MB
 5bea91f645c6 Downloading [================>                                  ]  6.163MB/19.17MB
 5bea91f645c6 Downloading [================>                                  ]  6.359MB/19.17MB
 5bea91f645c6 Downloading [=================>                                 ]  6.556MB/19.17MB
 e1c0035b8792 Downloading [==================================================>]     149B/149B
 e1c0035b8792 Verifying Checksum
 e1c0035b8792 Download complete
 5bea91f645c6 Downloading [=================>                                 ]  6.748MB/19.17MB
 3330c4715eb1 Downloading [==============>                                    ]  39.34MB/131.3MB
 5bea91f645c6 Downloading [==================>                                ]  7.141MB/19.17MB
 5bea91f645c6 Downloading [====================>                              ]   7.95MB/19.17MB
 5bea91f645c6 Downloading [=====================>                             ]  8.146MB/19.17MB
 5bea91f645c6 Downloading [=====================>                             ]  8.354MB/19.17MB
 5bea91f645c6 Downloading [======================>                            ]  8.551MB/19.17MB
 3330c4715eb1 Downloading [===============>                                   ]  39.88MB/131.3MB
 5bea91f645c6 Downloading [======================>                            ]  8.746MB/19.17MB
 5bea91f645c6 Downloading [=======================>                           ]  8.943MB/19.17MB
 5bea91f645c6 Downloading [=======================>                           ]   9.14MB/19.17MB
 5bea91f645c6 Downloading [========================>                          ]  9.336MB/19.17MB
 5bea91f645c6 Downloading [========================>                          ]  9.538MB/19.17MB
 3330c4715eb1 Downloading [===============>                                   ]  40.42MB/131.3MB
 5bea91f645c6 Downloading [=========================>                         ]  9.931MB/19.17MB
 5bea91f645c6 Downloading [==========================>                        ]  10.14MB/19.17MB
 5bea91f645c6 Downloading [==========================>                        ]  10.34MB/19.17MB
 5bea91f645c6 Downloading [===========================>                       ]  10.53MB/19.17MB
 3330c4715eb1 Downloading [===============>                                   ]  40.96MB/131.3MB
 5bea91f645c6 Downloading [===========================>                       ]  10.73MB/19.17MB
 5bea91f645c6 Downloading [============================>                      ]  10.92MB/19.17MB
 3330c4715eb1 Downloading [===============>                                   ]  41.49MB/131.3MB
 5bea91f645c6 Downloading [===============================>                   ]  11.91MB/19.17MB
 5bea91f645c6 Downloading [===============================>                   ]  12.12MB/19.17MB
 3330c4715eb1 Downloading [================>                                  ]  42.03MB/131.3MB
 5bea91f645c6 Downloading [================================>                  ]  12.32MB/19.17MB
 5bea91f645c6 Downloading [================================>                  ]  12.52MB/19.17MB
 5bea91f645c6 Downloading [=================================>                 ]  12.71MB/19.17MB
 5bea91f645c6 Downloading [=================================>                 ]   12.9MB/19.17MB
 5bea91f645c6 Downloading [==================================>                ]   13.1MB/19.17MB
 5bea91f645c6 Downloading [==================================>                ]   13.3MB/19.17MB
 2a9b507f3461 Downloading [>                                                  ]  4.134kB/327.4kB
 2a9b507f3461 Downloading [=====>                                             ]  32.77kB/327.4kB
 5bea91f645c6 Downloading [===================================>               ]  13.51MB/19.17MB
 3330c4715eb1 Downloading [================>                                  ]  43.11MB/131.3MB
 5bea91f645c6 Downloading [===================================>               ]   13.7MB/19.17MB
 5bea91f645c6 Downloading [====================================>              ]   13.9MB/19.17MB
 5bea91f645c6 Downloading [====================================>              ]   14.1MB/19.17MB
 2a9b507f3461 Downloading [======>                                            ]  45.17kB/327.4kB
 3330c4715eb1 Downloading [================>                                  ]  43.65MB/131.3MB
 5bea91f645c6 Downloading [=====================================>             ]  14.29MB/19.17MB
 2a9b507f3461 Downloading [==========>                                        ]  65.54kB/327.4kB
 2a9b507f3461 Downloading [=================>                                 ]  114.7kB/327.4kB
 2a9b507f3461 Downloading [====================>                              ]  131.1kB/327.4kB
 3330c4715eb1 Downloading [================>                                  ]  44.19MB/131.3MB
 5bea91f645c6 Downloading [=====================================>             ]  14.49MB/19.17MB
 5bea91f645c6 Downloading [=======================================>           ]  15.29MB/19.17MB
 2a9b507f3461 Downloading [=========================>                         ]  163.8kB/327.4kB
 2a9b507f3461 Downloading [===========================>                       ]  180.2kB/327.4kB
 5bea91f645c6 Downloading [========================================>          ]  15.49MB/19.17MB
 2a9b507f3461 Downloading [==============================>                    ]  196.6kB/327.4kB
 5bea91f645c6 Downloading [========================================>          ]   15.7MB/19.17MB
 2a9b507f3461 Downloading [================================>                  ]    213kB/327.4kB
 2a9b507f3461 Downloading [===================================>               ]  229.4kB/327.4kB
 2a9b507f3461 Downloading [=====================================>             ]  245.8kB/327.4kB
 3330c4715eb1 Downloading [=================>                                 ]  45.27MB/131.3MB
 2a9b507f3461 Downloading [==========================================>        ]  278.5kB/327.4kB
 5bea91f645c6 Downloading [=========================================>         ]  15.89MB/19.17MB
 5bea91f645c6 Downloading [===========================================>       ]  16.69MB/19.17MB
 2a9b507f3461 Downloading [===============================================>   ]  311.3kB/327.4kB
 5bea91f645c6 Downloading [============================================>      ]  16.89MB/19.17MB
 2a9b507f3461 Downloading [==================================================>]  327.4kB/327.4kB
 2a9b507f3461 Verifying Checksum
 2a9b507f3461 Download complete
 3330c4715eb1 Downloading [=================>                                 ]  45.81MB/131.3MB
 5bea91f645c6 Downloading [============================================>      ]  17.08MB/19.17MB
etc, etc, etc
Using CPython 3.13.9 interpreter at: /usr/local/bin/python
Creating virtual environment at: .cache/.venv
Activating python virtual environment
2025-11-12 17:42:39.025 INFO - [MainThread] App:  App started
======== App is starting ============================
I have deleted your other cross-posts @bgbetz.
Cross-posting is against the Arduino Forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Quick notes on this:
If you have Arduino installed and the Q board installed, it probably is already on
your computer:
That is on my machine I can type:
C:\Users\kurte\AppData\Local\Arduino15\packages\arduino\tools\adb\32.0.0\adb.exe shell
Your location is likely different.
Also I can connect up to my board using KiTTY (or PuTTy), this is KiTTY
Edit And if you wish to transfer files between your PC and the Q, KiTTy has
menu item to launch WinSCP
doesnt help: sudo apt update && sudo apt upgrade -y
Updated, the board also was rebooted.
The same error.
@jomardyan
Please try flashing the board with the latest image. See https://docs.arduino.cc/tutorials/uno-q/update-image/ for the how-to tutorial.
It was already done, but i can try again reflash if you think it will help.
@jomardyan
Before you launch the App Lab, please connect to the board via adb and check if its connectivity is working. A simple ping is enough.
ping 8.8.8.8
If it is not working, you can check if the WiFi is connected with the nmcli tool
nmcli device wifi list
should output
IN-USE  SSID              MODE   CHAN  RATE        SIGNAL  BARS  SECURITY
*       MyHomeNetwork     Infra  11    405 Mbit/s  100     ▂▄▆█  WPA2
        Neighb_Network    Infra  6     130 Mbit/s  70      ▂▄▆_  WPA2
        AnotherWiFi       Infra  1     270 Mbit/s  55      ▂▄__  WPA1
Where the * means the board is connected to the corresponding SSID.
For more examples and how to (re)connect the WiFi, please see nmcli-examples: NetworkManager Reference Manual
Good evening, I see that it is a common fault, and even though they already released the Uno Q 4Gb , I have the one of 2Gb flashed to the board, connect it just fine as SBC mode, but found that there is a partition called Arduino, which is not mounted and has as root user or super user
I don't know if this permissions thing is related to update failure and 403 bug.
Atte Anna Carolina Diaz Riera
